- Jan 26, 2024
- 15
I'm assuming so, I've never used a taper attachment before so I honestly don't know what I'm looking for with that. Is there anything else I would need to make this work?You mean like the block that fits the rod and clamps it to the bedway?
Yes on the block that clamps to the bed to hold the protruding rod. Maybe, maybe not on disengaging the cross slide - depends if that machine is set up with the telescoping cross slide screw (my Enterprise lathe has a very similar looking TTA, no need to disengage the cross slide lead screw).it looks like just the block and clamps. The block clamps to the bed , and to the rod. it holds the taper attachment and prevents it from moving.
you'll also need to figure out how to disengage your cross slide while using it.
