Pm-932m Feeds/speeds/doc/etc
Bray D
Jan 30, 2015
99
I wasn't sure where to post this, but I have a PM-932M so I figured I may as well post it in this forum.
I'm new to machining and I see a lot of references to feeds and speeds. The tool speed makes perfect sense, however I'm struggling to understand feeds and appropriate depths of cut.
Being a manual machine, I assume it will be difficult to quantify feed rates. That being said, could you guys school me on machine feeds rates? What are the variables used, how do you quantify those variables, and what is the ultimate equation that's used to calculate said feed rate?
That brings us to depth of cut. Is there a rule of thumb for finding the 'correct' depth of cut?
I've just been simply listening/feeling/observing my machine and trying to obtain a feel through mechanical empathy. It would be nice to put some numbers to this stuff. Hopefully it increases productivity as well. I could very well be treating my machine 'too nicely'.
Do you have a Machinists' Ready Reference? Nifty palm-sized book, with literally hundreds of formulas machinists need. There is an entire section on what speeds...roughing and finish...for what materials, with what type of tool (HSS or carbide).
What a machinist uses on large automated machinery doesn't map well to what a hobby machinist does on a much smaller, less rigid, manual machine. Unless that hobby machinist is doing CNC of course, and even then unless you machine weighs several thousand pounds those formulas may not be apropos.
You are already doing what most, including myself, do in that we 'listen' to the machine/cut. You can tell when it's happy, and when it's not (chatter/poor finish/broken bits). Each machine is different, and will respond to a particular operation differently. There are some general guidelines of course: slower/smaller cut for harder materials, while aluminum and other similar materials can go much bigger/faster.
As for treating your machine "too nice", well that just means it will last longer. You can of course attempt to always take the maximum cut you can get but that just means you will wear out your tooling and machine that much faster.
+1 what Bill said. I would say you are doing it correctly.
Now add the cutting tool variable, HSS vs carbide insert. Heck there's a maddening variety of just different carbide inserts to choose from that will perform quite a bit differently on the same machine. Carbide grade, shape, size, rake, did I mention it was maddening? You just have to figure out what works best on your particular machine.
This is no less true for 12,000 lb CNC machines, they also have to figure out what works best on their machines, how long the insert lasts is a factor, they do this largely through trial and error, recommendations from suppliers, other shops on what is working for them on the particular machine. Typically once they find something that works they stick with it, but they will still kick the tires on the latest new age insert from time to time. In production work if you can shorten cycle times 10%, 20% that's a pretty big deal.
As for being too easy on your machine, unfortunately we don't have a spindle load meter to help guide is. Even on industrial CNC machines its not generally a best practice to run the machine at the limit, sometimes it is but machines do wear out. If a machine is dedicated to churning out a part that pays for the machine in 3 months say, and it makes financial sense to run the machine into the ground at its max limit for 4 years then throw it away that's what you do. That's why I'm leery of purchasing a used CNC machine frankly.
My brother never ran his Haas VF2SS at more than 50% rapids for example. That thing will rapid at 1200 ipm which is insane. Spindle speed is 12,000 rpm but again he throttled it to between 6,000 and 8,000. After 5 years the machine still looked brand new and performed like new.
I found all the recommended speeds/feeds in Machinists' Ready Reference to work very well on my Smithy Granite, as they did for the big machines in school and at work. The only widely vastly different variable was depth of cut.
I'd agree that just because your machine can hog off .100" cuts doesn't mean you need to operate there all the time. Treat it well and make it last.
Now the OP has a 932 which is very similar to my 12Z, and in HIS case, a .1 DOC is nothing. I've done .75" (not a typo) DOC on mine and while it was a little hard on the cutter as it was a dry cut, the mill handled it well. I just wouldn't recommend a steady diet of that type of cut if you want the machine to last very long. That is what I was thinking when I typed the above comments. :)
Thanks for all of the replies, guys. Sounds like I haven't been doing anything too out of line so far. I have access to a Machiney's Handbook, though I haven't spend a whole lot of time studying it as I assume it was created for far more rigid commercial machines. I may have to pick up a Ready Reference for future reference though.
I haven't broken any bits yet so that's a plus. My heaviest cut thus far was a full cutter width .100 DOC with a 1/2" 4 flute HSS end mill in steel. It seemed to handle it pretty well. I ran 6 parts under those same conditions. .190 DOC with a 1/4" cutter in cast iron on another project. Definitely no issues with the 1/4" end mill.
I'd like to start experimenting with different cutters, though that will get expensive quickly. I just ordered a set of 4 flute cobalt roughers, though. I'll keep 'playing it by ear' and see how it goes.
I used a 1/2" cobalt rougher for that 3/4" deep cut. I'd not recommend that if you want the cutter to last very long though. :rolleyes:
.875 deep. 1/2 cobalt rougher, 1018 steel, WD-40 mist coolant.
