That's a wedged shaped heating element on the end, insert the wire into the heating element, you can use that black stop to adjust how much wire you want to strip if you are stripping a bunch of wires, you press the red button and it heats up red hot, about a half turn on the wire and the heating element slices through the insulation. If the stripped insulation gets stuck you press that other red button and it flicks it off.
