Cnc Options For The G0704?
The DYN2 at $348/axis looks nice; the demo video was certainly impressive. The current version of what I'm using from Xylotex is $375 for 4 axes. I'm sure he must have updated his hardware, since the Allegro A3977 he was using has gone obsolete. I don't know how to compare the ratings of the servo motor at 400W to the 425 in-oz stall torque on the Xylotex steppers, or if 425 in-oz is a reasonable torque for the G0704.
I ordered Hoss' DVD last night and got the shipping notice already, so I'll probably have it by next weekend. I've been on vacation this past week and will be getting back on my head Monday - as the old joke goes. Less time in the shop, but maybe I can do some more reading/planning. It's coming up on summer and around here in Florida, summer is the time to do your indoor projects. Yeah, we're kind of backwards from the rest of the country.
Bob, I've been to parts of Florida in the summer; I can see why it is done that way *grin*. How'd the Xylotex work out for you? Did you ever encounter mid-band resonance/are the motors fitted with dampeners?
I`m putting up another wall of text, just in case this is useful for anyone else is still following along.
Steppers have a rated holding torque that drops off with speed increase, so the torque needed has to be calculated at the operating parameters expected. Here's a sample curve. Faster operation means less rotary torque available to be converted into linear force.
Servo motors (excluding a encoder equipped stepper, which technically is a "servo") generally have a rated torque which is run-all-day-long value and a peak torque, typically 3 times the rated for only a limited time period that can decline with increasing speed but remains fairly flat (brushed DC motors drop off faster than BLDC or AC Servo).
Motor Sizing is dependent on what the machine is expected to do: how much weight and cutting forces must be moved at what rate and what acceleration, as well as what mechanical advantage is supplied by the rotary to linear motion mechanism (pitch of the screw). The overall goal is to make certain the torque available is sufficient during acceleration and nominal operations. On a servo, the intermittent region of the curve is for acceleration and deceleration, with the average needs within the rated torque envelope; on a stepper, the holding torque drops with speed, sometimes precipitously.
Now, before I run on further and not address Bob's comments....
Warning: I did make attempts to check my math, but I`ve been multi-tasking this all day *scribbles*, and this prime ground (for me) for mistakes, what with all the conversions.
Is the 425 in-oz a reasonable torque for the G0704?
Hoss states his bare recommended minimum is 381 oz-in steppers on the X and Y, and a 465 on the Z, and then states that 570 oz-in steppers are a great match (on the X and Y axis; 906 oz-in on Z) with stock screws (which have huge efficiency losses compared to ballscrews, and will traverse slower) or ballscrews. So, that gives us a range. Others builds he references also seem to use similar motor ranges.
Xylotex does not seem to publish a torque vs. speed graph for the motor, so I looked at a Automation Technologies 425 unit. The graph is a bit daft, apparently missing the top value (425 oz-in is 3 N.m), and is in Pulses Per Second, not Rotations Per Minute; makes it tricky to compare.
1.8 degree motor at 8x micro-stepping would be 1 600 steps per rotation. 8000 PPS = 480 000 pulses per minute, 480 000 PPM / 1600 steps = 300 RPM.
So, according to the curve, 42.5 oz-in is remaining at 300 RPM into a (picked out of the blue) 5mm pitch (~0.2 inch per rotation) ballscrew will produce ~75 pounds of force at 53 Inches Per Minute (IPM) of travel; this is just first approximation, and disregards friction from the gibs, dovetails, opposing cutting forces, acceleration losses, etc. Again, this is assuming the two motors are in any way similar; I have no way of knowing, and measuring in PPS is...unusual, to put it mildly.
Looking at the 570 oz-in Hoss recommended, it has a Torque-Speed Curve claiming at 1000 RPM it will produce ~63 oz-in translating into ~111 lbs. of linear force.
So the 570 stepper provides more rapid speed and more force. Why 1000 RPM? Using the above screw at 1 000 RPM will produce 200 IPM travels. Why 200 IPM?
Feeds and Speeds
I set out to see what the maximum rapid IPM people have been achieving. Again, the ubiquitous Hoss has achieved 300 IPM rapids (with the 570 oz-in motor). 200 IPM seems to be quoted as a more common number, so I used it in the example above. He also claims in one thread he has hit 200IPM with a 0.5 endmill during High Speed Machining operations, so it seems a reasonable number to look at for actual use (moving 200 pounds at 200IPM might be asking a wee bit much, however).
To do some basic cross-checking, I decided to take what I'd seen and compare the quoted numbers to G-Wizard rendered ones. The G0704 comes stock with a 1 HP spindle motor, end mill capacity of 0.75 inch (according to Grizzly). I took that information and built a machine in G-Wizard, and started in.
One video has Hoss demonstrating with a 0.8HP spindle motor driving a 0.5 inch four flute HSS endmill at 2250RPM, He managed a full width cut at 0.375 inches depth in 6061 Aluminum at a stated 12-15 IPM with no excessive audible motor loading noted.
G-Wizard, using this information and that from the mill specifications, gives a value of 18.4 IPM for a very aggressive cut, and 9.7 for a fine finish. The IPM is limited on the aggressive setting by available HP, and tool deflection on the fine finish. So, the theoretical roughly corresponds to the actual achieved numbers.
I then cross-checked using a milling power calculator (this is an approximation only) on 6061 Aluminum and lowered the feedrate to 13 IPM (due to the calculator claim this is 1HP motor load), I did the same using 4140 steel which nets a feed rate of between 2 (calculator) and 2.6 (G-Wizard) IPM. Hoss`s numbers look good (not that I doubted them; he knows more about practical machining than *I* do, for certain).
What I take away from the above is: Yes, depending on the motor's characteristics and mode (low impedance, high driving voltage, bipolar parallel more usable torque at higher RPM) and its torque-speed curve, a 425 oz-in stepper would work on the G0704 X and Y axis with high rapid speeds, as shown by theory, actual examples and cutting rates.
Comparing the ratings of the servo motor at 400W
Power is work over time, either in HorsePower or Watts. Torque x RPM = power.
Quick and dirty power formula for motor : Power: Watts = (heaviest object in lbs. * Inch Per Minute) / 531 (the 531 constant is just cutting out the conversions)
Example: ~113 Watts required to move 200 pounds (assume: 75 pounds for table and attachments, plus 125 pounds for work-piece, holding) at 300 IPM.
The 570 oz-in motor in the previous example would be generating ~46.5 Watts, and the 425 oz- in generating ~10 Watts. The G0704 1HP spindle motor, for contrast, would produce 448 oz-in at 2250 RPM to rate at 1 HP.
The DMM 640-DST-A6TS1 (DYN2, 60mm fram, 400W, Medium Inertia, 16 Bit Encoder, 60V max, Straight Shaft) has a rated torque of 1.27 N.m (180 oz-in) and a peak torque of 3.82 N.m (540 oz-in). Here are the Torque-Speed Curves.
As such, while 180 oz-in is considerably weaker than the holding torque of the aforementioned steppers, at speed (200 IPM rate * 5 rev. per inch = 1000 RPM) the motor is still generating 180 oz-in (18x and 3.8x respectively for the previously mentioned steppers) and ~318 pounds of linear force, or 133 Watts, with 3x that much in reserve for intermittent use at that speed.
Edit: Acceleration is a critical part of system design, and I will actually (gasp) refrain from getting into it at this time; suffice it to say there should be ample reserve capacity to put the pedal to the metal, so to speak.
Additional Resources:
- here's a handy guide put together by CNC Cookbook for motor sizing. In that post is a link for a Excel spreadsheet that has assorted variables to contemplate.
(for the above Excel file)
Mill Table Weight: I also could not find the stated weight of the mill table, so off I went to a calculator with the dimensions for a guesstimate: 73 lbs.
Part and Fixture Weight or Table Capacity: The G0704 has a table capacity of 125-150 lbs (also according to Hoss).
Cutting Force: That can be determined via calculators found on the web.
Linear aka Rapid IPM: Hoss again. 300 IPM (utilizing steppers)
Cutting IPM: Hoss claims in one thread he can hit 200IPM with a 0.5 endmill. This is in-line with comments others have made.
Leadscrew: Not much information I could quickly research, sorry.
Lead/Pitch: I looked quickly and could not seem to find what the leadscrew is that comes with the G0704, one claimed it was 5mm.
Diameter and Length: Again, no information.
Lead Efficiency: I could also not find reference to the lead efficiency, but it is somewhere between 20-40% generally. .4 is the value I run across most often.
- Kollmorgen Motioneering Online : online (register access) utility for linear motion system design
- Choosing Stepper or Servo: Gecko Drives
- MIT on Speed-Torque Curves
- Maris Freimanis from Gecko on a CNCZone thread running some numbers as an example of sizing, gearing, power, resolution for a gantry router
I'm a bit lost here, are we converting a lower end milling machine, made in china, installing Chinese ball-screws,
and strapping the trajectory computer for the lunar lander to it.
:cpa:
:cpa:
*laughs*
That's the beauty of the world; for those that want plug and play, many people have already crunched the numbers and come up with acceptable solutions; hence the links to existing proven selections. Use "x" with "y" and go hard with full confidence that others have it working.
For others, they want to optimize and understand the choices that go into such (hence the links to all the threads where this stuff is discussed in detail), or understand why their purchase of cheap and popular offshore chopper style stepper drives (hint they are popular because they are cheap) combined with serially wired huge steppers and a high speed gantry have yielded disappointing crappy results; or the eternal steppers vs. servo discussions, and the wisdom of putting $3000 of gear on a $1000 mill.
You should see the epoxy granite retrofit discussions :)
I have had similar thoughts when reading the threads about people scraping in these mills to improve performance; still, they have me (and others) thinking about it.
Does anybody counter weight the head on their CNC mill to help reduce the required motor on the Z? One of the FIRST things I did on my NON CNC 704 was to mount a couple pulleys on the ceiling and put about 40lbs of counterweight behind the cabinet to make it easier to raise the head.
Jim
You are most welcome.
See, I CAN write short responses! *grin*
Jim
I've seen many mention using gas charged supports to take some of the weight off. The type like your car has on the rear hatch to hold it up. Many options for those at McMaster.
Dave
Hoss did not bother to do his, due to a larger motor on the Z, but I have seen example threads where it is done (mostly other mills); I understand some of the VMCs have it as well. I can see the case for it, your own experiences for starters.
As Dave so rightly puts it, gas shocks (I was proofing this as his message popped up!) seem to be more common. CNCFusion at one time sold a gas spring add-on kit as well.
Here is a link on a BF clone equipped with a counterweight from the Hoss Massive Thread , and the linked YouTube Video of the same.
And from a CNC Arena thread (which seems to be a copy of the CNCzone threads):
I know this is probably going to be a ...............well DUH question, but why does the X2 need a counter weight , and the 0704 not?
An x2 wouldn't need a counterweight if you use a strong enough stepper with a proper driver and power supply.
A 381 oz/in, g540, 48v PS works well on an X2 just like a 570 oz/in, 6050 or 5056D, 48v PS works well on a g0704.
Go crazy adding weight to the head and you need more oomph or add a counterweight or gas springs.
Hoss
I have done a lot of playing around with the G0704.
As far as the steppers. The 575 is a great stepper because of the low 2.1MH inductance. It is just plan faster than almost all the other steppers. With any properly sized motor you never run out of power at low speeds. A cutter requires less power at low speeds and direction change forces are less. Steppers fail at high speeds due almost entirely to making less power at higher RPM due to inductance.
I can't count the number of people throwing stepper twice the size needed at a mill. Most of the guys are running the 575 which is a 5A stepper and driving it with a 5.6A PEAK China drive so that is 5.6A x .707 for RMS or 3.9A RMS so they are running the stepper at about 80% of full power.
Most are also running a 900oz on the Z which is silly too but the last 10 CNC kits I have sold for the 704 they all wanted the Nema 34 Z mount for the 900 oz stepper. The 575 works great on the Z even at 4A if you run it at full power then it is even better.
So most people are limiting the power they make by the driver and not the stepper.
The 425 is OK but has higher inductance so is slower.
I have no idea why you would want to run a servo. A good Gecko stepper driver works really well and you will never look back. They are much better than the China drivers. Micro stepping does help the accuracy but really makes the stepper run smoother at low speeds. I think only Gecko drives do drive morphing so they make 1/3 more power at high RPM over the China drives yet still have vary high micro stepping at low RPM for smooth running.
