- Jul 23, 2015
- 17
Hi All:
I've recently inherited a nice VN #12 (serial 12-8793 from early 1947). It came with a lot of tooling and accessories all in need of refurbishment, so I'll be asking a lot of questions.
Right now I've got the head disassembled to the point that I can see that there is absolutely no oil left in the mid-section but there is a lot of very old grease in the upper and lower bearings. I'd love to completely disassemble everything and clean all the pieces, but I have two concerns...
1) Since I am completely new to this... should I not attempt to move the bevel gear and hope to get it shimmed properly back in place when I re-assemble it. I know nothing about shimming bevel gears other than it is important to get it right and I don't know how to do it.
2) How can I get the spindle out (press it out) without trashing the very expensive looking Timken roller bearing (28150) at the top of the housing. The spindle spins very smoothly right now. It seems to have a little more preload than I would have expected... maybe that's the thickened and aging grease that is all over the place, but it rotates quite easily by hand and I am very hesitant to mess with it.
Can the whole head be cleaned well enough without any further disassembly? So far I've removed the top and bottom caps, the upper bearing preload nut and washer, and the side access cover. I'd like to start using an appropriate grease for the bearings... Chevron SRI or Mobil Polyrex EM from what I've read, but since I don't know what was used previously I'd like to get all the old stuff out in case of incompatibility issues.
Any advice would be appreciated.... Jeff in Danvers Mass.
