Cutting Hss Blanks
I buy hss tool stock from ctc tools in Hong Kong (google them). In this side of the Indian Ocean they are just too expensive
Sent from my GT-I9505 using Tapatalk
Bill,
Based on the code system from the link you provided, the wheel in question would be Alox, 80 grit, grade H, density 12.
From what I understand all manufacturers use the same basic code but have options to add their own letters or numbers before or after the standard specification. Have you contacted your Norton supplier for help?
Hope this helps, Mike
When I need to cut a HSS bit for a boring bar I use these.
Interesting read. I'd like to see that tool holder you made if you have a direct link to it. The POTD thread is huge.
Haven't bought any, but looking to.
Would ranter find a source of longer blanks that could be cut to the desired length.
I bought 4" and 6" blanks from Wholesale tool in various thicknesses.Several are 1/4" x 1/2 ,3/8" x 1/2 .Most are 4" long.
this rockwell grinder with thin blades go thru hhs like butter..locks, drill bits, hand cuffs, safes..ect.
