Another 1340gt Owner
Nice spider and tach install. :cheerful:
Noticed in the photos you have lots of the small black specs from the factory belt. Recommend replacing it with a Gates 5L280W to use on the "B" pulley section, and a Gates 6970 for use on the "A" . They run smoother and actually slightly quieter... several guys have had problems with the factory belt basically shredding after about 10 hours or so.
They also give you a slight bit more room between the motor and the lathe.
Thanks AirWolf!
I have the 5L280W already and am waiting for the BX24 to come in yet.
I had to use the factory one for a bit today, makes a heck of a mess in a very short time.
Very nice work Lonnie
Do you some details on the tac & display you used? Links to seller would be appreciated.
