Parting Tool Question
Wow, I didn't realize it was only solder holing those on. Thanks
It's called silver solder and has a tensile strength of between 40,000 and 70,000 according to Harris Products Group.
Although called solder, it is nothing like the typical plumbing or electronic solders which are a mixture of lead and tin
traditionally. Silver solders have a melting temperature of somewhat over 800 degrees F. Silver solders are usually
an alloy of copper, tin and silver and is available in various mixtures of these metals depending on use and strength needed.[/QUOTE]
Is it the same solder the HVAC guys use?
Is it the same solder the HVAC guys use?[/QUOTE]
Ken,
Generally speaking, yes. There are several brands available as well as manufacturers and product mixes. Welding shops
carry this and also the flux. By the way, the flux can be unhealthy if used in a closed space not to mention any silver solder
mixtures that contain cadmium as it can cause permanent breathing problems. Fortunately most of the silver solders
do not contain cadmium any more. Definitely read the labels and pay attention to any warnings on the packaging of both the solder
and the flux.
I need a pic of the shim solution
Ken,
and the flux.[/QUOTE]
Here's a little more information on silver solder and flux. I use a Harris product called Stay Silv which contains potassium
fluoride and difluorodihydroxyborate. Fluorides as you may or may not know are some extremely reactive compounds
used in this case for "wetting" or maybe ease of flow would be another way to put it. It's pretty difficult to do silver
soldering without the flux because the solder just won't flow properly. Knowing about the products goes a long way
to its safe use. Basically on the labels they say to not breathe the fumes or have skin contact or eat, drink or smoke
while using this product but they don't say why. Now we know why. To sum it all up, a little common sense thrown
in goes a long way to being safe in the shop. Harris makes another product called Stay Silv 15 which is a silver soldering
rod. I have used it but prefer the finer silver solder wire for small work. The rod is pretty good for cementing carbide
on to various tooling like boring bars or lathe cutters. Silver soldering is a good skill to have in the shop and found to
be quite useful when the need arises.
On the less serious side, better living through chemistry!:chemist:
I had to inject a little humor, keep :pickaxe: in the shop, use your :sherlock:, don't be a :clown:.
Geez, these emoticons are fun! Have a good day.
Lol... Thank you for that information. It sure takes the guesswork out of the decision.
It's probably not what you expected but lacking any shim stock, I cut two pieces of paper and laid them in at the base of the tool. The results were a perfectly perpendicular cut.
Whatever works! Thanks for the picture.
I had (have) a similar problem, with the parting tool wanting to bend slightly into the work toward the headstock. Actually switched to an older phase II holder that already had a tool, in it, worked fine. Thought it must have been the tool that was the problem, or lack of ridgity in the compound or the like. Never occured to me that it might be the tool holder! I'll try the shim and see if it makes a difference.
