Hitachi Wj200 Error Message
Fltenwheeler
Jun 29, 2016
16
Hi
I am using a Hitachi WJ200-015SF as a phase converter to run a Rockwell 14x30 lathe.
I have the out put of the VFD set to 60Hz and am using the speed control that is built into the lathe. When I slow the lathe down from the upper speeds I get an E07.3 error code. Over voltage protection on the DC bus voltage. Is there any way to stop this from happening?
Thanks
Tim
Yup, add a braking resistor, or increase the decel time.
A quick internet search indicates that a 50 ohm is the correct value. 300 watts should be OK.
