Have a friend with a Mdl # MV-445-DPM 111 welder, the ops manual says it will work with most,if not all modern feeders---He has a Lincoln LN-7 feeder, but the situation is that the connection on the welder is a pin type, and the LN-7 is a terminal type, and I was checking to see if anyone knows of a converter attachment that would make this an easy hook up, I'm envisioning a device that will have terminal connections that can be bolted/screwed to a conventional pin type to plug in to the welder.
Any help, info or advise will be appreciated.
olcopper
olcopper
