- Aug 29, 2016
- 838
So far I've only run it 460 and whatever the next step up is. As long as I stay within the design limits, I don't see a problem. The issue will be if I can't get it slow enough to turn a large object.
The driven pulley is fixed. The drive pulley has a large internal spring, the belt tension wedges it open. Adjust the motor down, the pulley opens, and you get a lower ratio. But I have to get the motor off the floor before I can try more.
This seems to be what I have, if a bit shinier.
http://www.speedselector.com/
http://www.speedselector.com/engineering/index.htm
