- Apr 11, 2017
- 74
For high heat try Brazil but oil.If you want an excellent oil for cooking then peanut oil is very good.
If stir frying then a good splash of peanut oil with a generous dash of sesame oil.
Its takes a high heat and tastes excellent. .
I suggest a half dollar size dollop in a cast iron skillet and your favorite blackened ahi...
When i worked in Hawaii back in the 90's, I was told by a canuck client from Edmonton way, they developed the oil for tanks back in the second WW.Charles, I asked the question of which oil to use in jest. However, you do bring up a good point. There are basically two types of canola oil. In this case, one would use the food grade. The industrial grade contains erucic acid, not good for human consumption. In fact, out here where a lot of canola is raised, the farmers are very careful on not raising the two types next to each other. By the way, rape seed came from the Latin word rapum which means turnip.
Grew it there as a strategic reserve.
