Results 1 to 21 of 21
Thread: Repairing a bearing shaft
  1. #1
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    (0% Positive Feedback)
    It has come time to make a permanent repair on my mill head (last discussed here http://www.hobby-machinist.com/showthread.php?t=3949). I have the head disassembled as I make additional enhancements, including the addition of a spindle encoder and a switch-over from variable speed reeves drive (which is worn, no replacement parts available) to a fixed pulley belt drive.
    The good news is that the JB weld has held up for over a year. Now I have to clean up the old repair to make room for the new one. I want to either build up the area with brazing rid and machine to size, or machine down, and press on a sleeve. I'd like some advice from the more experienced folks. The "shaft" is only about 50mm long, and 50mm in diameter. If I go with a sleeve, is that something I make myself? What material? Is it just a press fit, or do I braze/solder it on? If I build up the area with braze, how concerned do I need to be about distortion?
    Oh yeah, the shaft is cast iron.
    Thanks in advance.
    Matt
  2. #2
    Global Moderator terrywerm's Avatar
    Join Date
    Oct 2012
    City
    Jordan
    State
    Minnesota
    Country
    United States
    Posts
    1,103
    Tickets
    0
    Post Thanks / Like
    Chats
    219
    Total Downloaded
    0
    My Feedback
    Re: Repairing a bearing shaft
    Due to the small size of the shaft, I would try brazing the bad spot, then either machine it down, or maybe even just take it down with a file. If the bearing that slides on to the shaft is a good snug fit, brazing should hold up just fine, and I doubt that distortion would be a problem as you will not be getting the shaft as hot as you would with arc welding, not to mention that the heat of brazing will tend to affect a larger area, and over a longer period of time.
    Sleeving the shaft may be the ideal solution, but may be overkill for this application. A sleeve could be made from DOM (Drawn Over Mandrel) tubing which would not have a weld joint running longitudinally down the tube. Sleeves like that are generally shrunk on by cooling the shaft and heating the sleeve, then pressing the two together. Once the temperature equalizes the two will be nearly inseparable.
    One other thing to consider: if you braze first, sleeving is still an option later on down the road should your brazing repair not be sufficient.
    Just my $.02 worth.
    Wermie
    Don't take life too seriously - no one gets out alive!
    Making chips with old machines- Keller 5HD power hacksaw, Logan 210 lathe, Clausing 8520 mill.
  3. #3
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    Thanks Terry.
    I can't take any material down with a file, the shaft is recessed inside a larger piece, so material would have to be removed on the lathe or mill with a single point tool that can get in there. I only have small torches (2 propane units). I have done silver brazing with them; think they would be enough to braze with bronze filler?
  4. #4
    Join Date
    Oct 2012
    City
    Jordan
    State
    Minnesota
    Country
    United States
    Posts
    1,103
    Tickets
    0
    Post Thanks / Like
    Chats
    219
    Total Downloaded
    0
    My Feedback
    Getting enough heat out of a small propane torch for brazing might be a little tough, but if the part is small enough it might just work, especially if you have managed to silver solder with those torches in the past. I guess there is only one way to find out, right??
    Machining inside that recess and getting the diameter correct may be a little difficult, but is certainly not impossible. Probably just have to sneak up on it.
    Wermie
  5. #5
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    I'll give it a try this afternoon. If I need more heat, I recall seeing something in an issue of ... about building a charcoal brazier for this kind of work....
  6. #6
    Brass
    Join Date
    Dec 2012
    City
    Monterrey
    State
    Nuevo Leon
    Country
    Mexico
    Posts
    235
    Tickets
    0
    Post Thanks / Like
    Chats
    80
    Total Downloaded
    0
    My Feedback
    50 mm are over 2". I would go for the sleeve. A friend rebuilds the screws of Ice machines at waltmart, he uses sleeves he makes out of pipe and preses fit them with .005 interference. No heat, and when they are worn again, he just re machines to remove the old sleeve.
    regards
  7. #7
    Brass
    Join Date
    Oct 2012
    City
    Greensboro
    State
    North Carolina
    Country
    United States
    Posts
    166
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I just made some sleeves for an old surface grinder I bought. I used oil impregnated bronze for the material in case you go that route. It's good where you have little or no oiling.
  8. #8
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    @Syaminab:
    How thick is the wall of the sleeves your friend uses? The part I am working on doesn't have a lot of material to work with, I'm wondering how thin of a sleeve I could get away with. I'm gonna try to build up some material with braze metal because I have that in hand now (and now steel in the right size), but if that doesn't work, I'd like to have another option.
    @Phils69:
    This is a bearing shaft that accepts a 50mm ball bearing (6010 series) so I don't think oilite will work, at least I'd be too worried I would destroy it when I press the bearing on. I'll have to post some pics, the part in question is kind of an odd shape.
    Gonna head into the shop and turn down to fresh metal, then I'll see how much heat I can generate...
  9. #9
    Dismissed
    Join Date
    Nov 2011
    Posts
    1,459
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Matt,
    Repair of worn shafts is common in industry and there are ready made sleeves available. Check with your local bearing supplier and ask for shaft repair or shaft wear sleeves. They are simply a thin metal sleeve with a flange on one end and are driven onto the shaft with a tool (simply a collar that fits over the sleeve). Trying to heat a shaft that size enough to braze or silver solder it may do more harm than good.
    Tom
  10. #10
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,653
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    It would seem that the best approach would be to disassemble the machine to get to the shaft itself with good access to the surface needing repair, then truing it up with the idea of putting a sleeve in place. You should leave the sleeve oversize on the OD until you have it in place securely, whatever means you use, then if at all possible, turn it true between centers back to proper size to fit an original bearing.
    "A man who works with his hands is a laborer. A man who works with his hands and his brain is a craftsman. A man who works with his hands, his brain and his heart is an artist."
    -Louis Nizer
  11. #11
    In Memory GaryK's Avatar
    Join Date
    Dec 2012
    City
    Tyler
    State
    Texas
    Country
    United States
    Posts
    494
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I repaired some shafts from the gearbox of a SB13 a while ago and just turned down the original shaft pressed some sleeves one.
    Then turned it down to the correct diameter. Worked great.
    From the picture of the bushing you get the idea that they really needed fixing.
  12. #12
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    Well, brazing was a no go. I had two torches (1 propane, 1 MAP) on it and after 20 minutes I managed to attach 1 glob of braze. I just can't generate enough heat unless I build some sort of oven out of fire bricks... and for that I need more fire bricks.
    So lets talk about that sleeve. How thin can I get away with? I have about 0.160" total wall thickness on the shaft, and there is a key in it. I have attached a pic of what I am working with.
    The large cone shaped piece is the one that needs repair. In this photo I have the piece pressed onto it's mating shaft (the end of which has the toothed pulley and dog clutch on the end) and mounted in the 4 jaw chuck of the monarch so that I could keep things concentric. When I took this picture, I had just finished cleaning up the surface.
    Because the piece I am working on is pressed onto another shaft, it is hollow in the middle, so I don't have much material to remove... which is why I am wondering about minimum thickness on the sleeve.
    In any case, I am going to grab some DOM tubing to try out. If anybody can advise me on minimum thickness, that would be appreciated. Currently the shaft is about 0.080" under size, so I am hoping that 0.040" wall thickness will do...
    I also realized that this thing is going to be impossible to measure with a micrometer, so I need to make some go-no-go gauges? Or is there a simpler way?
    Attached Images Attached Images
  13. #13
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,653
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    0.040 wall will be just fine. I'm not quite getting why you cannot work directly on the piece needing sleeved. Or even if you had to make a dummy shaft to run it on, a capture spud or something.
    -Louis Nizer
  14. #14
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    Here are a few more pictures to get an idea of the whole thing. The part I am working on is the lower pulley on the spindle side of the variable speed drive. It also serves as the brake drum for the spindle brake, and the "shaft" I am repairing supports the main bearing on this portion of the drive train.
    The first pic shows the underside of the pulley, at this point I had turned down the shaft (maybe "boss" would be a better description?) to clean metal.
    The second pic shows the shaft this piece mounts to. The bottom portion is a toothed pulley that runs the back gears. I had the pulley pressed on to this to hold it in the lathe.
    The third pic shows the bearing and the piece the bearing fits inside. This whole assembly gets pressed onto the pulley, and then the pulley gets pressed onto the shaft in picture 2.
    The fourth pic shows all the pieces as they go together.
  15. #15
    Brass
    Join Date
    Dec 2012
    City
    Monterrey
    State
    Nuevo Leon
    Country
    Mexico
    Posts
    235
    Tickets
    0
    Post Thanks / Like
    Chats
    80
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by DMS View Post
    @Syaminab:
    @Phils69:
    He is using what we call size 80 tube, which is oversized to be driven in the shaft, then he remachines to final size. Size 80 means a seamless tube that holds 80 kg/cm2 pressure as working pressure.
  16. #16
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,653
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    OK, I get the picture now. Since you have already trued up that surface, no need to remove more material. I see two options readily. One easier than the other. I'll describe the one I would probably do. If you can get an accurate measurement of that diameter, simply make a bushing to light press into the bearing bore, with a bit of 680 Loctite. This bushing would need to be an accurately sized piece that would light press onto the pulley also. You don't want to crush the pulley at all, so be careful with the measurements. Turn, bore and part off in a single chucking so you maintain concentricity.
    The other method would be to bore a close fit sleeve for the pulley and again, close but no crush, Loctite it on and then machine it in place to fit the bearing. There is no need for a strong interference fit anywhere in this.
    -Louis Nizer
  17. #17
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    I think I will go for the second method you describe, as the datum that the bearing pushes against axially also needs truing up. I ordered some DOM tubing, and I'll see if I can track down some 680 loctite. I guess until then I'll figure out how I'm going to measure things with sufficient accuracy.
  18. #18
    Global Moderator swatson144's Avatar
    Join Date
    Apr 2012
    City
    Norfolk
    State
    Virginia
    Country
    United States
    Posts
    590
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Measurement is easy. Give it your best read and if you don't like the fit compensate and make another. DOM is fairly inexpensive.
    Usually you can come out right on just by averaging hard to measure areas if you don't have the exact measuring instrument needed. I'd find something nearly the same size and mic it then measure it with calipers and then measure the calipers. It looks like you may be able to fit a set of dial/digi calipers in there. If not just use a plain old fashioned set of friction calipers, just measure several times until you have a warm fuzzy feeling.
    You are just looking for a very light press fit or even a snug slip fit. Just make sure the sleeve isn't warm when you test fit as it may get captive 1/2 way on. There isn't very much difference in size to a shrink fit. I did that sleeving a motor shaft "yep that seems about right...Aught oooh NO"
    Steve
  19. #19
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    I realized this morning that I don't have to be dead on for the ID on the sleeve, because the loctite will take up the slack, but when I finish up the diameter for the bearing, I think I am going to need a light - medium press fit, correct? I'm thinking 0.0005-0.0010 over size on the boss. I can get calipers in there, but I don't trust them to that degree of accuracy. I was thinking that I can just leave the sleeve long while I turn it, so I have something to measure, and then once I have the diameter right, face to length.
  20. #20
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,465
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    Machined the sleeve, turned up an mandrel, and the sleeve is mounted with the adhesive drying. It's about 1" oversize on the length so I can have something to measure. I'll try to finish it up tomorrow.
  21. #21
    Cast Iron bvd1940's Avatar
    Join Date
    Oct 2011
    City
    Blackfoot
    State
    Idaho
    Country
    United States
    Posts
    537
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by Tony Wells View Post
    +1 on this fix, we did it for years and usually made a shrink fit with heat with a bit oversize to true it up.
    Just my 2 cents worth but what do I know
    Bill in SE Idaho, Given enough incentive and proper motivation anything can be fixed
Similar Threads
  1. felt grade for Cataract spindle bearing and bearing covers?
    By jklett in forum HARDINGE, GORTON, RUSNOK & BENCHMASTER
    Last Post: 08-01-13, 12:30 PM
  2. Best Material For Shaft Running In Bronze Sleeve Bearing?
    By CluelessNewB in forum ATLAS & CRAFTSMAN MACHINES
    Last Post: 04-19-13, 06:48 PM
  3. Logan 825 bearing & Bearing cap Question
    By joebiplane in forum SHELDON, LOGAN & ROCKWELL MACHINES
    Last Post: 04-07-13, 09:58 PM
  4. repairing bearing race mating surface on shafts and in bores
    By JOSHUAZ2 in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-24-13, 11:17 AM
  5. Cleaning a Ball bearing headstock bearing
    By Kevinb71 in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 12-04-12, 10:26 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
