Results 1 to 4 of 4
Thread: X2 Mill CNC Conversion
  1. #1
    Chips
    Join Date
    Mar 2011
    Posts
    3
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    Well I finally got it all together and have even used it to make parts to complete the project.
    The first change I make was to redesign the Z axis drive. I started with "Hoss" plans and made a few changes that allow me to adjust a nyloc nut for pre-loading the bearings in the
    Z drive. Relocating the drive from the side was a major improvement from the CNCFusion kit I bought. You can see the gib screws are now easy to get to and make adjustments.
    I did two things to the base as suggested in many other sites and that was to replace the dish
    washer with a chunk of 5/8" steel plate and second I added adjustment screws on each side
    of the columb to "Fine Tune" vertical tram. Both were great improvements.
    Next were the wiring junction boxes made for each stepper. The mill carved out pre-cut 1/2"
    aluminum plate and later machined out the cover plates from a sheet of .060" aluminum. You can see the finished products in front view. Each box has a slot milled out of the back on one
    end that fits over the rubber gromet in the stepper motor. The box is epoxied on. The cover
    sheet I made the cuts from is still mounted on the table where they were cut from.
    Finally, I replaced the factory control panel with a much larger NEMA 1 panel. That panel
    now houses the original control plus the new power supply and G540 controller. There is
    room for relays if I want to start/stop the spindle motor.
    John Buckwalter
    Attached Images Attached Images
  2. #2
    e44sp
    Guest
    Re: X2 Mill CNC Conversion
    sweet
  3. #3
    Chips
    Join Date
    Mar 2011
    Posts
    3
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    The X & Y's were a cake walk to convert with the CNCFusion kit. The Z axis was a little different story. I installed the CNCFusion parts that I got with their kit but I was very unhappy with it. First it installed over the top of the gib screws which made it imposible to adjust them without removing the whole thing. Second it put a side load on the head since it was mounted on the left side of the head.
    That being said, I set out to find plans for the Z. Hoss machine had pretty much what I wanted so I made a few changes and started making chips. I suffered from a self inflicted headache when I picked up a round of scrap Stainless at my local surplus store to start with. Hard does not even begin to tell the story. I would guess it took me 8 hours and I don't want to tell you how much tooling I destroyed. But I got it made. The rest went much smoother.
    A few years back I built a CNC Plasma/Router table so I had the computer and software which made the conversion easy. I have a bridgeport but wanted this for making small parts that have lots of curves so I don't have to set up a rotary table.
    In any event I am getting ready to tackle some steel parts. I hope the mill is up to it.
    John
  4. #4
    Chips
    Join Date
    Mar 2011
    Posts
    3
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    The steppers are 280 oz NEMA 23 dual shaft 8 wire. They are wired bipolar series connection. The power supply is 48VDC @ 12.5 amp which drives the Gecko G540 controller. BTW the G540 is perfect in this aplication. I do not have the E-stop wired up yet but I brought it out to a terminal strip in the control panel. Once the mill is mounted on a solid base I will mount and wire the E-stop.
    I also have limit switches to install and wire back to the control panel. I am pretty sure that I can drive the speed control directly from the G540 and the start/stop. Which means my Mach 3 will set the correct speed for each tool and of course start/stop at each tool change. So much to do so little time!!
    I will take more pic and post later.
    John
Similar Threads
  1. X2 Mini Mill CNC Conversion?
    By MGP in forum CNC IN THE HOME SHOP -- DISCUSS USING CNC IN YOUR HOME SHOP HERE!
    Last Post: 04-05-14, 09:20 AM
  2. Which Tabletop CNC Mill to machine CNC conversion
    By angelfj1 in forum CNC IN THE HOME SHOP -- DISCUSS USING CNC IN YOUR HOME SHOP HERE!
    Last Post: 02-17-14, 08:24 PM
  3. My new (to me) Bridgeport MILL w/CNC conversion
    By Kennyd in forum BRIDGEPORT & B'PORT CLONES
    Last Post: 11-03-11, 07:34 PM
  4. My new (to me) Bridgeport MILL w/CNC conversion
    By Kennyd in forum OTHER BRANDS OF MACHINERY
  5. X2 Mill CNC Conversion
    By flsteam in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 04-03-11, 10:40 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
