Results 1 to 4 of 4
Thread: High Frequency TIG Box
  1. #1
    Bronze Uglydog's Avatar
    Join Date
    Dec 2012
    City
    Dayton
    State
    Minnesota
    Country
    United States
    Posts
    474
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Total Downloaded
    363.8 KB
    My Feedback
    (0% Positive Feedback)
    I have a shot at multiple small aluminum repair jobs this summer if I am mobile.
    I decided that I should consider adding a Hi Frequency box to my 1980s Lincoln Weldn'Power AC/DC 225 (no CV Tap/MIG capability).
    I found an old Lincoln Hi Freq Box on Ebay that would likely work, and contacted Jeff Noland at HTP.
    Jeff has always been a reliable resource for consumables and torch replacements even though I don't own a HTP welder.
    We swapped some emails, he offered some ideas, then suggested I contact Lincoln Service Tech Dept to confirm it would all work.
    Yet another good experience.
    They confirmed Jeffs ideas would work well.
    Then they offered that while it would work. I should be aware that not only would it not pulse. But, it wouldn't have Balance control.
    I knew about the pulse. I hadn't considered that it wouldn't give me Balance.
    Balance control is critical for Aluminum. As it provides control over the cleaning and welding phases of the sine waves.
    I've decided not to make the investment.
    Instead I'll be saving for a used mobile unit with TIG and MIG.
    This was a good learning adventure, and am once again in debt to HTP (Jeff) and Lincoln.
  2. #2
    Global Moderator Rbeckett's Avatar
    Join Date
    Sep 2010
    City
    Bronson
    State
    Florida
    Country
    United States
    Posts
    2,750
    Tickets
    0
    Post Thanks / Like
    Chats
    390
    Total Downloaded
    0
    My Feedback
    Re: High Frequency TIG Box
    The machine you were bui;ding would work, But be extremely limited. You definately made the best decision to wait. Even though I tend to frown on imports the Everlast 256 has been favorably reviewed by some pro users. Depending on your thickness requirements you could also look at the Diversion line from Miller, The Predision Tigs rom Lincoln and the EZ from Hovart. I assume you would also be looking at the HTP's from Jeff. I just missed a 301 demo a while back on Ebay for a song. Remember .001=1 amp as a general rule of thumb on thickness, so if you want to do 1/4 you will need at least 250 amps. At higher amp ranges you should also consider a water cooler to extend your duty cycle in consumables and coo; the hot torch. Trust me it gets really hot after a while welding. The used market should yeild some of the smaller machines soon due to users becoming frustrated. Tiggin Alli does require a lot of practice to get good at it, so dont get discouraged when your first welds don;t turn out as you expect. It comes with time and practice.
    Bob
    If you don't have something positive to say, keep it to yourself it makes you look so much smarter.
    Life Resolution--NEVER let my shop get cluttered again....EVER!!!!!
  3. #3
    Tungsten Carbide xalky's Avatar
    Join Date
    Jun 2012
    City
    Naugatuck
    State
    Connecticut
    Country
    United States
    Posts
    1,967
    Tickets
    0
    Post Thanks / Like
    Chats
    9
    Total Downloaded
    0
    My Feedback
    I just put in an order for an Everlast 250EX tig welder that has all the bells and whistles. http://www.ebay.com/itm/221177766629...84.m1497.l2649 This welder has a lot of happy customers and has been around for awhile with a proven track record.
    I too was looking at adding a High frequency box to my Lincoln Idealarc Dc250 Cv/Vv , but after some research i realized how limited i would be. It makes no sense to invest money into something you know you won't be happy with.
    I had a Longevity Multipurpose ac/dc 250 amp machine that did tig, stick and plasma cut. It tigged really well and it plasma cut well. I had to sell it because the HF emissions on the plasma were ruining my cnc electronics on my CNC plasma table. I would have kept it had it not been that i was short on cash and i needed to get a Hypertherm for the plasma table.
    So depending on what you want to do, if your looking to have a plasma cutter too, one of those multiprocess machines would be good.
    Jeff at HTP is very knowledgeable, he set me up with a spool gun for my Lincoln Mig and it has worked really well. I'm now able to mig weld aluminum on my mig.
    Maybe i could help you out with your selection process.
    Bridgeport Milling Machine w/DRO and Powerfeed
    Nardini 1440s lathe
    Ikegai A20 20x40 lathe
    DoAll DH612 hydraulic surface Grinder
    Lincoln Idealarc DC250 with LN7 wire feeder, and spool gun
    Hypertherm Powermax85 with Machine and hand torch
    4x5 CNC plasma cutting table (shop made)
    Devilbiss 6.5hp 80gal 175psi 2 stage compressor
    HF blast Cabinet modified for foot pedal operation better gun.
    Hand and power tools up the wazoo.
    The name's "Marcel".
  4. #4
    Join Date
    Dec 2012
    City
    Dayton
    State
    Minnesota
    Country
    United States
    Posts
    474
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Total Downloaded
    363.8 KB
    My Feedback
    Quote Originally Posted by xalky View Post
    I run a Lincoln Precision TIG 225. I've had great luck with it. Had a walk in Friday to repair an aluminum snow mobile trailer. It's been work hardening since 1998. The deep cleaning AC mode worked exceptionally well in the tight spots could get a SS brush into.
    Jeff has suggested better options for tungsten selection, and got me into a longer torch hose at a hot price. Yeah, I've been drooling over one of his plasma cutters. I've even consider attempting to convert my 1940s Linde track torch away from propane to plasma. To solve my mobile TIG problem he has suggested I look at one of his lighter TIG units and plug it into my WeldnPower.
    One day at a time...
Similar Threads
  1. Some Voltage and Frequency Lathe Questions
    By Matabele in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 11-26-13, 07:28 PM
  2. high frequency add-on for AC tig?
    By Inflight in forum WELDING & CASTING
    Last Post: 11-12-13, 09:25 PM
  3. Motor "singing" (high frequency noise) using VFD
    By itsme_Bernie in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 04-17-13, 12:30 AM
  4. [Newbie] Looking for high-precision, high-speed mill
    By Photon in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 11-01-12, 04:07 PM
  5. High Frequency arc Stabilizer
    By Hawkeye in forum WELDING & CASTING
    Last Post: 12-19-11, 12:03 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
