Results 1 to 15 of 15
Thread: Mach3 and the spindle control
  1. #1
    Chips
    Join Date
    Jan 2013
    City
    Sandton
    State
    Outside US / Canada
    Country
    South Africa
    Posts
    12
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    All the info I have gathered regarding mill conversions, lathe conversions, building a home CNC machine etc.. All describes controlling 3 or 4 axes using Mach 3 or similar software driving stepper motors and ball screws. I am really not finding answers about the detail on the spindle itself, which I would assume is the most important aspect of any machine. Videos on YouTube all demonstrate the steppers for x, y, and a axes, but nothing for the spindle.
    initially I was of the impression that one could use a stepper motor for a spindle drive...although now I am no longer convinced.( I am talking for a milling machine or lathe specifically) engravers or routers is definitely not a consideration.
    now I am trying to decide whether it is better to use a DC motor with controller or an AC motor with a VFD. If going for the AC option then does one still control the spindle speed with Mach 3 or manually on the VFD?
    I have ordered a Nema34 stepper from China which I will use to try and drive a spindle with, but will change to AC with VFD if this is really unsuccessful. Once I have a spindle built I will carry on with the rest of the machine.
    i guess I am going to build a machine around the spindle arrangement.
    just waiting for the Chinese New Year to be over then hopefully I will get my first few goodies to start playing with.
    i would appreciate comments on this....
    thanks
    Rob
  2. #2
    Aluminum
    Join Date
    Sep 2011
    City
    Hiram
    State
    Georgia
    Country
    United States
    Posts
    70
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Re: Mach3 and the spindle control
    Your spindle can certainly be controlled by Mach. The choice in spindle motor would be more dependant on machine size and what your work will be. DC motor with a speed control is one option, 3 phase motor with VFD is another. I don't think you will have much luck using a stepper for a spindle motor as it looses it torque at higher speeds. It's primary job is to position and then reposition.
    Treadmill motors have been the latest fad for spindle motors, plenty of information out there on them. They can be had pretty cheap and torque is not an issue. Any speed control that can accept 0-10 Volt input can be controlled via Mach.
    If you can provide us with more machine information I am sure someone will be able to suggest a path to follow based on experience and help get it running too. Most of the hobby machines have been modified to increase rpm and decrease noise using a belt drive replacing the built in gear heads.
    Chris
  3. #3
    Global Moderator Rbeckett's Avatar
    Join Date
    Sep 2010
    City
    Bronson
    State
    Florida
    Country
    United States
    Posts
    2,641
    Tickets
    0
    Post Thanks / Like
    Chats
    368
    Total Downloaded
    0
    My Feedback
    Steve (Jumps5) may be able to help you get this figgered out. He has converted a couple of machines to CNC and uses Mach 3, Give him a shout and explain the issue you are having and he may be able to help you fix it right quick and pretty easilly. Hope this jelps get you going.
    Bob
    If you don't have something positive to say, keep it to yourself it makes you look so much smarter.
    Life Resolution--NEVER let my shop get cluttered again....EVER!!!!!
  4. #4
    Brass
    Join Date
    Feb 2013
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    177
    Tickets
    0
    Post Thanks / Like
    Chats
    46
    Total Downloaded
    0
    My Feedback
    If you're doing a conversion on a G0704 (BF20, etc etc) - the motor controller in that is very easy to convert to Mach control.
    You can get a board from (really hope I'm not violating rules by dropping company names!) CNC4PC.
    I've got the C6 board,and it ties right onto the existing speed control. It interfaces with Mach, and you have direct control.
    They have other similar solutions for different applications too.
  5. #5
    Brass fretsman's Avatar
    Join Date
    Feb 2013
    City
    Central Pa
    State
    Pennsylvania
    Country
    United States
    Posts
    131
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by Dr.Fiero View Post
    Hi, any chance you could be a little more specific with the connection of the C6 board to the existing controller? I have a G0704 that I will be eventually CNC'ing and would love to know the details on this.
    Thanks for your time and info-
    Dave
  6. #6
    Chips
    Join Date
    Jan 2013
    City
    Sandton
    State
    Outside US / Canada
    Country
    South Africa
    Posts
    12
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Thanks for the input so far.....essentially I want to build a machine to get some experience with computer control. The machine to be built will compliment my existing lathe, an optimum 280 x 700 vario. This is driven with a 1.5kW motor with a VFD. If I get the mill right then I will possibly look into upgrading the lathe as well to CNC. I will look out for a treadmill motor on eBay. Although not many of the sellers ship to South Africa, and to buy something here is going to be quite expensive. I'm sure I will find something soon.
  7. #7
    Brass
    Join Date
    Feb 2013
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    177
    Tickets
    0
    Post Thanks / Like
    Chats
    46
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by fretsman View Post
    Hi, any chance you could be a little more specific with the connection of the C6 board to the existing controller? -
    Dave
    While trying not to hijack the thread...
    http://cnc4pc.com/Tech_Docs/C6R6_User_Manual.pdf
    It's pretty easy when you see the drawing -- and you know how a picture says a thousand words.
  8. #8
    Join Date
    Feb 2013
    City
    Central Pa
    State
    Pennsylvania
    Country
    United States
    Posts
    131
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    Ok, thanks for the info-
    Dave
  9. #9
    Chips
    Join Date
    Jan 2013
    City
    Sandton
    State
    Outside US / Canada
    Country
    South Africa
    Posts
    12
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    After watching ebay for a few days I ended up buying this..
    http://www.ebay.com/itm/360596501176...84.m1439.l2649
    It is only 660W but might be more in line with what I have in mind and it was only $9.99 plus $60 for postage. Now I have to figure out what I need to drive the motor, and whether I can get something reasonably cheaply off ebay as well.
    I see there is a web site http://www.automationtechnologiesinc.com that deals in these motors for CNC and offer a motor controller, if I can't find something slightly more affordable.
    I will possibly use the Nema 34 stepper to drive the z-axis. this motor is quite heavy at 4 kg's
    Any suggestions on an alternative speed controller... thanks
  10. #10
    Brass
    Join Date
    Feb 2013
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    177
    Tickets
    0
    Post Thanks / Like
    Chats
    46
    Total Downloaded
    0
    My Feedback
    You weren't planning on using this motor as a spindle drive were you?
    It's a stepper.
  11. #11
    Chips
    Join Date
    Jan 2013
    City
    Sandton
    State
    Outside US / Canada
    Country
    South Africa
    Posts
    12
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Thanks, I see that now...I will have to see what I can find along the lines of an AC motor with VFD, like the treadmill motors suggested earlier. I guess a 2 Hp at least. I see these treadmill motors come with flywheels. I guess it would be best to run the spindle without the flywheel.
  12. #12
    Brass
    Join Date
    Feb 2013
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    177
    Tickets
    0
    Post Thanks / Like
    Chats
    46
    Total Downloaded
    0
    My Feedback
    The flywheel is for rotational mass. Helps the motor stay at a steady speed as the user picks up and puts down their feet, and pushes along.
    I think you'd tend to get dizzy otherwise from the constant speed change!
    This:
    http://www.ebay.ca/itm/CNC-0-3KW-Spi...item3cccfd81ef
    is a motor I was looking at. DC, 3K-12K speed. Even comes with a bracket! Guy has a much larger one too.
    Then check CNC4PC.com for an appropriate controller to let MACH do the speed.
  13. #13
    Chips
    Join Date
    Jan 2013
    City
    Sandton
    State
    Outside US / Canada
    Country
    South Africa
    Posts
    12
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    That motor looks great although I'm looking for something to use to mill mild steel and not quite so fine. This includes facing and making keyways and boring. I don't think I need such high speed and such fine tooling. My spindle should have an Er25 or even Er32 collet. I am thinking of using a belt drive to increase the torque and reduce the spindle speed. I think with mild steel the max speed should be 1000 rpm or even less? Turning mild steel on the lathe is never at more than 450 - 500 rpm.
    i guess the treadmill motor is still the best option.
  14. #14
    Chips
    Join Date
    Jan 2013
    City
    Sandton
    State
    Outside US / Canada
    Country
    South Africa
    Posts
    12
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Have a look at this thread,http://m.youtube.com/#/watch?feature=g-user-u&v=b2-Kdud7eiA
    Here Simpsons36 is using a stepper motor to drive his 4 th axis, see how we'll the stepper motor works turning the spindle at a reasonably high speed.
    This is where I initially got the idea to use a stepper to drive the spindle. Mine arrived today from china. I will try hook it up and drive a similar spindle as simpsons36.
    I guess it is a better option as a 4th axis as the stepper function is primarily for indexing.
    it will be interesting to find out how to have the drive and indexing options as in the video. This is where I think it will become difficult to control in Mach 3.
  15. #15
    Aluminum
    Join Date
    Sep 2011
    City
    Hiram
    State
    Georgia
    Country
    United States
    Posts
    70
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by MTBcrazy View Post
    HHere Simpsons36 is using a stepper motor to drive his 4 th axis
    Simpson uses a servo motor for his 4th axis. A servo is much different in this application and I don't think a stepper would perform well. I have been watching Simpson and his wokr over the years.
    Chris
Similar Threads
  1. Engraving with MACH3
    By MGP in forum CNC IN THE HOME SHOP -- DISCUSS USING CNC IN YOUR HOME SHOP HERE!
    Last Post: 04-09-14, 10:56 PM
  2. PM-45M-CNC Setup and Configuration with Mach3
    By Boswell in forum CNC IN THE HOME SHOP -- DISCUSS USING CNC IN YOUR HOME SHOP HERE!
    Last Post: 03-08-14, 10:08 AM
  3. Help - explain this spindle brake control on my LC-18VS mill (bridgeport "clone")
    By CanFire in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 08-23-13, 01:29 AM
  4. Put Mach3
    By OakRidgeGuy in forum CNC IN THE HOME SHOP -- DISCUSS USING CNC IN YOUR HOME SHOP HERE!
    Last Post: 12-06-12, 10:02 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
