Results 1 to 14 of 14
Thread: Stupid Plastic Back-ordered G0704 Gear!
  1. #1
    Brass Smudgemo's Avatar
    Join Date
    Nov 2012
    City
    People's Republic of Berkeley
    State
    California
    Country
    United States
    Posts
    197
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Anyone know of a supplier not named Grizzly that might have a 37t gear for my mill? (Part #209 in the drawing.) I made a mistake, crashed the cutter and the gear sheared some teeth. Sacrificial, for sure.
    I don't mind paying the $10 for my mistake, but they have been back-ordered since at least mid-Feb, and I just got a card saying no known stock date is in sight. I suppose it's strange, but I'd like to use this thing at least occasionally. Anybody selling clones I can check with?
    Thanks,
    Ryan
    My Flickr album.
  2. #2
    Brass
    Join Date
    Feb 2013
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    176
    Tickets
    0
    Post Thanks / Like
    Chats
    46
    Re: Stupid Plastic Back-ordered G0704 Gear!
    Try contacting King Industrial In Canada here. Same machine.. Different name.
    http://www.kingcanada.com/Products.htm?CD=36&ID=21355
  3. #3
    Cast Iron
    Join Date
    Feb 2013
    City
    Mason
    State
    Iowa
    Country
    United States
    Posts
    547
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    This may or may not help when I worked in a machine shop it was cheaper to buy the gears from Browning then it was to make them. A place that sold bearings had one of there catalogs and you could match up any gear and sometimes with only slight machine work. You could buy these gears made out of several different metals I never tried to buy a plastic one but if there are other plastic ones there a metal one would still work fine.. Ray
  4. #4
    Join Date
    Nov 2012
    City
    State
    California
    Country
    United States
    Posts
    197
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thank you, both. I emailed Quality Machine Tools and he's got some showing up in a few days that should fit, but might not. Just in case, if anyone else has another suggestion, please let me know.
    I need to look into the belt-drive mod one of these day.
    -Ryan
    My Flickr album.
  5. #5
    Join Date
    Nov 2012
    City
    State
    California
    Country
    United States
    Posts
    197
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by shawn View Post
    Is it a metric or standard gear? I have a set of module 1 gear cutters as well as a partial set of diametral pitch cutters, on the off chance that I have the right one to cut the gear I would be happy to make it for you, or at least try?
    Shawn
    That would be pretty cool, Shawn. It's probably metric, but gears are only theory to me at this point. If I had a dividing head I'd give it a go with the Benchmaster, but I haven't gotten far along enough yet to build one.
    If you want to check out the measurements I do have, go here. And I can measure whatever else is needed, but don't make too much of an effort. They are only $10 replacements and I can get things done w/ the BM until they are in stock.
    Thanks,
    -Ryan
    My Flickr album.
  6. #6
    Plastic
    Join Date
    Mar 2013
    City
    La Jolla
    State
    California
    Country
    United States
    Posts
    21
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Shawn
    The gear is metric, module looks to be 1.25, and it is helical with an odd angle. I've searched and searched for a replacement (while I've had two on back order from Grizzly for months). Does someone know: why not replace both gears with a metal non-helical set? What is the real advantage of the helical gear in this application?
    bix
  7. #7
    Tool Steel Richard King's Avatar
    Join Date
    Jul 2012
    City
    Cottage Grove
    State
    Minnesota
    Country
    United States
    Posts
    1,425
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Back in the old days... pre 1970's, some of the cheaper American and European made machines had sheer pins and soft key so you would sheer a pin or a key before break a gear. If I were you guys, I would examine your gear train and see if you can install a soft key or pin so next time you crash you don't break a gear. The foreign mfg copied a machine and did not know or understand this concept I bet. A plastic gear...hmmmm maybe buy a plastic key....
    If any of you fish it's the same idea of a old outboard motor. The prop used a brass sheer pin so you didn't break a prop when you hit a rock..
  8. #8
    Brass road's Avatar
    Join Date
    Mar 2013
    City
    Hamilton
    State
    Ontario
    Country
    Canada
    Posts
    132
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    did you try busy bee tool in Canada ?
    their CX600 mill is the same unit. even the same part # 209
    The worth of our lives comes not in what we do or who we know,
    but by WHO WE ARE.
    UNKNOWN
  9. #9
    Tool Steel pdentrem's Avatar
    Join Date
    Jan 2011
    City
    Niagara Region South
    State
    Ontario
    Country
    Canada
    Posts
    1,300
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Back in time when people still believed in magic, I made molds using body filler. Used for making plastic parts as well as for low temperature metal alloys, even lead soldiers where the detail needed to be well cast.
    If you made a 3 piece mold you could make a new epoxy fiber reinforced gear. You can also use silicone to make a pliable mold to allow you to pop it out a bit easier.
    Use hot glue to rebuild the damaged teeth etc. naturally it is a bit of work but if a gear is too far out time wise or expensive, this is an option.
    Pierre
    Never enough toys is bad but too much government is worst!
  10. #10
    Copper kd4gij's Avatar
    Join Date
    Feb 2011
    City
    St. Petersburg
    State
    Florida
    Country
    United States
    Posts
    822
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by bix View Post
    bix
    Check out G0704.com Hoss did replace the gears with spur gears.
    Craftsman 101 12x36, Grizzly G704, Emerson-Craftsman Radial armsaw & table saw.
  11. #11
    Brass
    Join Date
    Dec 2012
    City
    London
    State
    UK
    Country
    Great Britain
    Posts
    138
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    bix
    Have you ever driven a car with a strait cut gear box? , they sound awsome :-) you can generaly hear the difference between helical and strait gears by shifting into reverse on your car gear box.
    Stuart
  12. #12
    Brass
    Join Date
    Feb 2013
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    176
    Tickets
    0
    Post Thanks / Like
    Chats
    46
    Not sure if you ever tried King Canada, but... that #209 in the book for my machine is:
    #6400202090 Gear $43.95
  13. #13
    Brass fretsman's Avatar
    Join Date
    Feb 2013
    City
    Central Pa
    State
    Pennsylvania
    Country
    United States
    Posts
    130
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Quote Originally Posted by Dr.Fiero View Post
    I actually tried to contact them with 3 different emails and no response at all.
    Not sure what the issue is there.
    Dave
  14. #14
    Join Date
    Nov 2012
    City
    State
    California
    Country
    United States
    Posts
    197
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thanks Shawn, but I contacted Grizzly again and must have figured out the secret password because they decided I had a warranty issue and I think they pulled a gear from a new machine to send to me. I haven't gotten it yet, but I got an email saying it was coming via Brown Santa on Monday. I told them to keep my the other two on order because I don't intend to be without again. Hopefully they show up so I don't worry every time I use the machine. I don't have anything to properly cut gears, but it seems like the Benchmaster would be ideal for that sort of thing.
    -Ryan
    My Flickr album.
Similar Threads
  1. Ordered Grizzly G0704 Mill
    By Paradox123 in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 03-19-14, 11:22 PM
  2. plastic gear for Enco 9x19 or Grizzly 4000
    By Vavet in forum JET, ENCO & RONG FU IMPORTS
    Last Post: 01-20-14, 07:36 PM
  3. Back gear pin
    By psychodelicdan in forum ATLAS & CRAFTSMAN MACHINES
    Last Post: 03-28-13, 09:22 PM
  4. Plastic Gears in the G0704
    By Wheels17 in forum GRIZZLY, BUSY BEE, HARBOR FREIGHT & CENTRAL MACHINERY
    Last Post: 03-14-13, 10:21 PM
  5. G0704 plastic gear shredded
    By cg 2005 in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 10-15-12, 06:22 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
