Results 1 to 9 of 9
Thread: 6x12 surface grinder purchase?
  1. #1
    Plastic
    Join Date
    Aug 2011
    City
    Bismarck
    State
    North Dakota
    Country
    United States
    Posts
    49
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    I have a chance to pickup a DoAll 6x12 manual surface grinder for my home shop and I wonder if anyone has experience with this brand and if it is a good tool for the home hobbyist. I have just started working in the machining hobby, being a long time woodworker and furniture maker. I want the machine mainly for trueing up surfaces etc and not so much for sharpening. The machine has some use and for the price I am wondering if I am making a wise investment. I can get the machine for $500.00 but I have to go about 400 miles to pick it up.
    Please if you can, give a an honest appraisal for its purchase. Thanks
    Skipd1
  2. #2
    Bronze Pacer's Avatar
    Join Date
    Apr 2011
    City
    Greenwood
    State
    NW La
    Country
    United States
    Posts
    443
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Re: 6x12 surface grinder purchase?
    Just my 2 cents but --- A surface grinder in the "average" home shop is very seldom used/needed. My mentor/friend has a KO lee and rarely uses it. I cant recall ever really needing one in my shop. Then you have the very real problem of buying one and the wear will be enough to negate the very precision that is needed in use of a surface grinder, along with the usual missing parts. The wear will be in the table ways and screws with both requiring skill - and expense - to repair, and parts can be scarce and pricey when found, all of which can be hard to justify the limited use gained from one, unlike a lathe or mill.
  3. #3
    Titanium Ray C's Avatar
    Join Date
    Nov 2012
    City
    Crofton
    State
    Maryland
    Country
    United States
    Posts
    4,846
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    I have a 6-18 SG (B&S) and was apprehensive about getting it but two things changed my mind. 1) It was in very good condition and cost $500 and 2) I recall that much, if not most of my father's tool & die projects started with a mill or lathe and were completed with a surface grinder.
    Guess what? About 1/2 of my personal, pet projects start as pieces in the lathe and/or mill -and the true accuracy and precision happen at the last steps on the surface grinder.
    As for that particular one... Don't know. DoAll seems to be pretty common and it looks pretty solid. The parts on mine are fairly easy to see/understand and I could make anything on it if I wanted to. If the ways need to be scraped, that could cost some money... Lot's of folks are willing to shell-out good money for rusty, worn lathes and some of them are worth reconditioning... My guess is that a SG rebuild will cost about as much as a lathe refurb and just like a lathe, might need way scraping.
    Ray
    ...and a rock feels no pain; and an island never cries.
    www.cmf-llc.com
  4. #4
    Cast Iron bvd1940's Avatar
    Join Date
    Oct 2011
    City
    Blackfoot
    State
    Idaho
    Country
    United States
    Posts
    538
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    If you like precision and purddy work you will use it a lot, but ifin you want fast a dirty job you wont. I finally broke down and bought a Rockwell tool & surface grinder and it aint much in the world of surface grinders but I love it and its simplicity ( and precision)
    Just my 2 cents worth
    Bill in SE Idaho, Given enough incentive and proper motivation anything can be fixed
  5. #5
    Bronze fastback's Avatar
    Join Date
    Jan 2013
    City
    Attleboro
    State
    Massachusetts
    Country
    United States
    Posts
    360
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I have a Freeport surface grinder and use it more that I thought I would. Mine is a 6 x 18 and I may try using it for sharpening my 15 inch wood planer blades.
    So to answer your question I think that having one available is a good thing. Don't know about their surface grinders, but DoAll has been around for a long time and made a lot of good equipment.
  6. #6
    Bronze
    Join Date
    Mar 2013
    City
    Genoa
    State
    Illinois
    Country
    United States
    Posts
    453
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    3.67 MB
    My Feedback
    I don't know what your location is...that seems to make a big difference in the value of used machines. I'm guessing if your going to drive that far for a sg, you must be in an area where uses machines are not plentiful. In my area, 500 for a used, in good condition 612 manual surface grinder would be about top dollar. If the spindle bearings are worn....it's scrap...and there isn't a lot of scrap value in it. It is a nice machine to have available like the others have said, but I can somtimes go months without using mine.
    Chuck
  7. #7
    Aluminum Professor's Avatar
    Join Date
    Jan 2012
    City
    Natick
    State
    Massachusetts
    Country
    United States
    Posts
    55
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I paid only $110 for mine (a Reid 2B) but it did need a LOT of cleanup. The ways were straight and the spindle could be adjusted to run true. As George says, if the spindle is shot, you don't have anything. If you can, run a test piece on it first to see if it will produce a smooth surface (shiny isn't as important, smooth and consistent is).
    I got mine to sharpen planer and chipper/shredder blades. Like an i-pad, you find a lot of other "apps" for it, once it's yours. I don't use it often but when I do, it's nice to have. You do need space for it and a place to put it (or some good dust control) so the grinding dust won't wreck your other machines.
    Atlas 10F lathe, Southbend Model A lathe
    Bridgeport J-head mill, Reid 2B Surface grinder
    An original ShopSmith 10ER
    Plus various support equipment (drill press, band saws, welder, etc.)
  8. #8
    Aluminum twowheelinjim's Avatar
    Join Date
    Aug 2012
    City
    Greensboro
    State
    North Carolina
    Country
    United States
    Posts
    57
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Hi, I was just looking around here and stumbled on your post. I recently sold my surface grinder that I purchased 5 or 6 years ago. The funny thing is, I needed it only hours after it left my shop. As I remember I purchased it for a few reasons, one was the need to precisely fit some parts together and grinding was the way to get this done. Second the price price was right. Third, it was located less than 3 miles from my house. In retrospect, I spent more money on extra arbors, wheels, wiring, and the tools associated with the surface grinder than the actual purchase of the surface grinder. In the first months I used it frequently enough to get surface grinder elbow on the left arm. The only thing fun about that was watching the kids get sea sick from watching the table go back and forth. As time passed, I used it less frequently until I almost never used it at all. I have a very limited space in my shop and reluctantly decided to sell it. I needed the space for a CNC mill I had an opportunity to get but the deal fell through about a week after I sold the grinder. That's the story of my life in a nutshell.
  9. #9
    Join Date
    Nov 2012
    City
    Crofton
    State
    Maryland
    Country
    United States
    Posts
    4,846
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    That's a bummer...
    Truth be known, mine is one of the lesser used items in the shop. -Probably only 1-2 times a month but, when it's needed, it serves a great purpose and it adds a new level of fit and finish to some types of projects. BTW: I made a couple grand when I got my hands on 5-6 old/abused magnetic chucks and rebuilt them. The final touch was to true-up the bottoms and top. They sold on eBay like hotcakes. Couldn't do it w/o the SG and it paid for itself in that 1 week.
    Ray
    Quote Originally Posted by twowheelinjim View Post
    www.cmf-llc.com
Similar Threads
  1. Newb Q. surface grinder -vs- Cinnci #2 Grinder for a budding home shop?
    By countryguy in forum OTHER BRANDS OF MACHINERY
    Last Post: 07-20-14, 02:19 PM
  2. Bad Surface Grinder Surface
    By Charley Davidson in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 04-29-14, 04:00 PM
  3. Surface Grinder
    By LJP in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-03-14, 08:38 AM
  4. B&S #2 Surface Grinder
    By Ray C in forum WELLS-INDEX, TREE, RIVETT & B&S MACHINES
    Last Post: 07-25-13, 10:39 PM
  5. Harig 6X12 Surface Grinder
    By Charley Davidson in forum ANTIQUE, VINTAGE, & OTHER TYPES OF MACHINERY
    Last Post: 04-21-13, 11:55 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
