Results 1 to 2 of 2
Thread: How to calculate lathe speeds and feeds?
  1. #1
    Titanium Nels's Avatar
    Join Date
    Sep 2010
    City
    Queens
    State
    New York
    Country
    United States
    Posts
    5,230
    Tickets
    0
    Post Thanks / Like
    Chats
    156
    Hey Guys,
    In Darrell Holland's video on Lathes, he gives a formula for calculating speeds and feeds. I believe it is:
    SFPM X 4 divided by diameter = RPM
    SFPM is surface speed per minute in feet this is the speed your cutter is cutting at, whether it is a milling cutter or a lathe bit contacting the revolving work, or a shaper bit, or planer, or a grinding wheel. Feed rates are termed in inches per minute.
    Others have said that with High Speed Steel they use 50 sfpm to start with, and then work up, especially with mystery material. This way it is easy to figure also, 200rpm for 1.00 dia. so 2"=100rpm 1/2=400rpm 1/8=1600rpm. Staring at this low surface speed saves drill bits, I have seen people burn up big bits, this formula is easy to figure in your head and avoids problems.
    As to feed rates, he mentions that it depends on size and power of the lathe and how good a finish you need.
    How do YOU calculate speeds and feeds on a typical home shop lathe?
    Thanks,
    Nelson
  2. #2
    Brass
    Join Date
    Apr 2011
    City
    Delta
    State
    British Columbia
    Country
    Canada
    Posts
    218
    Tickets
    0
    Post Thanks / Like
    Chats
    30
    Re: How to calculate lathe speeds and feeds?
    Top speed on my SB9A is only 650rpm so I guess I'll be a little slow for small diameters
Similar Threads
  1. Spindle speeds/rpm of the Atlas 12" lathe
    By chevydyl in forum ATLAS & CRAFTSMAN MACHINES
    Last Post: 08-04-13, 03:51 AM
  2. Lathe turning speeds and feed rates using carbide cutters
    By Pmedic828 in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-23-13, 11:42 PM
  3. How to calculate the RPMs and Speeds using as slitting saw on a mill?
    By Nels in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 10-08-11, 09:23 AM
  4. Table of Recommended Cutting Speeds & Feeds
    Last Post: 11-26-10, 03:21 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
