Results 1 to 2 of 2
Thread: Best Material For Shaft Running In Bronze Sleeve Bearing?
  1. #1
    Brass
    Join Date
    Mar 2013
    City
    Gorham
    State
    Maine
    Country
    United States
    Posts
    246
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    I starting back work on my Atlas MF mill. The jack shaft that rides on two bronze bushings will need replacement along with the two bushings. It's a simple 5/8" shaft with a few milled flats. What would be the best material to use for a replacement shaft?
    Thanks!
  2. #2
    Brass twstoerzinger's Avatar
    Join Date
    Nov 2012
    City
    Inver Grove Heights
    State
    Minnesota
    Country
    United States
    Posts
    160
    Tickets
    0
    Post Thanks / Like
    Chats
    21
    Total Downloaded
    0
    My Feedback
    Re: Best Material For Shaft Running In Bronze Sleeve Bearing?
    AISI 1045 steel is commonly used for drive shafting. It is readily available, low cost and fairly easy to machine. It has the toughness required for drive shaft use. There are many other alloys used, but for the jack shaft on a small lathe, I recommend 1045.
    If the shaft will run directly in the bronze bushings, then the shaft needs to be well finished where it runs in the bearings. 1045 cold drawn rounds are available TGP (turned ground and polished) so you don't have to do the finishing yourself. All you need to do is cut to length and machine the flats. One source that I have used is Discount Steel http://discountsteel.com They are happy to deal retail and to ship small orders. Otherwise, check with any steel supplier in your area.
    Terry S.
Similar Threads
  1. Bearing bronze question
    By Jimmy in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 03-03-14, 12:08 PM
  2. Material for puller shaft
    By Kevinb71 in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 01-27-14, 07:21 PM
  3. sleeve shaft on planer
    By maineshops in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 11-18-13, 09:53 AM
  4. Is There A Sleeve Bearing Atlas 6" (Not Craftsman)?
    By wa5cab in forum ATLAS & CRAFTSMAN MACHINES
    Last Post: 06-19-13, 07:25 PM
  5. Repairing a bearing shaft
    By DMS in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-11-13, 09:31 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
