Results 1 to 2 of 2
Thread: How to adjust a Brown and Sharpe mic
  1. #1
    Cast Iron ome's Avatar
    Join Date
    May 2013
    City
    Freeport
    State
    New York
    Country
    United States
    Posts
    509
    Tickets
    0
    Post Thanks / Like
    Chats
    19
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    How to adjust a Brown and Sharpe 0-1" mic
    Hi,
    I am new to metalworking, and have 2 Brown and Sharpe 0-1" micrometers.
    how to adjust these micrometers?
    Thanks,
    Jon
  2. #2
    Chips
    Join Date
    Jun 2013
    City
    Tulsa
    State
    Oklahoma
    Country
    United States
    Posts
    4
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Re: How to adjust a Brown and Sharpe mic
    One rotation per thimble equals .025. The hash marks of a micrometer are in 25/50/75 and the graduations (0-9) are ten thousands.
    If you was to measure a .250 drill shank it should read .2495 minimum. On the graduation the closet line determines the final measurement. In many circumstances you'll see almost 7 and not quite 8 on the graduations and read as 8(.0008). Round up because that cmm will make your tools seem like crap.
    A micrometer is not a c-clamp
    Edit:
    There small hole at the base of the stem. Grab the neasest adjustment wrench and prey feel is king. close the mic without clamping. adjust the stem according to you current pressure on zero. back off the stem then run it back to the fixed position to check again. Adjust accordingly. You won't mess it up. Its all relative but that doesn't mean half ass adjust it. Take your time and make sure it is zero and read 0.0 with 1" standard. Assuming you are using 1-2" mic.
    If you are using 0-1 mic you can drill rod, joe block because most 0-1 standards get lost. Most standards get lost anyways, find something that is consistent .0002-.0003 deviation.
    I'm sorry for my response because I misread your question.
Similar Threads
  1. How would one use a Brown and Sharpe #559?
    By itsme_Bernie in forum METROLOGY - MEASURE, SETUP & FIT
    Last Post: 10-29-13, 10:56 AM
  2. Brown & Sharpe #2 plain mill Help
    By Douglas in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 06-15-13, 09:46 AM
  3. Brown and Sharpe Mill
    By JEM in forum ANTIQUE, VINTAGE, & OTHER TYPES OF MACHINERY
    Last Post: 03-14-13, 08:33 AM
  4. Brown & Sharpe 2A Horizontal Mill
    By Old Iron in forum WELLS-INDEX, TREE, RIVETT & B&S MACHINES
    Last Post: 07-01-12, 03:45 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
