Results 1 to 20 of 20
Thread: Manually milling an arc without a rotary table
  1. #1
    Plastic
    Join Date
    Jan 2013
    City
    Kensington
    State
    Maryland
    Country
    United States
    Posts
    34
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    After thinking about it for a while, doing some maths, and doing some checks, I think I have a method to manually machine an arc on a mil without using a rotary table. I would appreciate it if someone would look to see if I missed something or not:
    http://benchtopmachineshop.blogspot....nual-mill.html
  2. #2
    Titanium Ray C's Avatar
    Join Date
    Nov 2012
    City
    Crofton
    State
    Maryland
    Country
    United States
    Posts
    4,822
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    Re: Manually milling an arc without a rotary table
    I guess I don't quite follow along with multiplying the half-degree by X or Y... Any chance you could express it as a formula? The standard formula for a cricle centered about the origin (or arbitrary datum) is r2 = x2 + y2 for which x and y can be solved as x = SQRT(r2 - y2) and y = SQRT(r2 - x2).
    Either way, the issue is granularity. Making discrete adjustments of the hand crank will give you a bunch of zig-zag steps.
    Also, I'm not sure who your audience is but, someone could come along an nit-pick the daylights out of you over the term "arc" instead of sphere or hemi-sphere in this particual context -unless of course, the metod produces an arc -but I don't think so because at quick glace of the table, the numeric pattern is symmetric.
    Ray
    Quote Originally Posted by Zoltan View Post
    ...and a rock feels no pain; and an island never cries.
    www.cmf-llc.com
  3. #3
    Dismissed
    Join Date
    Nov 2011
    Posts
    1,459
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    That is precisely the way a CNC mill works and it will get the job done if the steps are small enough and you have enough patience. I once had to mill a .012" square hole in a piece of brass shim for an optical application. I used a .005" diameter end mill and worked under a microscope to see what was going on. The individual steps were very apparent at that level. Obviously a larger end mill will make the steps less apparent. I think I would get looking for a rotary table though, it's gonna take a lot of time to create an arc with that technique.
    Tom
  4. #4
    Aluminum
    Join Date
    Jan 2012
    City
    San Diego
    State
    California
    Country
    United States
    Posts
    61
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Zoltan
    Post deleted
  5. #5
    Copper davidh's Avatar
    Join Date
    Jan 2012
    City
    Maple (near Superior / Duluth)
    State
    Wisconsin
    Country
    United States
    Posts
    764
    Tickets
    0
    Post Thanks / Like
    Chats
    20
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    5
    I tried a few times and found that its very nerve wracking. . . . just one little "ohs##t" turning the crank the wrong direction and pooof ! "murphy" follows me around most days. . .
  6. #6
    Aluminum
    Join Date
    Jan 2012
    City
    San Diego
    State
    California
    Country
    United States
    Posts
    61
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Zoltan
    Assuming a 10.0000 circumference (diameter?) it would seem that I would move 5.000 in the x axis and 5.0000 in the y axis to complete 90 degrees. That would be 180 steps in your spreadsheet. Have I misinterpreted anything?
    Gene
  7. #7
    Bronze
    Join Date
    May 2013
    City
    Medfield
    State
    Massachusetts
    Country
    United States
    Posts
    288
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    1
    What type material will the arc be cut into, and how thick will it be? Will the finished arc be on the outside edge of the piece? Or, is it inide of a square piece? As a cabinetmaker, many methods come to mind. Rough out the piece on a band saw. Swing the arc, with a pivot point against an edge sander. I have made very accurate parts that way. A lot depends on the material.
    Larry
  8. #8
    Bronze
    Join Date
    Jan 2012
    City
    Marysville
    State
    Ohio
    Country
    United States
    Posts
    377
    Tickets
    0
    Post Thanks / Like
    Chats
    13
    Total Downloaded
    0
    My Feedback
    yes that will work, but man, thats alot of work).
  9. #9
    Bronze
    Join Date
    May 2013
    City
    Medfield
    State
    Massachusetts
    Country
    United States
    Posts
    288
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    1
    It is a lot of work. Might not be bad in 1/2" aluminum. But 3/4" steel is another story!
  10. #10
    Plastic
    Join Date
    Jan 2013
    City
    Kensington
    State
    Maryland
    Country
    United States
    Posts
    34
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by easymike29 View Post
    Zoltan
    Gene
    If you're doing 90* of a 10 diameter circle, then yes, you'd move a total of 5 in the X axis and 5 in the Y axis in a total of 180 steps.
  11. #11
    Aluminum
    Join Date
    Jan 2012
    City
    San Diego
    State
    California
    Country
    United States
    Posts
    61
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    OK. Where do I find that in your spreadsheet? I must be missing something.
    Gene
  12. #12
    Bronze
    Join Date
    Feb 2013
    City
    Perth
    State
    Ontario
    Country
    Canada
    Posts
    310
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I once manually milled my then house numbers 2158 in a fairly fancy font out of 1/2x5 x14" brass. It was time consuming and wasn't quite prefect, but it was pretty close. I pebbled the background inside the border and darkened it with gun blue and polished the foreground and lacquered the works. It can be done.
    Michael
  13. #13
    Plastic
    Join Date
    Jan 2013
    City
    Kensington
    State
    Maryland
    Country
    United States
    Posts
    34
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Gene
    If you enter in a circumference of 31.415 (the circumference of a circle with diameter 10) then your X (column A) and Y (column B) movement for 90* sums to 5 and 5.
  14. #14
    Cast Iron Kennyd's Avatar
    Join Date
    May 2011
    City
    Westminster
    State
    Maryland
    Country
    United States
    Posts
    531
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    What machine do you have? I have a 6" Phase II Rotab I can make you a deal on!
    More Projects in my Picasa Album: https://picasaweb.google.com/kdeckster/
  15. #15
    Tool Steel GK1918's Avatar
    Join Date
    Nov 2010
    City
    No. Dighton
    State
    Massachusetts
    Country
    United States
    Posts
    1,331
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    167.45 MB
    My Feedback
    An arc, with no math just a sharpie like this
    Attached Images Attached Images
  16. #16
    Aluminum
    Join Date
    Jan 2012
    City
    San Diego
    State
    California
    Country
    United States
    Posts
    61
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Understood, thank you.
    Gene
  17. #17
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    There are all sorts of formulas to describe circles. I just have one question:
    Is a circle a polygon?
    "A man who works with his hands is a laborer. A man who works with his hands and his brain is a craftsman. A man who works with his hands, his brain and his heart is an artist."
    -Louis Nizer
  18. #18
    Aluminum
    Join Date
    Jan 2013
    City
    Portage
    State
    kevin
    Country
    United States
    Posts
    71
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I tried something similar on my 7x12 lathe - the method does work, but you have to careful do it in a way that does not allow for cumulative errors. My lathe does not have DROs, so this was a problem for me. On a mill with DROs I think this method would work just fine, but it takes a long time and it's easy to make a mistake. On the other hand, sometimes you just have to work with what you have, and that's part of what makes hobby machining a fun challenge.
    For a successful technology, reality must take precedence over public relations, for nature cannot be fooled. - Richard Feynman .. Visit my website!: https://sites.google.com/site/lagadoacademy/home
  19. #19
    Brass
    Join Date
    Jan 2013
    City
    Mt. Croghan
    State
    South Carolina
    Country
    United States
    Posts
    183
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I've made bearing races b4 on the lathe. i turned a piece of stock to the same diameter as my outer race. Then i set up an indicator on my cross slide and had this piece on the ways. Like a tracer.It worked very well, dont see why you couldnt do the same on the mill. These were bearing caps and i was cutting the concave inside of them to fit a radial ball on a shaft. Same as the inside of an outer race on a ball bearing. Never tried it on the mill but im sure it would work. No math involved just hand feeding and keeping your eyes on the indicator
  20. #20
    Brass
    Join Date
    Jun 2012
    City
    warsaw
    State
    Indiana
    Country
    United States
    Posts
    240
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I remember doing a few impromptu jobs, without having access to a rotary table.
    Hog/Bandsaw, them out to your line, then use a 2-3 foot cheater bar to (feed/finish), the rest of the cuts...only taking off a few thousandths at a time.
    As long as you don't slip.
    A slip up could be disastrous. And, a destroyed workpiece.
    I know some pieces were at least 3/4" thick steel.
Similar Threads
  1. rotary table
    By SWARFEATER in forum SHOP-MADE TOOLING
    Last Post: 07-10-14, 12:27 PM
  2. Replies: 10
    Last Post: 11-16-12, 11:51 AM
  3. Rotary Table or Rotary Table and Dividing plates?
    By 7HC in forum MACHINE ACCESSORIES
    Last Post: 07-22-12, 01:08 AM
  4. Rotary Table or Rotary Table and Dividing plates?
    By 7HC in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
