Results 1 to 21 of 21
Thread: Sharpen and Hone Carbide Tooling
  1. #1
    Tungsten Carbide itsme_Bernie's Avatar
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    OzzModz Classifieds
    2
    Hey HM Folks!
    I would like to set myself up to lightly reshape carbide tools, to the proper tip geometry, and hone them to a fine edge. I do believe that carbide serves some purposes and certain situations in the home shop.
    Between a grinder wheel or a honing station of some kind, I would like to be able to make use of all this Carbide I have. (If this has already been covered here, please point me toward the thread
    I have a 6 inch Baldor 500 Tool Grinder, and I thought I would set up one wheel to cut Carbide tools, and keep the other wheel for HSS.
    Does anyone out there have experience sharpening carbide?
    What do you guys do with your carbide? Diamond wheel? Hone?
    If you use diamond, what grit you use?
    Any wheels that have served you well?
    Do you have any suggestions for vendors? I like McMaster, but $$$!!
    McMaster has them for $160 to $200 D8 !!
    http://www.mcmaster.com/#diamond-gri...wheels/=osw8yu
    After seeing Nelson's old post sharing Conrad Hoffman's page, I thought that a Diamond wheel (with ??? Grit?) would allow me to lightly reshape, and then I should hone the edge with a fixture like Conrad Hoffman (web page below)?
    http://www.hobby-machinist.com/showt...Conrad-Hoffman
    Is a Diamond wheel my best choice?
    Questions questions questions!!!!
    Thanks for your help guys!
    Bernie
    Bernie
    Let's help each other with similar machines! Here's what I got:
    South Bend Heavy 10 Lathe -1965
    Hardinge TM Horizontal Mill - 1949 -- with RUSNOK ST Milling Head
    Sheldon 0 Mill -- with RUSNOK Model 70 Vertical Milling Head- 1955
    Sheldon 12 Inch Shaper
    Walker Turner 20 in Floor Drill Press 1100 -1950
    Hand-I-Hack Lipe Rollway Corp - 1950
  2. #2
    Cast Iron
    Join Date
    Mar 2013
    City
    Clarksville
    State
    Indiana
    Country
    United States
    Posts
    619
    Tickets
    0
    Post Thanks / Like
    Chats
    19
    Total Downloaded
    0
    My Feedback
    Re: Sharpen and Hone Carbide Tooling
    Quote Originally Posted by itsme_Bernie View Post
    Hey HM Folks!
    Bernie
    The last time I resharpen or reshaped cemented carbide tooling was in a job shop. I recall using a cup shaped wheel. I don't think I honed my bits, its been to long ago. They always had a dedicated grinder for carbide tooling.
  3. #3
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    2
    Thanks Bill
    I just don't know the first practical thing about what grit wheel I would really need, or whether I even need a two-step process of grinding then honing, or just a proper grit wheel and start working.
    Bernie
    Bernie
  4. #4
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    2
    I also have been reading people discussing CBN wheels. Does anyone have experience with those?
    Bernie
    Bernie
  5. #5
    Chips
    Join Date
    May 2013
    City
    Solvang
    State
    California
    Country
    United States
    Posts
    9
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I decided a while ago that I wanted to sharpen HSS and maybe carbide. My grinder has a 6" green wheel and a 6" diamond coated aluminum wheel. Since I am a rookie at this I decided to not spend much money. The cheapest diamond wheel was a lapidary wheel (I think it is 600 grit, sorry it was a while ago and I do not remember where I got it; it was a web purchase and i think it was around $70). I have used this for a couple of years with some success.
    The limitation to this wheel is that all the grit is on the outside diameter. There is no face; . This is a picture of a similar wheel I found on Ebay. Without a face you cannot get a flat surface, Every grind will be slightly concave. Other than that, it works well. It cuts carbide easily and leaves a nice finish. The diamond coating on mine is starting to wear thin and I will have to replace it shortly. I suspect that if this is something that you will use a lot, it may not last long enough.
    I hope this helps.
  6. #6
    Moderator
    Join Date
    Jul 2012
    City
    Thorold
    State
    Ontario
    Country
    Canada
    Posts
    46
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    The only CBN (cubic boron nitrate BTW) and diamond wheels I've ever used were on a cylindrical or surface grinder, I've never seen one used for free hand grinding though I don't see why it wouldn't work. They aren't meant for rapid metal removal,only a few tenths at a time. They have an aluminium alloy core and a layer about 1/2 inch thick or so of grit around the outside. They are very expensive, but if used properly will last many years.
    A simpler and less expensive choice for grinding carbide is to buy silicon carbide wheels. They are green in colour and can probably be found in your local hardware store. They tend to leave a rough surface so the carbide should be honed with a diamond lap to finish. The laps have a plastic backing that come in different colours to denote the grade. The diamond is embedded in a nickel plate stuck on the plastic. They last a long time, I have a few that I've been using for over ten years.
    All of this only applies to brazed on carbide tool bits. Carbide inserts can be resharpened, but as far as I know, it takes special equipment to do properly.
    Hope this is of some use.
    Sandro Di Filippo
    Sent from my ME301T using Tapatalk 2
  7. #7
    Tool Steel
    Join Date
    Aug 2011
    City
    Santa Clara
    State
    California
    Country
    United States
    Posts
    1,475
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    69.4 KB
    My Feedback
    Diamond is usually used on non-ferrous alloys (tungsten carbide falls into that category). cBN is usually used why grinding ferrous alloys. It also tends to be more expensive. I have heard (and this has been backed up by my own experience) that green wheels leave a rough finish on carbide. Diamond leaves a much smoother finish. What I did with my carbide scraper blades was to use a green wheel for rough shaping, and then finish with diamond. Green wheels are cheaper in any case, so best to use them for bulk material removal.
  8. #8
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    2
    Thanks so much guys!
    I am pretty sure the wheels on it now are "green", since they are a light green color, so I may be good to go! One of the wheels is a little buggered up so it is a good excuse to replace the one anyway.
    The main reason for wanting to reshape the cemented carbide tools is to be able to correct all the boring bars with improper relief, and also be able to get more life out of the chipped cemented lathe tools. It would also be nice to put a small round the cutting tip to change the finish.
    Can I use the Green Silicon Carbide wheel on HSS as well as Carbide?
    Thanks so much for your help!
    Bernie
    Bernie
  9. #9
    Chips
    Join Date
    Aug 2012
    City
    York
    State
    Pennsylvania
    Country
    United States
    Posts
    8
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Get a face wheel, That is the diamond should be on the side of the wheel. The face wheel will work on your Baldor. Get one with as wide of a face as you can afford. 1/2 or 3/4 is better. 220 or 320 grit will work well as a roughing and finishing choice. You will not have to hone your tool. CBN is for Hi-speed tools only. Never use it on carbide. MSC or one of their competitors will have them under $100.
    50 years a Toolgrinder and proud of it.
  10. #10
    Chips
    Join Date
    Aug 2012
    City
    Needham
    State
    Massachusetts
    Country
    United States
    Posts
    11
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Talking Re: Sharpen and Hone Carbide Tooling
    Hi,
    My night for interesting posts, i guess. We use a lot of carbide, instead of HSS. Once you get a few diamond wheels, you never go back. It's great to work with. I got 2 wheels. One coarse and one very fine. Got them from a diamond tool company, nearby. Funny thing, they gave me a piece of molybdenum to dress the fine wheel with, when it's clogged up. They have 1/2" holes, so easy to mount on the bench lathes that we use. Also got some 6, 8, and 1,200 hand hones. They're about an inch long, double side taped to aluminum handles. I use water to hand hone with. If you use carbide ThinBits, and Nicole Mini System inserts, you can touch them up, unless they're TIN coated.
    I also bought a real old Baldor grinder, for a few $.000. It has diamond wheels on it. I never changed them, so i don't have a clue as to who made them, or what grit they are.
    http://www.ebay.com/itm/BALDOR-522-CARBIDE-TOOL-SHARPENER-BENCH-GRINDER-115-VOLT-1-PH-ELECTRIC-GRINDER-/111160733930?pt=LH_DefaultDomain_0&hash=item19e1b230ea
    Best,
    Payson.
    PS I also bought a fine wheel, and a cutoff wheel for the surface grinder.
  11. #11
    Aluminum barrydc1's Avatar
    Join Date
    Jan 2013
    City
    Dillon
    State
    Montana
    Country
    United States
    Posts
    91
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I don't know if your question has already been answered, but here is what I use. I do wish that they had a finer grit sometimes than the 220, but a light touch with 600 grit flat stone and it's ready to go. Here's the link: http://www.use-enco.com/CGI/INPDFF?P...PARTPG=INLMK32. Hope this helps.
  12. #12
    Aluminum
    Join Date
    Oct 2012
    City
    vallejo
    State
    California
    Country
    United States
    Posts
    81
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I use those Enco diamond wheels too. Work good for me.
    Charl
  13. #13
    Plastic
    Join Date
    Oct 2013
    City
    Houston
    State
    Texas
    Country
    United States
    Posts
    21
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    1
    Gents,
    The best thing I ever got from Harbour Freight was this saw sharpener:
    http://www.harborfreight.com/120-vol...ner-96687.html
    The key thing about it is that it runs relatively slowly! Just FYI, it is a brushed motor with a rectifier in the back end. It is slow enough that the diamonds don't diffuse into steel during cutting.
    What you need to do it swap to the diamond wheel, and cut a larger opening in the guard. Once you do that you have a great grinder that works on high speed steel, carbide, tungsten electrodes, etc. I use it all the time! I have it right next to the lathe and I regularly touch up tools (still in the toolholder). Here's where you cut the guard (I later opened it up more to the right). You can also modify the saw support into a decent tool rest. The grinding disc can be tilted relative to the table, so you can easily set your relief angles too.
  14. #14
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    2
    Quote Originally Posted by xman_charl View Post
    Charl
    Charl- thanks for your reply- what grit wheel do you use? And for what?
    I want to be able to lightly reshape, and sharpen most of the way...
    Bernie
    Bernie
  15. #15
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    2
    Quote Originally Posted by barrydc1 View Post
    Hey Barry
    Thanks for posting- very helpful.
    So you use the 220, and hone with the 600 stone?
    Do you find you could grind badly-formed heels off of boring bars with the 220, or is it too fine to reshape?
    Bernie
    Bernie
  16. #16
    Global Moderator Rbeckett's Avatar
    Join Date
    Sep 2010
    City
    Bronson
    State
    Florida
    Country
    United States
    Posts
    2,642
    Tickets
    0
    Post Thanks / Like
    Chats
    368
    Total Downloaded
    0
    My Feedback
    Just a quick note. CBN will not grind carbide. It will do a great job on HSS, but will not touch carbide at all. If you use CBN you just wasted the price of that wheel. I use the Pink wheels with very good results and they are much cheaper and wear a long time even when sharpening tungsten's for my tig. HTH
    Bob
    If you don't have something positive to say, keep it to yourself it makes you look so much smarter.
    Life Resolution--NEVER let my shop get cluttered again....EVER!!!!!
  17. #17
    Cast Iron pineyfolks's Avatar
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    570
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I just use the green wheels, 120 grit. I found using a dremel with a diamond tool works great for making chip breakers.
    Bill
  18. #18
    Brass savarin's Avatar
    Join Date
    Aug 2012
    City
    Townsville
    State
    Queensland
    Country
    Australia
    Posts
    234
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    This may be of use
    http://www.shell-lap.com.au/shelllap...ond%20Discs%22
    I would suspect there are similar providers in the states.
    Asian 9x20, some rusty files and a hammer
  19. #19
    Steel kd4gij's Avatar
    Join Date
    Feb 2011
    City
    St. Petersburg
    State
    Florida
    Country
    United States
    Posts
    1,036
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    11.06 MB
    My Feedback
    I don't know the quality but CDCO has diamond wheels for $69.00
    http://www.cdcotools.com/ just go to machine tooling then grinding machine tooling.
    Craftsman 101 12x36, Grizzly G704, Emerson-Craftsman Radial armsaw & table saw.
  20. #20
    Aluminum
    Join Date
    Oct 2012
    City
    vallejo
    State
    California
    Country
    United States
    Posts
    81
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    http://www.harborfreight.com/120-vol...ner-96687.html I use it too...
    This is my enco diamond wheel on my harbor fright grinder. Have
    white wheel on other side for HSS junk.
    Charl
    Attached Images Attached Images
  21. #21
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,520
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    OzzModz Classifieds
    2
    Thanks so much for your help guys- I ordered a Silicon Carbide wheel from a local supplier, SpeedCut in Fairfield, NJ. I try to buy locally when I can.
    I did not mention any other searches or stores, and he gave me a good deal. I'll let you know when it is all hooked up and running!
    Bernie
    Bernie
Similar Threads
  1. When machining acetyl or Delrin, HSS or carbide tooling?
    By ome in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 05-04-14, 10:47 AM
  2. Sharpening HSS & Carbide tooling
    By GarageGuy in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 04-07-14, 08:32 AM
  3. Interchangeable carbide tooling?
    By Rbeckett in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 09-26-13, 09:18 PM
  4. Mr. Inquisitive would like to know . . . How to sharpen HS and carbide scraper blades
    By Mr. Inquisitive in forum MACHINE RESTORATION & WAY SCRAPING -- REBUILDING OLD MACHINES HERE!
    Last Post: 08-22-12, 12:17 PM
  5. Carbide insert tooling in ... situations
    By Nels in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 06-27-11, 07:00 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
