Results 1 to 6 of 6
Thread: Anyone broken the gear on the Grizzly mini-mill?
  1. #1
    Titanium Nels's Avatar
    Join Date
    Sep 2010
    City
    Queens
    State
    New York
    Country
    United States
    Posts
    5,247
    Tickets
    0
    Post Thanks / Like
    Chats
    160
    From what I have read, there is a "sacrificial' plastic gear under the plate the motor fixes to that breaks quite easily when the mill is under stress?
    Has anyone broken that and had to replace it with one from Little Machine Shop?
    Nelson
  2. #2
    Tool Steel Hawkeye's Avatar
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,407
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Re: Anyone broken the gear on the Grizzly mini-mill?
    If the Grizzly is the same as the HF X2, then it is the same as the one I have. The gear train exploded after a couple of years of faithful service. When I was looking for the LMS site, I found quite a bit of information on replacing the gears with a belt-drive system. There are kits available, but I have a shop, so I tend to make what I can.
    I had some aluminum plate in the scrap bin and picked up a sewing machine belt at a repair shop. This works so well, I'd recommend converting your mini-mill even if the gears haven't thrown chunks yet.
    Mike
    Mike
    Victoria U2 Mill w/ Vertical Head
    ZX25 Mill/Drill
    X2 CNC Mill
    Storebro Bruk Ornmaskiner 14 x 40 Lathe
    Hercus AR Lathe
    Louis 10" Shaper
    9 x 12 Horizontal Bandsaw
    Hobart Handler 140 MIG
    TIG / Plasma Cutter
  3. #3
    Bronze hq308's Avatar
    Join Date
    Jul 2011
    City
    Sydney
    State
    NSW
    Country
    Australia
    Posts
    254
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I broke one of the plastic gears on my X2 clone, the one thats connected to the change lever. To change it I had to take the head off the column, as you can only get to it from the back of the head. While I had it apart I also noted another plastic gear on the spindle as well as the one that runs directly off the motor, making it 3 plastic gears in total.
    I plan to do something similar to Hawkeye when my machining skills are a little better.
    Cheers
    David.
  4. #4
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,407
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I worked out dimensions suitable for space available, then kept checking ratios by math until UI thought it would work. It does. Not an original concept. Kits are available (not from me) if you don't have time to make your own. A quick search like "mini-mill belt drive" should find lots of references.
    Mike
  5. #5
    Join Date
    Jul 2011
    City
    Sydney
    State
    NSW
    Country
    Australia
    Posts
    254
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thanks Mike ::
    I am aware of the commercially available kits (Little Machine Shop is one that springs to mind) but without modifications they won't fit my mill as it's an upgraded version of the X2 with a bigger electronics box (not sure what else you'd call it) that gets in the way of the pivot for the new motor mount. I can move the box down but I have to do an air spring conversion first.
  6. #6
    Join Date
    Jul 2011
    City
    Sydney
    State
    NSW
    Country
    Australia
    Posts
    254
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Here's a couple of pics of the gears, the gear on the left is the one at the top of the gear change mechanism, the one in the middle is the one that is on the spindle and the one on the right (the one I broke ) goes on the gear selector shaft. The spindle gear and the selector gear are both inside the head, which needs to be removed from the column to access them.
    An this is what the broken gear looks like. :-[
    Cheers
    David.
Similar Threads
  1. Grizzly G8689 Mini-Mill capacity
    By MattM in forum GRIZZLY, BUSY BEE, HARBOR FREIGHT & CENTRAL MACHINERY
    Last Post: 11-19-12, 09:08 PM
  2. Grizzly G8689 Mini-Mill
    Last Post: 11-12-12, 05:08 AM
  3. Anyone broken the gear on the Grizzly mini-mill?
    By Nels in forum OTHER BRANDS OF MACHINERY
    Last Post: 10-02-11, 05:32 AM
  4. Removal and Replacement of the Grizzly Mini-mill Spindle Head Gears
    By Nels in forum GRIZZLY, BUSY BEE, HARBOR FREIGHT & CENTRAL MACHINERY
    Last Post: 02-09-11, 09:49 AM
  5. Removal and Replacement of the Grizzly Mini-mill Spindle Head Gears
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
