Results 1 to 6 of 6
Thread: DRO installation
  1. #1
    Aluminum
    Join Date
    Apr 2011
    Posts
    57
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    DRO installation
    Has anybody installed a DRO on their milling machine? I am considering a DRO-pros 2 axis on my Grizzly 0619 mill. It looks like something that I could do,but I would like to get some input from someone that has done it.
  2. #2
    Cast Iron Kennyd's Avatar
    Join Date
    May 2011
    City
    Westminster
    State
    Maryland
    Country
    United States
    Posts
    531
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Re: DRO installation
    I installed one on my lathe, and re-installed the one on my mill after I moved it. It's seems daunting at first, but it's really a easy job-just takes time to get everything lined up.
    More Projects in my Picasa Album: https://picasaweb.google.com/kdeckster/
  3. #3
    Plastic
    Join Date
    Mar 2011
    City
    Near Winnipeg
    State
    Manitoba
    Country
    Canada
    Posts
    36
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I bought a kit for my SX3 on ebay after seeing threads on other forums detailing the installation. The kit contained everything needed for the installation, but the instructions were not as good as they could have been.
    As it turned out there were no problems fitting the kit and I wouldn't ever want to be without it.
  4. #4
    Brass joebiplane's Avatar
    Join Date
    Nov 2010
    City
    Malaga
    State
    New Jersey
    Country
    United States
    Posts
    223
    Tickets
    0
    Post Thanks / Like
    Chats
    3
    Total Downloaded
    2.11 MB
    My Feedback
    OzzModz Classifieds
    2
    Quote Originally Posted by woodguy View Post
    Could you give us the seller of the kit you bought? and where the install article appeared? unlesss that would be an infringement... otherwise i would like to have it for my own SX# ( Griz 0619)
    joe
    Remember: Don't make old People mad.
    We don't like being old in the first place, so it doesn't take much to **** us off.
  5. #5
    Davo J
    Guest
    Hi,
    I have installed 2 sets on milling machines and one on a lathe, and I have the scales for both my shapers here to install it on them as well.
    I would recommend installing the X scale on the front of the table so you don't loose any travel. I did a right up a while ago here about installing it on the front.
    http://www.hobby-machinist.com/showt...3617&highlight=
    As for buying one, I bought 2 from Meister off ebay and the other from the Sino guy on ebay. Both have great customer service and arrive quick to your door. They are pretty well all the same, but are a lot cheaper than DRO Pro's, from memory the 2 axis is around $400 and the 3 axis is around $550. Over the years I have only heard one complaint which was a broken scale through postage which was from the Sino guy (which could happen to anyone) and it was replaced promptly.
    This Sino fellow will upgrade your scales to slim line for $20 an axis extra or up grade to 0.001 scale for $20 an axis extra.
    I highly recommend both these sellers.
    If your like most including me, it all seems high tech and a daunting task when buying your first one, but after you get one and install it you will see how simple they really are. The scales are very robust in construction and the cables come shielded from swarf and coolant. The main screen will come with a clear plastic protective cover on brands standard. I ordered an extra one with the Meister's, but have never needed it in 4 + years.
    I have had these running for 4-5 years and never had a problem. I am pretty sure they are all coming out the same factory, just with different names and screen layouts, so it is more about saving a few dollars when looking to buy one. The prices have come down a lot over the years, when I bought mine back then it cost me $2150 for the 2 X 3 axis Meister sets with 7 scales.
    Dave
  6. #6
    Davo J
    Guest
    I will just add, when installing the scales just remember to measure twice and drill once. The cast iron will drill easily, but make sure you have some metric taps and drill bits on hand as they get supplied with metric hardware.
    You will wonder how you ever lived without it once you have it installed and use it. I remember when I took my mill apart for cleaning and needed to mill something before the scales where re installed, I forgot how much trouble it was turning and counting hand wheels. LOL
    Dave
Similar Threads
  1. DRO Installation - Storebro Lathe
    By Hawkeye in forum METROLOGY - MEASURE, SETUP & FIT
    Last Post: 08-25-14, 10:59 PM
  2. DIY Nut Sert installation tool
    By acourtjester in forum MEMBERS PROJECTS
    Last Post: 01-18-14, 09:21 PM
  3. VFD installation
    By ecdez in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 03-28-13, 11:29 PM
  4. VFD installation
    By ecdez in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 03-11-13, 05:14 PM
  5. Craftex CX-601 Mill DRO Installation
    By bmw rider in forum GRIZZLY, BUSY BEE, HARBOR FREIGHT & CENTRAL MACHINERY
    Last Post: 12-26-12, 12:20 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
