Results 1 to 12 of 12
Thread: Anyone ever make a lift for drill press table? need ideas
  1. #1
    Cast Iron bvd1940's Avatar
    Join Date
    Oct 2011
    City
    Blackfoot
    State
    Idaho
    Country
    United States
    Posts
    518
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I have a drill press without a lifting mechanism, its a oldie but goodie Atlas floor drill press but its a pain to change height of table
    Anyone out there have any killer ideas for a retrofit?
    If you have one on your drill press a picture would be real nice
    Any input would be appreciated
    Bill in SE Idaho, Given enough incentive and proper motivation anything can be fixed
  2. #2
    Brass
    Join Date
    Oct 2011
    City
    Minneapolis
    State
    Minnesota
    Country
    United States
    Posts
    130
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Re: Anyone ever make a lift for drill press table? need ideas
    Looking at the results of a Google [is that actually a verb] for "drill press table lift" suggests that trailer jacks are popular ...
    http://www.harborfreight.com/catalog...q=trailer+jack
    http://home.comcast.net/~kvaughn65/drill_press_lift.jpg
    http://home.comcast.net/~kvaughn65/d...ress_lift2.jpg
    if you want a manual version and linear actuators ...
    http://www.surpluscenter.com/item.as...tname=electric
    if you are into push button convenience.
    At least something to get you thinking.
  3. #3
    Join Date
    Oct 2011
    City
    Blackfoot
    State
    Idaho
    Country
    United States
    Posts
    518
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thanks for the feed back, right now I am looking at a double sleeve with buttress threads on the inside sleeve and a buttress nut on the outside sleeve with a sprocket chain drive if you can visualize so to operate from the standing position or by power
    I am looking for something that I can operate from the operating position on the drill press.
    I will try to sketch it up and see what you guys can do with it
  4. #4
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,541
    Tickets
    0
    Post Thanks / Like
    Chats
    53
    Seems we had a thread or two where members had done a good job a couple of ways to add a table lift. I'll see if I can locate them.
    Late to bed, early to rise puts big dark circles under your eyes! Author - Me!
  5. #5
    Brass Inflight's Avatar
    Join Date
    Nov 2011
    City
    Long Beach
    State
    California
    Country
    United States
    Posts
    104
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    My idea won't suffice for a floor model drill press, but a few years ago I used a discarded hydraulic door closer mechanism to assist lifting the table on a bench top size drill press.
  6. #6
    Aluminum
    Join Date
    Oct 2011
    City
    Mackay
    State
    Queensland
    Country
    Australia
    Posts
    54
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    its a bit belated but may help someone.
    My drill press has a hollow column and I have a bit of round bar about the weight as the drill press table. Its just a counterweight that is connected via pulleys and a stout stranded wire rope.
    Its poring rain at the moment so I can;t get out there,but will take pics if anyone wants them.
  7. #7
    Plastic HarryG's Avatar
    Join Date
    Mar 2011
    City
    Canal Winchester
    State
    Ohio
    Country
    United States
    Posts
    22
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    OzzModz Classifieds
    1
    Quote Originally Posted by Ozwelder View Post
    its a bit belated but may help someone...
    My drill press has a hollow column and I have a bit of round bar about the weight as the drill press table...
    If the rain has stopped, pix would be nice...
  8. #8
    Join Date
    Oct 2011
    City
    Blackfoot
    State
    Idaho
    Country
    United States
    Posts
    518
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Well I have traded up to a Powermatic varispeed with the low speed option which is nice BUT it creates a whole new set of rules for a table lift so back to drawing board
  9. #9
    Aluminum
    Join Date
    Oct 2011
    City
    Mackay
    State
    Queensland
    Country
    Australia
    Posts
    54
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by HarryG View Post
    Hi,
    If it rains much more I will go out and shop for an arc.
    Instead here s a link with pics to a kit that was available in Oz .
    http://www.onlinetoolreviews.com/reviews/easyriser.htm
    It looks quite simple to duplicate,if you have a lathe. If you don't, it was cheap enough to buy at $69.Au three or four years back.Hopefully it is still available.
    The hard bit is getting the head off the drill ,its bloody heavy.The counterweight make lifting or lowering the table quick and easy- like 5 or 10 seconds work.
    If you need more pics or more info ,just ask!
    Hope it helps.
    oz
  10. #10
    Cast Iron Ulma Doctor's Avatar
    Join Date
    Feb 2013
    City
    Tracy
    State
    California
    Country
    United States
    Posts
    672
    Tickets
    0
    Post Thanks / Like
    Chats
    9
    i have the same problem, by table w/ my x/y vise is very heavy and may need 60 lbs of counterweight.
    i like the steel pipe/ concrete idea!
    mike
    Mike
    "If it broke once, it WILL break again!"
    Ulma Doctor- Meat Processing Equipment/ Packaging Specialist, Serving the West Coast.
  11. #11
    Join Date
    Oct 2011
    City
    Blackfoot
    State
    Idaho
    Country
    United States
    Posts
    518
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Tanks OZ I will see if there is any way I can fit it into the head with the vari speed unit inside, pretty tight with that adjustable pulley and belt moving in and out but maybe
    Thanks for all the ideas guys
  12. #12
    Aluminum
    Join Date
    Oct 2011
    City
    Mackay
    State
    Queensland
    Country
    Australia
    Posts
    54
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    The counter weight does'nt necessarily have to fit down the hollow column.
    It can be sited outside,even inside its own pipe /tube if need be. That can be any size you want it to be.
    Oz
Similar Threads
  1. xy table on a drill press
    By cpd62 in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 09-29-13, 10:18 PM
  2. Drill Press Dolly - Need some ideas
    By dlinderm in forum MACHINE ACCESSORIES - QUESTIONS & ANSWERS
    Last Post: 02-25-13, 08:54 AM
  3. x-y Table for Drill Press
    By Walt in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-17-12, 07:34 PM
  4. Chain drive table lift for my drill press
    By jimini in forum TOOL JUNKIES - TOOLS & TOOLING
    Last Post: 08-06-11, 08:52 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
