Results 1 to 2 of 2
Thread: Rebuild and Test stands
  1. #1
    Plastic
    Join Date
    Apr 2011
    Country
    United States
    Posts
    36
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    5.44 MB
    My Feedback
    (0% Positive Feedback)
    A while back a customer came in needing a fixture or stand to hold a component out of a coffee machine for rebuilding.
    Also needed a way to test it before sending back into service. The component gets rebuilt after every 100,000 cups of
    coffee made whether it needs it or not I made a fixture to hold the unit to make the rebuild easier. Part of the rebuild
    was replacing a 24 volt dc motor and a limit switch as well as a couple of bearings and this was done every time. Next they
    needed a way of testing the unit to make sure it was in working order and the limit switch tripped correctly. Can't remember
    how it worked exactly but the limit switch controlled two functions via a couple of bumps on the slide that the motor ran.
    The test stand consisted of a 120 vac to 24 vdc converter which allowed the motor and switch function to be tested.
    Work good and a couple of months later wanted another one made. Would have been nice to build them at the same time
    Dave
    Attached Images Attached Images
  2. #2
    Moderator irishwoodsman's Avatar
    Join Date
    Nov 2011
    City
    stlouis
    State
    Missouri
    Country
    United States
    Posts
    1,048
    Tickets
    0
    Post Thanks / Like
    Chats
    3
    Total Downloaded
    0
    My Feedback
    Re: Rebuild and Test stands
    nice job
Similar Threads
  1. BP 2J Rebuild
    By sd624 in forum BRIDGEPORT & B'PORT CLONES
    Last Post: 07-09-14, 05:30 PM
  2. It's all I can stands can't stands no more
    By mirage100 in forum MACHINE ACCESSORIES
    Last Post: 02-01-14, 10:09 AM
  3. Rebuild of my 618...
    By dfwcnc in forum ATLAS & CRAFTSMAN MACHINES
    Last Post: 09-24-13, 11:03 AM
  4. Test TEST test photo of HLV_H project
    By JIM MCGREGOR in forum THE PRACTICE FORUM (practice your posting here)
    Last Post: 01-12-13, 06:19 PM
  5. Custom Bike Stands
    By Tony in forum OTHER PROJECTS, INCLUDING WOODWORKING
    Last Post: 09-16-11, 08:14 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
