Results 1 to 7 of 7
Thread: Gnome Rotary Engine
  1. #1
    Dismissed
    Join Date
    Nov 2011
    Posts
    1,460
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Gnome Rotary Engine
    This is one of those on again off again projects that I've been working on for some time. It's loosely based on the Gnome type N nine cylinder. I originally intended to actually use it on a radio controlled quarter scale Nieuport 28, so I thought it would be wise to actually build two engines at the same time, just in case. Besides, most of the work in parts like this is in set-up so an extra set is actually very little extra work. So far I've completed the crankshaft, front and rear crankcase covers, cams, most of the parts associated with spark timing and the cylinder liners. I also got a good start on the finned part of the cylinders and I made a somewhat lame first attempt at casting the crankcase. I still need to make the master and slave connecting rods, pistons, re-design and build the valve train assembly (I don't care for the original design), and recast the crankcase. I also need to make some spark plugs at some point.
    Tom
  2. #2
    Tungsten Carbide ScrapMetal's Avatar
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,731
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Re: Gnome Rotary Engine
    Very cool project. I'd love to see more of it as you work on it.
    -Ron
    South Bend 11" Lathe
    Wells-Index 860 Mill
    Queen City Shaper
  3. #3
    Dismissed
    Join Date
    Nov 2011
    Posts
    1,460
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thanks Ron.
    Getting the parts out to photograph has re-kindled my interest. Maybe I'll move this project up the list a bit.
    Tom
  4. #4
    Dismissed
    Join Date
    Nov 2011
    Posts
    1,460
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Bill,
    I'm gonna finish the single shot rifle first and when that is done I'll take another look at the Gnome. There are too many unfinished projects in the que at the moment and I need to check a few off the list. The problem with the Gnome is that once that's done it will automatically generate another project, a Nieuport 28 to fly it in.
    I have been thinking about casting some metal though. If nothing else, there could be a crankcase in the works for this summer.
    Tom
  5. #5
    Thurston Howell
    Guest
    Quote Originally Posted by TLGriff View Post
    Bill,
    Tom
    Tom,
    Beautiful work so far - very impressive! What was wrong with the casting? Sure doesn't look bad but guess getting the draft right on something that complicated could be problematic.
    In the event you do get back and start pouring casting, might not be a bad idea to offer some for sale as I'm sure you'll get some takers.
  6. #6
    Dismissed
    Join Date
    Nov 2011
    Posts
    1,460
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by MikeA View Post
    Tom,
    Thanks Mike.
    The aluminum wasn't hot enough on the first try so the mold didn't fill all the way. Of course there are nine cylinders so I guess one less wouldn't make that much difference.
    Tom
  7. #7
    Thurston Howell
    Guest
    Thanks Mike.
    Tom
    Tom,
    I could be wrong, but somehow I think an 8 1/2 cylinder might have timing problems!
    I've never done any casting - is it something I need to look into?
Similar Threads
  1. Rotary valve steam engine build
    By joeschuit in forum STATIONARY & LIVE STEAM ENGINES
    Last Post: 09-25-13, 12:03 AM
  2. Allenair pneumatic rotary tables--Anyone use them or hyd operated rotary tables?
    By Dave Smith in forum MACHINE ACCESSORIES - QUESTIONS & ANSWERS
    Last Post: 06-19-13, 07:42 AM
  3. Good Site for Steam Engine and Stirling Engine Plans
    By Nels in forum STATIONARY & LIVE STEAM ENGINES
    Last Post: 05-29-13, 12:56 PM
  4. Model Engines - Gnome and Aeronca
    By cwelkie in forum OTHER PROJECTS, INCLUDING WOODWORKING
    Last Post: 03-31-13, 09:51 AM
  5. Rotary Table or Rotary Table and Dividing plates?
    By 7HC in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 07-22-12, 01:08 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
