Results 1 to 6 of 6
Thread: How to I fix a crooked hole?
  1. #1
    Aluminum Professor's Avatar
    Join Date
    Jan 2012
    City
    Natick
    State
    Massachusetts
    Country
    United States
    Posts
    55
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    In the "Welcome" section of this forum Nikon Ron wrote:
    Soooooo, feeling a little frisky I decided to drill and tap the compound rest on my Compact 8 lathe for a QCTP, which many of you helped me with. Well to make a long story very short, I drilled the hole crooked, very crooked. Which brings up a question and subject for a new post in the group that I haven't joined yet. The best way to right the wrong, or make the wrong right whichever you prefer, should I try repairing the compound or should I try, with your help, to find another one? It seems that if I found another compound I would have the same problem, drilling it correctly. I squared everything up on my drill press before I started but I "still" got it wrong.
    He indicated he would start a thread in a different group so I thought I'd give my answer here instead of continuing on in the Welcome section. So here goes.
    Bob replied with one good approach:
    My thought on the mis-drilled part is to install a threaded stud to completely fill the hole and mill it off so the it is level and square. We used to do this on diesel engine blocks that cracked between the liners and it is a tough and durable fix. When you install the stud, use a bit of green loctite and it is nearly permanent as any other repair.
    I have used stud plugs as Bob describes for many different applications. They work particularly well when further machining is not going to occur at the same location as where the hole is being plugged. Of course, a threaded stud requires a threaded hole (which is Nikon Ron's case). In some cases when I just had a round hole, I simply threaded it so I could stud plug it.
    Stud plugs become a bit more problematic if they are plugging a hole that was drilled close to the correct location, and which will be corrected with a new threaded hole. The problem arises when the new hole drills out a significant portion of the plug. The remaining bits of threads from the stud plug may not hold securely enough to enable clean threads to be made in the new hole. (In this case, the more the first hole missed the mark, the better.)
    For holes that have to be moved only slightly (or realigned slightly) filling the hole with weld may be an alternative. Use soft filler material and let the entire piece cool slowly to anneal it. After it is cool, grind off the excess filler to get a smooth surface. Of course, this may not be practical for hardened or precision pieces (such as Nikon Ron's QCTP).
    So, in Nikon Ron's situation:
    1) Can you stud plug the errant hole and drill and tap in an undisturbed location?
    2) Could you disassemble all except the base, weld the hole shut, anneal, re-drill and tap it? (I don't think it has to be hard to function well. You would want to do a little clean-up surface finishing to make it look better and work well.)
    3) Can you, as Bob suggests, re manufacture just the base?
    Then, Ron, you need to figure out just what went wrong when you drilled and tapped the first time. Why did it come out crooked?
    Other comments/suggestions?
  2. #2
    Global Moderator Rbeckett's Avatar
    Join Date
    Sep 2010
    City
    Bronson
    State
    Florida
    Country
    United States
    Posts
    2,641
    Tickets
    0
    Post Thanks / Like
    Chats
    368
    Total Downloaded
    0
    My Feedback
    Re: How to I fix a crooked hole?
    Ron Nikon and Prof,
    You are absolutely right about the location of the original hole being an issue. If it cant be moved far enough, then maybe using a helicoil in the newly drilled hole will give the QCTP stud a stable and durable base. If you could move it completely off of the original hole location that would be best but the stud repair coupled with a stainless helicoil should be plenty strong enough for even the tightest tool post. If it is Iron it is going to be difficult to weld and get good results with unless you have a welder freind who is willing to devote the time to do it properly. Cast Iron and cast steel are pourous and problematic, but can be worked nicely with silicon bronze alloys among others. Just some more thoughts from the peanut gallery.
    Bob
    If you don't have something positive to say, keep it to yourself it makes you look so much smarter.
    Life Resolution--NEVER let my shop get cluttered again....EVER!!!!!
  3. #3
    Plastic Nikon Ron's Avatar
    Join Date
    Aug 2011
    City
    Klamath Falls
    State
    Oregon
    Country
    United States
    Posts
    43
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    2.12 MB
    My Feedback
    Fixing a crooked hole
    I believe that the compound is made of cast steel. I could do a spark test on it today to determine what it is.
    I was using a tap drill for a 14mm stud that came with the QCTP. I think that I was turning the drill bit at too high an RPM and it walked a little on me.
    I might be able to move the location of the hole, ?, not sure. I have a friend who has a home hobby machine shop who may have a milling machine. Could I perhaps bore a bigger hole in it and then press in a threaded bushing?
    One would think that after 41 years working as a millwright that I could do a better job than this. I know, age and senility have set in.
    Regards, Ron
  4. #4
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,651
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    If you can get it on a mill, drill and tap to the next size that will fit. The make a step-stud for it, one end to fit the new hole, the rest stepped down to fit the tool post.
    A pressed in sleeve will be too easy to pull out, unless you make one that has a "head" on it and can get to the backside for a matching counterbore.
    "A man who works with his hands is a laborer. A man who works with his hands and his brain is a craftsman. A man who works with his hands, his brain and his heart is an artist."
    -Louis Nizer
  5. #5
    Tool Steel Hawkeye's Avatar
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,491
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    If the stepped stud Tony suggests isn't practical for some reason, it might be worth drilling and tapping a fair bit larger than you need. Then screw in the threaded plug that size, with green Lock-tite. You'll need a mill to ensure straight drilling and tapping, after milling or grinding the plug flush. That way, the new hole isn't too close to the other threads.
    Overall, I like Tony's stepped stud threaded in from the back with a shoulder, if that can be done.
    Mike
    Victoria U2 Mill w/ Vertical Head
    ZX25 Mill/Drill
    X2 CNC Mill
    Storebro Bruk Ornmaskiner 14 x 40 Lathe
    Hercus AR Lathe
    Louis 10" Shaper
    9 x 12 Horizontal Bandsaw
    Hobart Handler 140 MIG
    TIG / Plasma Cutter
  6. #6
    Cast Iron bcall2043's Avatar
    Join Date
    Oct 2010
    City
    Middle TN
    State
    Tennessee
    Country
    United States
    Posts
    662
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    72.37 MB
    My Feedback
    Crooked hole fix
    I agree that Tony Wells' solution is best if the crooked hole is in the right location. A new piece of raw stock would be needed and you would get some practice turning and threading in your lathe.
    Benny
Similar Threads
  1. Bolts for any hole
    By Old Iron in forum THE MEMBERS' HANGOUT (OFF-TOPIC discussions)
    Last Post: 01-20-13, 03:02 PM
  2. Square hole
    By wawoodman in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 08-22-12, 02:08 PM
  3. OT: Crooked EBay Buyer
    By randyjaco in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 04-21-12, 08:14 PM
  4. How do I use an Indicol to indicate a hole?
    By Nels in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 01-22-12, 07:33 AM
  5. Help boring a hole
    By Galileu in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 06-05-11, 04:28 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
