Results 1 to 16 of 16
Thread: Grizzly G0704 v. an X3 mill - what are your thoughts?
  1. #1
    Aluminum
    Join Date
    Jan 2012
    Country
    United States
    Posts
    57
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    (0% Positive Feedback)
    What are your thoughts out there between an X3 mill v. a Grizzly (BF20) G0704. It seems that weight-wise, they are in the same category. With the 0704 you get the digital height adjustment and the stand, but pay less, is there that much of a quality increase in the X3 styles, namely the G0463. My question stems from seeing the similarities between the G0619 and the G0704 but the huge (~$500) difference in price. I know they're made in different factories in China, but, while not as popular as the X3 styles, there seems to be a decent following on the BF20s, so just wanted to get some input from the users. Thanks.
    Micromark 7X16 mini-lathe and a bunch of stuff I don't know how to use yet.
  2. #2
    Aluminum
    Join Date
    Jan 2012
    Country
    United States
    Posts
    57
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Great information - thanks. I'm hopefully within a few weeks (positive thinking) of acquiring a mill. I don't have a lot of room to play with, and even less money (same old song and dance I'm sure), and think I have it narrowed down between the X3 and the G0704. I'm sure you've been on the www.g0704.com website, and I noticed the following there, as well as the CNC conversions. Has the tilting head on the 0704 caused you much anguish for tramming? It seems a bit more solid than having the column tilt on, for example, the LMS X3 with the column tilt. Most of my reading shows that not too many use the tilt feature of either the head or the column. Have you used it much, or do you simply use a tilting vise? Again, great information.
  3. #3
    Chips
    Join Date
    Mar 2012
    City
    Montreal
    State
    Province du Quebec
    Country
    Canada
    Posts
    3
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Re: Grizzly G0704 v. an X3 mill - what are your thoughts?
    Be very careful when milling SS, I burned out the motor on my G0704 which Grizzly rapidly replaced.
    I have made a mod by installing a thermo-disk overload inside the motor and I also installed a cooling fan to draw the heat out of the motor. I will not be doing any SS in the foreseeable future as it is VERY hard stuff to mill.
    For 4140 steel there is no apparent issue, especially since installing the cooling fan. All-in-all, it is a nice machine with a small footprint. My problem is available floor space of which I am very limited in.
  4. #4
    Cast Iron Splat's Avatar
    Join Date
    Mar 2012
    City
    here and there...
    State
    New Jersey
    Country
    United States
    Posts
    713
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    As the guys have already mentioned, for all the right reasons, get the 704. What you get is more workspace and lower cost, but less weight than the 463. A lot of guys would say the weight makes the difference but you have to weigh that against your budget. As I've said before, when I was looking for my first mill months ago and researching as much as I could I had decided upon the 704, until I found a used Johansson small knee mill that popped up only 2 days before I planned on riding out to Grizzly for the 704. Get the 704. It's a great machine and the $ you save over the 463 will buy you some needed tooling or accessories.
    1953 Johansson B-12 mill
    1957 South Bend Heavy 10L with Teco NEV-101-H1 vfd
  5. #5
    Join Date
    Mar 2012
    City
    here and there...
    State
    New Jersey
    Country
    United States
    Posts
    713
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    FWIW..... I just got a catalog from Penn Tool (New Jersey, USA) and I see they have a small knee mill from Top Tec for around $1800, link here. I've read of guys' positive reviews of their lathes but so far haven't searched for any reviews on their mills. If I had saw that before I bought my used 1956 Johansson/Clausing small knee for only a few hundred more, I might have went with that.
  6. #6
    Chips
    Join Date
    Mar 2012
    City
    Montreal
    State
    Province du Quebec
    Country
    Canada
    Posts
    3
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by dalee View Post
    Hi,
    Grizzly did have some issues with the motors on a batch or two of 704's. They replaced a lot of motors under warranty for people. They even stopped selling the machine until they found a suitable solution.
    I'd love to see your fan set up and the thermo overload mod. I've got a 115v pancake fan around here somewhere.
    dalee
    120Vac fan powered from inside the control panel on the G0704. Installed a SPST toggle switch as you can see in photo.
    I cut a large opening in the top with a dremel tool as the slots don't allow enough volume of air flow.
    As for the motor, I installed a thermodisk inside the motor inline with one of the brushes. Should the heat rise to a dangerous level, it will open and thus shut down the motor until it cools to the pre-trip level.
    When the fan is running, it sucks an enormous amount of air thru the cover thus effectively preventing heat build up and motor melt down.
    Thermodisk = $8
    Fan = $20
    Not having to worry about 2 weeks down time = Priceless
    Top view (motor was installed a little crooked) NOTE: must install screw heads on the inside and nuts on the outside as there is very little clearance between the motor and the cover. Also use nyla-lock nuts so doesn't loosen with the vibration.
  7. #7
    Steel kd4gij's Avatar
    Join Date
    Feb 2011
    City
    St. Petersburg
    State
    Florida
    Country
    United States
    Posts
    1,036
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    11.06 MB
    My Feedback
    I have had my G0704 for almost a year and have been very pleased with it. The latest ones comming from grizzly have the 3 bolt mod already done.
    Craftsman 101 12x36, Grizzly G704, Emerson-Craftsman Radial armsaw & table saw.
  8. #8
    Brass
    Join Date
    Aug 2011
    City
    Pueblo
    State
    Colorado
    Country
    United States
    Posts
    136
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.41 MB
    My Feedback
    Got mine last month. It did not have the 3 bolt mod. But it does now.
    Ron
  9. #9
    Aluminum
    Join Date
    Apr 2012
    City
    Van Alstyne
    State
    Texas
    Country
    United States
    Posts
    59
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Might want to see what Precison Matthews/Quality Machine tool has.
    Although my mill is the dovetail column "45" size, I found that PM had the best overall price/package.
    While I did not care for the PM lathe I got (and sold) , I am very happy with the Mill.
  10. #10
    Join Date
    Mar 2012
    City
    here and there...
    State
    New Jersey
    Country
    United States
    Posts
    713
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    I talked to the owner of PM about 2 months ago and they only had the bigger machines in stock with no ETA of the smaller ones, like the PM20/25/30. Might be obvious but you should definitely call them before you start seriously considering them.
  11. #11
    Cast Iron BRIAN's Avatar
    Join Date
    Jan 2011
    City
    Caltabellotta
    State
    Sicily
    Country
    UK
    Posts
    620
    Tickets
    0
    Post Thanks / Like
    Chats
    81
    Total Downloaded
    0
    My Feedback
    I run the smaller brother of this mill( a 16 ) and am very happy with it .I use the head tilt a lot and find it easy to tram . Most of my work is light weight so I cant comment on its heavy use.
    If I have a issue it is the noise that the primary reduction gears make when used at high speed.I had to drill out the motor plate holes to adjust the depth of mesh to improve this. But after 2 years and a lot of use it seems to be getting a lot less, Or i am geting Deaf in my old age.
    If you are thinking of power feed you may like to look at. 2 AXIS POWER FEED FOR MINI MILL pdf
    I posted some time back.
    I think the 20 will definately be a good machine for you.
    Best regards Brian.
  12. #12
    Aluminum
    Join Date
    May 2012
    City
    Poplar Bluff
    State
    Missouri
    Country
    United States
    Posts
    54
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I, too, am in the market for a small mill. I saw a reply mentioning the 0463. What are the main differences, besides weight? Is there a measurable difference in ability to make cuts without chatter becoming an issue? What do most people here use this mill for? I hope to use mine for gunsmithing work. Obviously, I would like a full sized knee mill, but it is in the future. Would I be making a mistake by buying this to begin with?
    Thanks for everyone's help here!
  13. #13
    Join Date
    Mar 2012
    City
    here and there...
    State
    New Jersey
    Country
    United States
    Posts
    713
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by geraldsd View Post
    A lot of, if not most, people associate weight with rigidity. Therefore, a heavier machine should ideally be more rigid, thereby able to take cuts that would make a lighter machine chatter or not be able to take at all (with equal motors, etc.). The G0463 is an excellent machine. It's got a little more travel but the table and the motor HP is smaller than the G0704. Both are capable machines for the home machinist.
  14. #14
    Plastic
    Join Date
    Nov 2011
    City
    Middlesbrough
    State
    Teesside UK.
    Country
    UK
    Posts
    37
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Total Downloaded
    0
    My Feedback
    Hi from across the pond.
    I have the UK equivalent..BF20L? (Warco WM16, the smaller capacity brother) & have just started to use it in anger after getting my garage coversion sorted, I have milled a couple of stops for head now that I have trammed it in, the first of some mods that I have in mind. I am now in the process of machining some cast iron for a rear toolpost from a kit I bought some months ago,& so far it is handling cutting quite well, I am using a 2" four tip index insert facing mill as a fly cutter, that way it spreads the intermittant loading of a single point fly cutter, I am not being greedy only putting on between .020" - .050" per cut.. 'slowly, slowly catchee monkee' as the saying goes. I started off with 127 rpm as calcs indicated but upped it to 250 rpm & it handles it quite well..so far! really don't like counting chickens & all that.
    The machine is straight out of the box & apart from the removal of the travel grease off the table & haven't done any strippinng to bits as a lot of guys seem to want to do etc, if it aint broke don't fix it I say, I am satisfied with the way it is performing so far, the cast iron cutting has not produced any excessive heating of the motor-750 watt DC, & it was running for at least 20 -30 min at a time, there was some clatter which concerned me but on checking the cutter I found that the head (cutter) was not tightened snuggly onto the taper(MT2) this soon quietened down once I gave it a extra tweak with a Allen key & it improved the cutting properties. There is some intermediate gear chatter which seems to be the norm for these chinese machines from all accounts so I am not unduly worried about it.
    One of the other mod's I want to do eventually is convert it to belt drive to eliminate the intermediate gear & improve the torque rating as some have done with the X2 version..any one out there have a conversion kit, or plans for one? I would most gratefull.
    I have att. a couple of pics..if they have loaded ok.
    Cheers
    George
    2012-12-02 16.45.47.jpg2012-12-02 16.44.28.jpg2012-12-02 16.44.06.jpg2012-11-30 12.38.14.jpg
  15. #15
    Aluminum
    Join Date
    Oct 2012
    City
    vallejo
    State
    California
    Country
    United States
    Posts
    81
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I have used both. I gave the x3 to a brother at my church.
    I prefer the G0704 or Enco. Seems to be more rigid.
    The steel in the sig seems to be softer, the quill bearing tube.
    Also had a round column mill, mostly used it for drilling. Its been long
    gone.
    charl
  16. #16
    Plastic
    Join Date
    Sep 2012
    City
    Carrollton
    State
    Texas
    Country
    United States
    Posts
    24
    Tickets
    0
    Post Thanks / Like
    Chats
    4
    Total Downloaded
    0
    My Feedback
    The cooling fan is a great idea. I've already lost the first motor, it was covered under warranty and I had no issues getting a replacement.
    One thing about the fan switch, Why, just wire it so the fan comes on when the motor is running?
Similar Threads
  1. Ordered Grizzly G0704 Mill
    By Paradox123 in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 03-19-14, 11:22 PM
  2. Need some thoughts on Grizzly G9902 Mill
    By Earlkonig in forum GRIZZLY, BUSY BEE, HARBOR FREIGHT & CENTRAL MACHINERY
    Last Post: 11-20-13, 09:14 AM
  3. grizzly mill thoughts
    By talkingmonkey in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-19-13, 04:36 PM
  4. Grizzly G0704 v. an X3 mill - what are your thoughts?
    By Lone Watie in forum OTHER BRANDS OF MACHINERY
    Last Post: 05-08-12, 09:51 AM
  5. Grizzly G0705 Mill/Drill vs G0704
    By mjonkman in forum OTHER BRANDS OF MACHINERY
    Last Post: 05-21-11, 02:18 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
