Page 1 of 2 12 LastLast
Results 1 to 30 of 51
Thread: Repair lathe motor?
  1. #1
    Tungsten Carbide ScrapMetal's Avatar
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    (0% Positive Feedback)
    Repair lathe motor?
    I have (as best I can read off the tag) a GE, Model# 5SCA65AA6, Type SCA, 1/2 HP, single phase, 110v motor powering my SB 11".
    The motor gets very hot and it does it rather quickly. It will start to make "strained" noises short time which can be alleviated by oiling the bearings but it only lasts for a short time. Applying the oil to the bearings is like dumping it on the ground as the oil just runs through it. Yes, I can switch to a higher viscosity oil but I'm pretty sure the bearings need some work.
    How much effort is it to rebuild one on these? Am I looking at bearings or bushings? Is it "worth it" to try and rebuild this motor or just go with a newer and probably more efficient option?
    I'd like to hear some opinions.
    Thanks,
    -Ron
    South Bend 11" Lathe
    Wells-Index 860 Mill
    Queen City Shaper
  2. #2
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    Re: Repair lathe motor?
    Likely sleeve bearings, which are babbit plated steel. You could make some new ones of bronze, but you would need another lathe. Unlikely, but not impossible that a motor shop would sell you some. They press in, which of course means knock the old ones out with a drift, and press in the new ones, aligning the oil hole.
    "A man who works with his hands is a laborer. A man who works with his hands and his brain is a craftsman. A man who works with his hands, his brain and his heart is an artist."
    -Louis Nizer
  3. #3
    Steel 8ntsane's Avatar
    Join Date
    Dec 2010
    Country
    Canada
    Posts
    1,210
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Ron
    I would look around, and get a general idea of price for a motor in your area. If new is out of the price range for you , a used motor might be worth looking in to.
    I maybe wrong, but the bearings would normally be greased,No? I would also guess the bearing , or bushings should be fairly inexpensive, and shouldnt break the bank.
    The only bummer about this, is once you pull the motor and tear it down, your lathe is down too. And you know the deal, thats just when you might need it.
    Regardless, it might be worth taking it apart, just so you know what it needs, and how bad it looks inside. This might save you the BS of ordering bearings / bushings and wishing you just looked for another motor to start with.
    Might check the local craigslist for a good used replacement first.
    Paul
    All My Rowdy Friends Have Settled Down.
  4. #4
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    If you have a mill, you don't need a lathe to make new bushings, if it is a bushing as I suspect because of the oilers. You'll have to tear it down to see. I'm another who prefers repairing old motors if possible.
    -Louis Nizer
  5. #5
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    If it were mine, I'd pull that belt off the motor pulley and turn it by hand - er, power off, of course. If it's the bearings, you can feel it, and see how long it spins after being given a turn by hand. If it spins easily and smoothly, it's not the bearings. If it's hard to turn, yep, bearings or some built-up drag mechanism inside.
    It could well be the motor start/run cap going bad. If that has not been replaced in your memory, it wouldn't be all that bad an idea to just replace it if the rest of the motor checks out. Motor caps are $5 to $20 items at HVAC supply places. This could cause the heat all by itself in some cases. A *shorted* or going-low-resistance motor cap causes a big electrical drag on the motor's rotation, as well as pulling a lot of current.
    The other option is to trouble shoot by telephone. I'd spend an hour calling motor rewinding shops within a reasonable driving distance. I've had alternators rewound in the past; this cost in the range of $30-50. I don't know about induction motors.
    Electrical motors are highly standardized. If you can get the motor speed off the rating plate as well as the other numbers, any 1/2HP 120Vac --same speed-- rated motor with similar mounting will work, and may be cheaper as a surplus item.
    A quick look at ebay shows:
    http://www.ebay.com/itm/ELECTRIC-MOT...item3a698c7029 : 1/2HP 120vac 1ph 1800rpm, $110 including shipping, new, 5yr guarantee
    http://www.ebay.com/itm/1-2-HP-ELECT...item3a6b4ce97d : 1/2HP 120VAC 125rpm, $100 including shipping, reversable
    searching on "electric motor 1/2HP" turns up 13 pages of motors. You have to match the voltage, phases, power and speed, as well as the mounting, which is a foot type on yours.
    And, just because the devil is sitting on my shoulder tonight, if you were to buy a DC motor, you'd get infinitely variable speed. You'd have to get one rated for the same or higher HP (note, treadmill motors are notoriously overrated) and about the same speed, you'd only have to adapt it and a DC motor controller to get really wide speed variation.
  6. #6
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    Thanks guys. I personally like the idea of rebuilding but, as mentioned a few times, once I pull the motor my lathe is kaput. If I had a mill that would simplify things but the closest things I have at the moment are a crappy drill press and a huge doorstop that looks kind of like a shaper.
    I don't know any of the history of this motor as it was bought with the lathe, from the widow of the previous owner.
    Tony voiced what I was already thinking, "if it is a bushing as I suspect because of the oilers". The only way to know for sure will be to pull it apart.
    Looks like that is going to have to be the place to start though it's going to kill be to "disable" my lathe.
    Now, if I were to replace it, that opens up a whole new "can o' worms" as I have both 115v and 230v readily available and, darn you R.G. , the possibility of going to a D.C. system.
    I'll let you guys know what I find.
    -Ron
    Queen City Shaper
  7. #7
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Do try spinning the motor by hand with the belt off. It will tell you semi-instantly if the bearings are binding.
    I threw in that comment about capacitors because they often fail. It might be worth your time to take off the capacitor cover and pull out the cap for testing/replacement if you can get to it. Motor start and run caps (those are different) are cheap and easy.
    One thing I forgot last night was craiglist. There's a guy on my local craigslist (which probably doesn't help you much) who is selling his accumulation of motors for $25 - $40 each. You might check your local craigslist for motors.
  8. #8
    Tool Steel Hawkeye's Avatar
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,491
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I think the ultimate solution would be to find a used motor and install it, then use the lathe as required to rebuild the old one. Even a yard-sale motor would keep you running. Just make sure it's got all the connections brought out to the junction box so it can be reversed.
    Mike
    Victoria U2 Mill w/ Vertical Head
    ZX25 Mill/Drill
    X2 CNC Mill
    Storebro Bruk Ornmaskiner 14 x 40 Lathe
    Hercus AR Lathe
    Louis 10" Shaper
    9 x 12 Horizontal Bandsaw
    Hobart Handler 140 MIG
    TIG / Plasma Cutter
  9. #9
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    That's a good point Mike. If a guy could pick up a used motor cheap enough it would make perfect sense.
    I did pull the belt off today and spun the motor shaft by hand. Doesn't seem gritty at all and the shaft is rock solid with no "slop" what so ever. The "electronics" seemed questionable at best. I'll take my camera in tomorrow so I can take a couple of pics as it's kind of hard to describe.
    -Ron
    Queen City Shaper
  10. #10
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by ScrapMetal View Post
    If it spins freely, and has no grit, resistance, or slop, you just saved yourself a fair amount of trouble. Bearings only need rebuilding if they're bad, and if they're not bad, rebuilding doesn't help at all.
    That would be a help. Bad connections/wires can be a problem; so can the start and/or run caps.
    It is possible that there is a bum contact that only opens or shorts when it warms up. I've run into that.
    Are you familiar with an ohmmeter? This is one of the settings on most electric multimeters. This can tell you if there is any electrical connection between the two probes. It's used for measuring resistance (ohms) and also for detecting the difference between open circuits and short circuits (that is, very low resistances). The motor should have two or more wires going in, and a third wire attached to the motor frame or one end bell. Neither of the power wires should be connected (shorted) to the frame, either end bell, the shaft, or the third wire safety ground. If either one shows resistance under maybe 1 megohm, the motor windings are compromised. If they're both over 1M, it's something else.
    See if you can find out the value of the start and/or run capacitor, which should be in the "bulge" outside the motor frame.
  11. #11
    Brass
    Join Date
    Mar 2012
    City
    Sioux Falls
    State
    South Dakota
    Country
    United States
    Posts
    179
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Having worked in a motor shop 25 yrs ago while I was going to school I will tell you what I learned.
    Before doing anything else check how much "up and down" and "in and out" play there is on the shaft. Then pull off the capicitor as mentioned by R.G. A motor shop or some electricians can test this with a meter. If that all is ok then do the following.
    1. Next write down how the wires are hooked up now. By color code or on a motor of that age by number on the wires! GE was always a little different than everybody else.
    2. Before you pull the four long bolts holding the end bells to the middle(stator) section scrib a line fom the end bell on to the main body. One line on the shaft end bel and main body and two lines on the opposite end(start switch end. These are for reference later to get the end bells back on in the same position. Some of these older motors weren't always machined perfectly and if you get them "out of line" you can mess up the clearance of the rotor to the stator and it's hard to sort out.
    3. Take and tap the end bell shaft end loose from the main body and slide the rotor and end bell out of the stator. That way you don't have to fight with/break the start switch and wiring. It's all at the "non shaft" end. There will be a centrifigal switch operator on the end of the rotor. It probably has two springs and a flat plate/washer that you should be able to push in on and it will pop back out on it's own. This operates the start switch.
    4. Take a look inside at the motor windings. It's usually fairly obvious if the windings are burned out. Some will be bright or maybe a dark copper color and some will be "BLACK". If the are portions that are black you would probably need a different motor. They can be rewound(i did it ) but it is harder than I can explain here plus you have to find the right size wire.
    5. Tap the other end bell loose carefully and watch how the wires are routed to the switch and windings. carefully lay the end bell down interior side up. The start switch will be mounted to the end bell. There are usually one or two contacts on the switch. Do they appear good and clean or dark and burned? Think points on a car(if you are old enough to know what they are.
    iF ALL THIS APPEARS GOOD. How much play in and out play was there? Sometimes they wear out fiber washers(on the shaft between the shaft and end bell) and to much play won't let the start switch work properly.
    The old motors like this one really are the best ones ever built (LOOK AT HOW OLD IT IS NOW) and if you can get it back up and purring that's how I'd go.
    Post a picture or two of the inside if you question how something looks.
  12. #12
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    Quote Originally Posted by R.G. View Post
    Quote Originally Posted by Kevinb71 View Post
    R.G. - Yep, I'm familiar with ohmmeters, I don't have a Simpson 260 sitting around but I can pull out my Fluke 87 and get pretty much the same thing done. (Sorry, had to mess with you a bit even though you have no way of knowing that I majored in electronics engineering some 25 -30 years ago. ) Good advice given. I'm not familiar with the layout of this old of motor though. I will be trying to get some good pics tomorrow. I may even be able to get some pics on the interior (wife got me an electronic bore-scope for Christmas that I haven't had a chance to use yet). Oh and no real "bulge" on the motor itself, pictures again.
    Kevin - Where to start? Okay, write down the wire hookups? All black. Wait 'til you see the pics, you'll love it. The motor shaft itself it rock solid, no extraneous movement up, down, in or out. I really like the attitude, "The old motors like this one really are the best ones ever built". I'd like to save it too.
    Pics to come shortly,
    -Ron
    Queen City Shaper
  13. #13
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Another EE? Ok. And may God have mercy on your soul. I do have a Simpson 260, but it was given to me as a legacy.
    Mmmmm. That probably means they got self-starting with a resistance-split phase. The lower-end induction motors bypass the motor start and run caps with a high resistance winding. At startup, the main power winding is low resistance and appears highly inductive, and the high-resistance winding keeps a nearly resistive impedance. This makes for a partial second phase, enough out to let the rotating magnetic field get the rotor moving, and after that, induction takes over and the reaction of the rotor field keeps it running like it would if it had a start cap that dropped out.
    That gets you lower starting torque than a capacitor start or run motor. Still, it's been working for you. That opens your range of replacements a bit. If it were me, I'd look for a cap-start or cap-run motor to replace it. These versions have better starting torque.
    I bring this up because the lack of a capacitor phase split means that it's not as simple as clipping in another cap. If it's a resistive-split phase, that puts it into the rewind or replace category, because there's only the windings doing the work. I'm not a motors expert, but I played one back in the power supply design lab.
    Kevin's advice is really, really good. Pictures, lots of pictures, and disassemble so you can find and fix.
    However, at this point, my 'it's gotta work by tonight' demon prods me and says that you oughta buy a physical replacement motor used and cheap, install it in the lathe, and then work on refitting the old iron.
  14. #14
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    You know, I wonder if the motor is jumperable 110/220 and the jumpers have corroded.
    And I wonder if the continuous increase in wall-socket voltage is just flat overvolting it. Wall sockets used to provide 110Vac, as the name plate says. Over time this has increased until I get 125Vac out on the end of a long, skinny, rural distribution wire. This is a common problem in vintage guitar amps (I deal with these in my day job) and can wear them out pronto. In a motor, it would lead to heating, and the cumulative effect could be to burn wire insulation.
    Just speculation.
  15. #15
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    http://www.dreisilker.com/Documents/...0091225102.pdf
    GE AC motor selection guide. Good info for anyone dealing with electric motors.
  16. #16
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Quote Originally Posted by 1200rpm View Post
    another vintage amp guy... can`t beat glowing tubes!!
    Real amps glow in the dark.
    'Course, when welders do it, sparks fly.
  17. #17
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    NO PICKING ON THE 260's!!! I have a fleet, and a couple of 160's as well. I use a 260 regularly.
    -Louis Nizer
  18. #18
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    oh man! it is getting thick now! ( and creamy!)
    Make that another
    Also have a Matamp Minimat and the wife bought me a Mesa Transatlantic TA-30 Combo for Christmas.
    Quote Originally Posted by Tony Wells View Post
    No problem Tony. Most of my experience with them was back in school and their survival rate was horrendous with many of the students (true "dip sticks" ) switching ranges without disconnecting and frying them left and right.
    Okay guys, I promised some pics today. Here goes.
    Under the little "oval" plate is access to the brushes. I couldn't get a clear picture of them so I didn't bother to post the resulting blur.
    And finally, my favorite...
    Nice installation huh? I haven't dared to take off the old cloth electrical tape as it's a little "crunchy" and I'd rather keep the lathe "runable" 'til I'm prepared to actually do something about it.
    -Ron
    Queen City Shaper
  19. #19
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Make that another
    You're doomed. At least you haven't developed a taste for JMI Vox amps. Might as well like absinthe.
    Comments on pictures:
    (rating plate)
    OK, 1/2Hp, 110V 60 cycle 1780rpm (that's good), foot mounted. If you'll measure the shaft diameter and footprint hole pattern, you can pretty much directly pick a replacement. I think...
    ... brushes... ?? There are brushes in there?? Are you sure?? One of the reasons to use a split phase induction motor is that it doesn't need brushes at all, so there's nothing to wear out.
    Is there a commutator or slip rings in there?
    Are you sure it has brushes?? Brushes make it into a different animal. If there is a commutator in there, it's a big "universal" type. If there are slip rings, it's a wound-rotor type. I've read about wound-rotor induction types, but I don't think I've ever actually seen one.
    Is that maybe access to a centrifugal switch to switch out the start winding?
    Brushes... AAACCKK!!! Brushes...
    That last run of comments flips my advice over to "find a used replacement motor and put it in. Then do your rebuilding at a leisurely pace."
    Look here: http://austin.craigslist.org/tls/2877966495.html
    I think numbers 3 and 4 might drop in if they are foot mounted. Can't tell from the pictures.
  20. #20
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,491
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Hah! I ran the model number through Google. I got 10 hits, all originating from HM. There's not much info on that motor on the net.
    Is it possible that what you are seeing under the oval plate is the start switch mechanism? You don't usually see a universal motor in that size. (At least, not any more.) If it was for brushes, I'd expect to see another plate on the underside.
    If the start switch is not opening, it will keep the start winding in play all the time. This will definitely cause quick heating. Try removing the oval plate and watch the switch mechanism while it is starting up. If it is opening, you will usually see a spark and hear a click when the start winding drops out. If not, check for grunge on and around the mechanism, broken springs, or pieces obviously out of place.
    According to the plate, it is 110 Volt only. The fact that there are four leads coming out to the JB shows that it is likely reversible.
    If you do take the connections apart, pick up some screw terminals large enough to take all the necessary wires. They come is strips of 12 and can be cut to length.
    Mike
    ZX25 Mill/Drill
    X2 CNC Mill
    Hercus AR Lathe
    Louis 10" Shaper
    TIG / Plasma Cutter
  21. #21
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    I should have made a sketch when I was looking at it (By the way, my bore scope sucks!) but here's a rough drawing of what I saw under that nice little cover:
    I could only see the top side, of course, so I can't say what else is going on in there.
    -Ron
    Queen City Shaper
  22. #22
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,491
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Yup. That's a universal, all right. Does it look like there is any kind of rotational adjustment in the brush arrangement? Some large frame brush motors were 'tunable' at one time - I think that's how some were reversed.
    Mike
    ZX25 Mill/Drill
    X2 CNC Mill
    Hercus AR Lathe
    Louis 10" Shaper
    TIG / Plasma Cutter
  23. #23
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    A series wound motor is a horse of an entirely different complexion.
    First: bummer - it's a natural for a speed control setup, just like a DC motor (which it is).
    Second: maybe it'll be easy. Bad brushes and commutator would do what you're seeing.
    Third: maybe it'll be very hard. I have no clue how common brushes are.
    I'll go do some looking.
    It would be GREAT if you could refurb it, as you'd get the possibility of variable speed control easily.
  24. #24
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    Quote Originally Posted by Hawkeye View Post
    I couldn't really tell. The way my setup is it's a little difficult to get in at that area. I'll have to remove the lathe's switch in order to get a bit closer.
    I couldn't find much on it either. Not sure how it relates to the internal wiring but if you look at the motor plate there is a line on there that states "ELECT. REV."
    -Ron
    Queen City Shaper
  25. #25
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    That means "electrically reversable", which is is. Reversing the connections of either of the two series windings while leaving the other one alone reverses the rotation direction.
    I did a quick scan through ebay and failed to turn up even one likely suspect.
  26. #26
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,491
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    I couldn't open the manual, but the front page mentions a "brush lifting" motor. Fascinating. The commutator is only in play during start-up. If this is what you have, you should see some type of centrifugal mechanism connected to the brushes that will lift them at speed.
    Just for reference, I wouldn't advise using a series motor (which R.G. mentioned) in any application other than direct connection. They have the strongest torque of any brush motor, but, if the output becomes broken i.e., a belt comes off), they will "accelerate to destruction".
    Mike
    ZX25 Mill/Drill
    X2 CNC Mill
    Hercus AR Lathe
    Louis 10" Shaper
    TIG / Plasma Cutter
  27. #27
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    Quote Originally Posted by CluelessNewB View Post
    I believe that is an RI (repulsion start induction run motor) not a universal. The link below is
    for a Wagner Electric Manual for their RI motors which may be of some help.
    http://www.vintagemachinery.org/pubs...l.aspx?id=3918
    Very interesting. I have some reading to do tonight.
    Thanks much.
    Got it! example: "runaway diesel" - not good. It makes sense, now that you mention it, with no load there is nothing to limit the acceleration 'til things get exciting and parts start whizzing past your nose. Oh, and try downloading it from this link: http://68.227.91.247/machines/WagnerRepStartInd.pdf It's off my server and I saved it in a slightly different way. Hopefully you can open it.
    Thanks Hawkeye
    -Ron
    Queen City Shaper
  28. #28
    Aluminum
    Join Date
    Feb 2012
    City
    Austin
    State
    Texas
    Country
    United States
    Posts
    62
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
  29. #29
    Brass
    Join Date
    Mar 2012
    City
    Sioux Falls
    State
    South Dakota
    Country
    United States
    Posts
    179
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    0
    My Feedback
    Ron
    I was gone over the weekend and followed up this morning on the progress. Since this is a wound rotor motor it's even better if it's not toast. With a wound rotor the commutator typically has segments on it with mica separating each segment from the next. As the brush's wear down they also wear into the commutator section. The copper/brass section wears down quicker than the mica does causing the mica to lift the brush's as they pass from segment to segment. I have attached a crude attempt at a drawing showing this(i was laughed out of art class in high school. They let me go to shop class instead!) This can be turned down on a latheto flatten it back out, but you need a tiny slot cutter to cut the mica down between segments(only a few thou). Brush's should be available at a motor shop locally. If not I have some yet from back when. PM me and I will give you my address to send me an old one to match up. In the mean time try to find a used motor for a backup and then fix this one if you can. You can use your lathe to do it. The only hard part is getting the Mics cut down. A dremel with a slotting cutter mounted to your tool post somehow should do it fine. Since your an EE this will all make sense to you. Didn't mean to be so basic in my first reply. There's lot's of other good sources of info in the posts since my first reply.
    Attached Files Attached Files
  30. #30
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,801
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Total Downloaded
    1.86 MB
    My Feedback
    I like your drawing Kevin, has kind of a "Salvador Dali" feel to it.
    It seems counter intuitive that the mica would wear less than the copper but what you say makes perfect sense. Before I go tearing apart this motor though, I am thinking that I need to get a better handle on exactly what type of motor I'm dealing with and it's operation. It may seem a bit odd or overly cautious but this strikes me as opening up a "can o' worms" and it's my nature to try and handle a job as efficiently (least work as possible. I'd hate to buy a cheap, used motor as a temp with the plan to rebuild the original then "hit a wall" on the rebuild for some reason. I'd then have to buy a "good" motor to replace the crappy one (again, it's my nature ) and be left with an extra crappy motor as well as a pile of parts that used to be an old motor. Or something along those lines.
    That's a great offer on the "brushes" and I may end up taking you up on that but I'm going to do a little more research before I reach that point.
    Thanks again,
    -Ron
    Queen City Shaper
Similar Threads
  1. Drill Press Motor Repair Help
    By Tutt in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 05-26-14, 11:52 PM
  2. Motor and vari-drive repair or replacement with VFD?
    By Senna in forum QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 03-29-14, 05:18 AM
  3. lathe tool post repair
    By 12bolts in forum TOOL JUNKIES - TOOLS & TOOLING
    Last Post: 02-27-12, 07:19 PM
  4. Unimat motor repair
    By Tom Whitfield in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 08-17-11, 12:52 AM
  5. Clausing Lathe Compound Repair.
    By Old Iron in forum CLAUSING-COLCHESTER & LEBLOND
    Last Post: 01-07-11, 11:08 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
