Page 1 of 2 12 LastLast
Results 1 to 30 of 34
Thread: A DIY Press Brake for a hydraulic Shop Press.
  1. #1
    Tungsten Carbide xalky's Avatar
    Join Date
    Jun 2012
    City
    Naugatuck
    State
    Connecticut
    Country
    United States
    Posts
    1,622
    Tickets
    0
    Post Thanks / Like
    Chats
    9
    I made this press brake to fit on my HF 20 ton shop press. I thought I'd share it with you guys over here. I've seen several different variations of these for sale online at places like Northern Tool and on ebay. Some of them were pre-cut weld yourself kits others were already made. I had the steel laying around my shop so I decided to build one.
    So here's what it looks like complete:
    These are the parts mostly precut and ready for welding. The spring came from a storm door air cylinder that I had laying around. I cut it open to retrieve the spring.
    This is my Bridgeport hogging out the 60 degree wedge shape on the 1 1/2" x 3 1/2" piece of steel for the punch side of the brake. Some of the iterations of this brake I've seen only have an angle iron welded to the top punch to achieve the wedge shape or a 90 degree wedge shape but the result is that achieving a 90 degree bend is nearly impossible because of the flex-back of the material. With a 60 degree wedge on top a 90 degree + bend is easily achievable.
    Heres a picture of how it's put together from the side.
    It can bend up to 110 degrees. which is the reason why I put a 60 degree angle on the wedge to achieve the beyond 90 capability.
    I did most of this on a Saturday afternoon and finished welding it up the next Sunday morning. The longest part was hogging the wedge shape out on the Bridgeport at .040 bites at a time with a 1" carbide indexed end mill. I tried it with a larger HSS end mill and the result was way too slow for my taste. Gotta get me some of those Large indexable facing and hogging shell mills.
    Have Fun
    Marcel
  2. #2
    Global Moderator jumps4's Avatar
    Join Date
    Apr 2012
    City
    New Port Richey
    State
    Florida
    Country
    United States
    Posts
    1,989
    Tickets
    0
    Post Thanks / Like
    Chats
    6
    Re: A DIY Press Brake for a hydraulic Shop Press.
    nice job and it looks like it works good
    steve
    " Where There Is A Will... my kids want to be in it "
    " no brains no headaches "
  3. #3
    Join Date
    Jun 2012
    City
    Naugatuck
    State
    Connecticut
    Country
    United States
    Posts
    1,622
    Tickets
    0
    Post Thanks / Like
    Chats
    9
    Quote Originally Posted by jumps4 View Post
    steve
    Thanks Steve. I'm painting it up now. I'll post a pic complete.
  4. #4
    Join Date
    Jun 2012
    City
    Naugatuck
    State
    Connecticut
    Country
    United States
    Posts
    1,622
    Tickets
    0
    Post Thanks / Like
    Chats
    9
  5. #5
    Brass burnrider's Avatar
    Join Date
    Mar 2012
    City
    Oregon City
    State
    Oregon
    Country
    United States
    Posts
    227
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Nice job on the ever-versatile 'H' press
    Logan 200 Lathe owner since 1975
  6. #6
    Aluminum schemer's Avatar
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Hi,
    I am in the process of either buying a kit or making my own Press Brake but I have a question for those who have one and use it a lot. I need to bend some 1/8 aluminum sheet in a semi-circle that is conical in design. Picture a clamp that is used with EMT in a "C" shape including the flat for the bolt. Can this shape be bent in a press brake? If so, what order would you make the bends? I am assuming starting in the middle and work to one side then turn the piece around and do the same for the other side. I just don't want to have the piece get in the way of itself. Also, what die shape would be best? A 4 sided one with varying angles or just the plain 90 degree angle?
    Thanks,
    schemer
    p.s. Nice job on the Press Brake
    Thanks,
    Schemer
  7. #7
    Global Moderator Rbeckett's Avatar
    Join Date
    Sep 2010
    City
    Bronson
    State
    Florida
    Country
    United States
    Posts
    2,543
    Tickets
    0
    Post Thanks / Like
    Chats
    353
    Marciel,
    Lookin good there buddy. Any idea of the max thickness it will bend yet? That looks like a formidable chunk of alli in the pic of the over 90 degree bend. Keep up the great work!!!! And thanks for the really great pics, that really helps show a great project so others can give it a try too.
    Bob
    If you don't have something positive to say, keep it to yourself it makes you look so much smarter.
    Life Resolution--NEVER let my shop get cluttered again....EVER!!!!!
  8. #8
    Tool Steel Hawkeye's Avatar
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,404
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Okay, Zalky. That's one more for the project list. I got a "Does not work" 20 ton at the local tool store and made it work (at least up to 15 tons). A rig like that will make it very useful.
    Thanks for sharing.
    Mike
    Victoria U2 Mill w/ Vertical Head
    ZX25 Mill/Drill
    X2 CNC Mill
    Storebro Bruk Ornmaskiner 14 x 40 Lathe
    Hercus AR Lathe
    Louis 10" Shaper
    9 x 12 Horizontal Bandsaw
    Hobart Handler 140 MIG
    TIG / Plasma Cutter
  9. #9
    Cast Iron pineyfolks's Avatar
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by schemer View Post
    Hi,
    Thanks,
    schemer
    It can be done by step bending the radius then flipping to do the bend. A narrow piece of c-channel and a piece of flat bar with a piece of round stock welded to the edge for a top die will make a smoother radius. I use different width c-channels for all my bottom dies. If I need something tighter I drop some round stock in the c-channel, you don't need a bottom v- die when air bending just 3 points.
    Bill
  10. #10
    Tool Steel itsme_Bernie's Avatar
    Join Date
    Jan 2013
    City
    Roseland
    State
    New Jersey
    Country
    United States
    Posts
    1,392
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    OzzModz Classifieds
    2
    Thanks for the fantastic write up and pics Marcel!
    I just picked up one of these HF 20 ton presses from a guy nearby. I am in the process of tooling it up, please keep posting!
    Bernie
    Bernie
    Let's help each other with similar machines! Here's what I got:
    South Bend Heavy 10 Lathe -1965
    Hardinge TM Horizontal Mill - 1949 -- with RUSNOK ST Milling Head
    Sheldon 0 Mill -- with RUSNOK Model 70 Vertical Milling Head- 1955
    Sheldon 12 Inch Shaper
    Walker Turner 20 in Floor Drill Press 1100 -1950
    Hand-I-Hack Lipe Rollway Corp - 1950
  11. #11
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by pineyfolks View Post
    Pineyfolks,
    Thanks for the info.Do you have any pics? I was thinking of having a versatile press brake with changeable bottom dies like you describe. How are they held in place when you use a narrower C-channel? What size is the receiver for the bottom dies?
    schemer
    Thanks,
    Schemer
  12. #12
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Pineyfolks,
    schemer
    The base is 1 x 4 flat bar with a 3/8 key to locate the bottom dies to the base. Just key all your bottom dies and swap them as needed. My top is a 60 deg V. No reason you couldn't make the top die keyed for different dies too, that was my plan but I ran out of heavy stock
    Bill
  13. #13
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thanks pineyfolks,
    That is clear and a great solution to my question. May as well make it the most functional as I can from the get go. I appreciate the info.
    schemer
    Thanks,
    Schemer
  14. #14
    Brass
    Join Date
    May 2013
    City
    Savonburg
    State
    Kansas
    Country
    United States
    Posts
    239
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Press Brake dies are clamped in place by a 1/2" thick by 5/8" "tang" along the top of the die. Same for the bottom dies. Here are a couple photos of a top die and a sketch of the way they are held. Both top and bottom dies are made in sections to allow parts with lips to be bent.The one I have is 7/8" thick and about 4-1/2" tall. Just Google Press Brake die and you will find several photos of the tooling. Also check out ebay - literally tons of tooling for sale on there all the time. One interesting type of tooling is the Urethane bottom die. Check this auction out for starters. http://www.ebay.com/itm/PRESS-BRAKE-...item1c330e72cb and this one for Urethane tooling. http://www.ebay.com/itm/3-8-VEE-URET...item5657da9fb5.
    Attached Images Attached Images
  15. #15
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by SEK_22Hornet View Post
    Press Brake dies are clamped in place by a 1/2" thick by 5/8" "tang" along the top of the die. Same for the bottom dies. Here are a couple photos of a top die and a sketch of the way they are held. Both top and bottom dies are made in sections to allow parts with lips to be bent. Just Google Press Brake die and you will find several photos of the tooling. Also check out ebay - literally tons of tooling for sale on there all the time. One interesting type of tooling is the Urethane bottom die. Check this auction out for starters. http://www.ebay.com/itm/PRESS-BRAKE-...item1c330e72cb and this one for Urethane tooling. http://www.ebay.com/itm/3-8-VEE-URET...item5657da9fb5.
    SEK_22Hornet,
    Thanks for the added info on the dies and punch retention. I have looked at the ebay stuff and most of it is 5-8" but that stuff will work on appropriately sized projects. I did see the urethane pieces too but thought they were for thin sheet metal work. Maybe not.
    schemer
    Thanks,
    Schemer
  16. #16
    Brass
    Join Date
    May 2013
    City
    Savonburg
    State
    Kansas
    Country
    United States
    Posts
    239
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Here is link to a website that has lots of different tooling with dimensions and application information - looks like a good reference. It was in the ebay auction I linked to so i had to check it out -
    - - - Updated - - -
    SEK_22Hornet,
    schemer
    The dies are made so that you can end to end stack them - the shop where I used to work would buy 4' sections and cut them to smaller pieces on a power hacksaw. Especially the top dies. We made sheet metal parts out of aluminum and steel for our electronic products. Check out the urethane companies web site - it will surprise you what they say can be done with the urethane dies. If you are looking at bending much more that 16 gauge, I think you will find that you will need to beef up you dies to keep them from deflecting. Something like an A frame to hold the top die would help a lot.
    Dan
  17. #17
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Using sections of dies works great to bend boxes and such, just remember you're using a shop press not a brake so the load must stay centered under the ram or things will get ugly.You can also place pieces of cardboard between the top die and the work piece on one side to adjust a long piece to bend the same on each end.
    Bill
  18. #18
    Bronze astjp2's Avatar
    Join Date
    Aug 2013
    City
    Pleasant View
    State
    Utah
    Country
    United States
    Posts
    354
    Tickets
    0
    Post Thanks / Like
    Chats
    1
    We use dies like this at work in our 60 ton press brakes, you can get them with different radiuses, the amount of distance the top die is pressed into the bottom die will dictate the bend. If you make a back gauge, you can then make the same bend distance multiple times. You also should put grease zerks on the bolster pins so you can lube the upper die. Tim
  19. #19
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    @Pineyfolks:
    Seeing I have to run to the steel store Thursday, what size c-channel do you use? I looked online and the stuff less than 3" wide gets too thin at 1/8" thick. I was going to buy a piece of 3" and try to use it as the base with round steel bars and also as the receiver for the bottom dies like angle iron etc. I figure with a little planning at the start I can make it very adjustable as far as make a new die as needed.
    Thanks,
    schemer
    Thanks,
    Schemer
  20. #20
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I use 3" and 4" channel for heavy material. 3" works great for me for 1/4" material. I made a bottom die with a 1" slot for 12ga. material and less. You can add some round stock inside the channel too. I also have a pointer next to my jack and a scale held on the side of the jack with magnets to use as a depth gauge for repeatable bends. I shot you some pics but I don't want to hijack this thread, just give you guys some other options when building.
    Bill
  21. #21
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Very nice. Thanks for the pics and added info. Looks great! I appreciate it.
    schemer
    pm sent
    Thanks,
    Schemer
  22. #22
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    schemer
    pm sent
    schemer , here's a pic of some of my bending stuff just to give you some ideas I've got more, I was getting tired dragging it out
    Bill
  23. #23
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Looking good. Thanks for the pics. I am sure my first one will not be my only one.
    schemer
    Thanks,
    Schemer
  24. #24
    Join Date
    Jun 2011
    City
    Kelowna
    State
    British Columbia
    Country
    Canada
    Posts
    1,404
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I got a start on a 10" brake, thanks to your thread. After what you said about many slow passes with an end mill, I decided to take the vertical head off my Victoria. I'd only done horizontal milling once before - a few T-nuts for the 'new' mill.
    I have to admit, I like being able to take the whole bevel in one pass. Turn the work around to make both sides match. I set up the arbor for three operations, just by moving the work for each one. The second operation was to round the crown slightly with the right-hand cutter.
    The final operation added another 15o to the bevel on each side to make it a bit closer to round. I might blend the three operations with some emery strip.
    Mike
    ZX25 Mill/Drill
    X2 CNC Mill
    Hercus AR Lathe
    Louis 10" Shaper
    TIG / Plasma Cutter
  25. #25
    Cast Iron DAN_IN_MN's Avatar
    Join Date
    Aug 2013
    City
    Green Isle
    State
    Minnesota
    Country
    United States
    Posts
    674
    Tickets
    0
    Post Thanks / Like
    Chats
    8
    I've been looking for an example on how to finish my press that I started about 4 years ago!
    The rollers running on the verticals is a good answer. What size of steel are you using for the horizontal jack support?
    Machinery:
    Vertical knee mill
    12" Clausing Lathe 6307 .
    Run/program CNC Torchmate3: Capacity 3/4 thick 60 X 120 sheet size. (Not my machine.)
    Hammer
    Adjustable wrench.
    A little about me LINK
    <----GREEN ISLE WEATHER
  26. #26
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by DAN_IN_MN View Post
    DAN, The top and bottom channel are 8". The plate above the jack is 1". The whole thing bolts together (with grade 8 bolts )so parts can be replaced if something gets bent.
    Bill
  27. #27
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Does anybody know the specs on the springs and where to get some? I have decided to use 3/4" posts so I need springs to fit over them but am unsure on the length and load specs. I will be using a 1" x 4" x 20" piece of steel for the top die.
    Thanks,
    schemer
    Thanks,
    Schemer
  28. #28
    Join Date
    Apr 2012
    City
    Dillonvale
    State
    Ohio
    Country
    United States
    Posts
    533
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I got my springs from old motorcycle shocks, I think an 80 or 100cc something small. If you have to, cut them so you don't compress them to far. You can also search for die springs on ebay.
    Bill
  29. #29
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I was looking at die springs and motorcycle fork springs today. Then I realized I have an old set that may work.
    Thanks,
    schemer
    Thanks,
    Schemer
  30. #30
    Join Date
    Mar 2011
    City
    Crestview
    State
    Florida
    Country
    United States
    Posts
    73
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Hey Piney,
    On the slot for the 3/8" key in the base, did you mill the whole .375 depth? Just curious now that I have milled .1875 in the base thinking of the old regular key slot thinking, but soon realizing the channel isn't thick enough to mill .01875 for the other half as it is only .1875 thick. Probably easiest to mill the .375 instead of messing with the key stock later on the attachments but I thought I would ask just in case. My base is 1.00 thick by 4.00 wide.
    Thanks,
    schemer
    Thanks,
    Schemer
Similar Threads
  1. Older 10T Hein Werner Air over Hydraulic Press - service
    By br-549 in forum OTHER PROJECTS, INCLUDING WOODWORKING
    Last Post: 03-13-14, 12:34 PM
  2. Another Press Brake
    By Hawkeye in forum SHOP-MADE TOOLING
    Last Post: 10-21-13, 10:26 PM
  3. homemade press brake
    By ecdez in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-14-13, 06:52 PM
  4. Press brake
    By McRuff in forum TOOL JUNKIES - TOOLS & TOOLING
    Last Post: 01-30-12, 11:01 AM
  5. Hydraulic Press made from HF Press
    By Nels in forum TOOL JUNKIES - TOOLS & TOOLING
    Last Post: 04-13-11, 11:22 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
