Results 1 to 9 of 9
Thread: How to rewire a 3 phase motor for low voltage (230V)
  1. #1
    Founder Nels's Avatar
    Join Date
    Sep 2010
    City
    Queens
    State
    New York
    Country
    United States
    Posts
    5,460
    Tickets
    0
    Post Thanks / Like
    Chats
    246
    Total Downloaded
    5.59 MB
    My Feedback
    (0% Positive Feedback)
    Sometimes, you apparently need to rewire a 3 phase motor for low voltage (230V as opposed to 460V) in order to connect the motor to a VFD. This apparently involves the windings and associated wire configuration.
    How is this done?
    I am lost, and have never touched motor windings before.
    Thanks,
    Nelson
    My toys: South Bend Heavy 10L Lathe (1978), Burke #4 Milling Machine (1946), Van Norman #12 Milling Machine (1942), South Bend 14" Drill Press.
  2. #2
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    Re: How to rewire a 3 phase motor for low voltage (230V)
    Maybe this will help, Nelson.
    "A man who works with his hands is a laborer. A man who works with his hands and his brain is a craftsman. A man who works with his hands, his brain and his heart is an artist."
    -Louis Nizer
  3. #3
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    Yep Turbo, that's exactly what that is. It was the simplest way to provide the basic information. I've wired more than a few myself. Always the plate rules though. I've seen rewinders come back with some weird variants that they failed to document. Had to call them up to get the real story.
    Everybody should have a yellow UGLY book.
    -Louis Nizer
  4. #4
    Join Date
    Sep 2010
    City
    Queens
    State
    New York
    Country
    United States
    Posts
    5,460
    Tickets
    0
    Post Thanks / Like
    Chats
    246
    Total Downloaded
    5.59 MB
    My Feedback
    Another stupid newbie question- you manually relocate the brass windings? What happens if the brass wire breaks (anticipating all-thumbz at it again)- do you need to buy magnetic wire of the correct gauge to replace it?
    I sure could use a video showing someone doing this- there was one on Youtube-
    in which an old motor is repaired, but it wasn't very clear.
    The reason I raise this is because there is a Youtube video, actually, a set of 5, by a user called "CVMikeRay" about hooking a VFD to his 13" South Bend, and the first step he does is to rewire his motor to "low voltage" (230) as opposed to 460. He lost me right away as to (a) why he would need to do that, and (b) exactly how he did it.
    Thanks.
    Nelson
  5. #5
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    I know of no brass wiring in the "peckerhead" as we say in the south. There should be 9 insulated wires coming out of the windings into the connection or termination box. Those are numbered, usually with poultry rings or some such. They will be paired up according to one of the diagrams above. You should make sure you can read all the numbers before you disconnect anything. That will tell you for sure what voltage it is currently set up for and whether delta or star. The windings themselves are enameled magnet wire, but you won't normally need to mess with them directly, only the insulated pigtails in the box.
    -Louis Nizer
  6. #6
    Join Date
    Sep 2010
    City
    Queens
    State
    New York
    Country
    United States
    Posts
    5,460
    Tickets
    0
    Post Thanks / Like
    Chats
    246
    Total Downloaded
    5.59 MB
    My Feedback
    Ah, I understand. I have seen those. Sometimes on old machines not in good shape. Then I would need to know how to test to find out what goes where.
    What is delta and star?
    Thanks,
    Nelson
  7. #7
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    Delta and star (or wye) is the method of connecting the windings of the motor. It has to be compatible with the phase relationship of the supply. In a VFD change, don't worry about it, just go with the way it is currently. It would only matter if you were moving to an area of the world or country that had a different scheme than home. Sorting out unmarked pigtails is not simple. A motor shop may need to get involved then.
    -Louis Nizer
  8. #8
    Lost Pup
    Guest
    Question?
    With a dual voltage 3 phase motor do you wire it to 240 or 480 ?
    I have a Teco Jnev 101 to connect to a dual voltage Baldor 3 phase motor. Is there a benefit to either high or low if the VFD will operate it?
    The Baldor is setup to the high voltage out of box.
    Thanks
  9. #9
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,650
    Tickets
    0
    Post Thanks / Like
    Chats
    57
    Total Downloaded
    0
    My Feedback
    A quick look at that VFD unit tells me it should not handle anything but 110 motors, so I'm not sure it will run a 240/480 motor.
    -Louis Nizer
Similar Threads
  1. 3 phase motor starts automagically on 1 phase power??
    By rogerrabbit in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 03-05-13, 11:08 PM
  2. TEMCo How To: AC 120v Single Phase to 230v Three Phase VFD
    By Nels in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 01-28-13, 10:03 PM
  3. Run 3 phase motor with single phase power
    By ralugo5 in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 06-21-12, 09:03 PM
  4. How do I rewire or convert a 115volt to 230 on Emerson 1HP motor single phase
    By Johndrew in forum ELECTRICAL ISSUES - POWERING YOUR MACHINES & SHOP (PHASE CONVERTERS, VFDS, ETC.)
    Last Post: 01-13-12, 09:42 PM
  5. Motor overheating at lower voltage. Why?
    Last Post: 07-09-11, 07:45 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
