Results 1 to 14 of 14
Thread: Picked up my first bandsaw- Problems already
  1. #1
    Plastic
    Join Date
    Apr 2011
    Posts
    22
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I just picked up a rong-fu RF-115 4x6 bandsaw today for $50. Guy was nice, I did a test cut and even though it did not cut quite straight, it cut through 2" solid round 6061. Brought it home and tried three times, and all three times the blade binded and stalled the motor.
    I am brand new to horizontal band saws, and have no idea where to start to get it to work, and cut straight. Does anyone have a manual for this machine?
    thank you to anyone who can help
    Attached Images Attached Images
  2. #2
    Cast Iron 7HC's Avatar
    Join Date
    Jul 2012
    City
    Tampa
    State
    Florida
    Country
    United States
    Posts
    683
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Re: Picked up my first bandsaw- Problems already
    Quote Originally Posted by billsnogo View Post
    Assuming you were cutting a similar piece of stock, you were probably either running too slow, or had too much downforce on the workpiece.
    You adjust the downforce with the horizontal spring.
    Grizzly probably has the best manual for these bandsaws: http://cdn0.grizzly.com/manuals/g0622_m.pdf
    M
    Edit: Looks like someone has replaced the motor with a bigger one (good thing), and left off the belt guard (bad thing).
    Always Learning!
  3. #3
    Plastic
    Join Date
    Apr 2011
    Posts
    22
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by 7HC View Post
    M
    You are correct, the motor is a 3/4hp motor. I will try and adjust the speed and tension
    Quote Originally Posted by sssfox View Post
    I've never stalled the motor on mine. Maybe it would be beneficial take the blade and belt off and see if there is some friction in the gearbox that shouldn't be there.
    When the blade starts to wear out, it cuts crooked because the teeth always wear more on one side than he other.
    Try a new blade, preferably one with less teeth.
    By the way, you got a good deal.
    I will also try out a new blade. Hopefully I can get this working for me.
    thanks guys
  4. #4
    Global Moderator Rbeckett's Avatar
    Join Date
    Sep 2010
    City
    Bronson
    State
    Florida
    Country
    United States
    Posts
    2,538
    Tickets
    0
    Post Thanks / Like
    Chats
    352
    Bill,
    There is a 4X6 group on Yahoo that has an excelent tune and true procedure for the RF style bandsaws. It takes about an hour to do and really makes a huge difference in the usability of the saw. If you have any problem finding it PM me and I will ask that group if I can copy it and add it here with the appropriate credit to the author and site it came from. I did it to my HF saw and it made a world of difference. I can cut stright and about as thin as a quarter with no misalignment or issues. Hope this helps get you straightened out and cutting good again.
    Bob
    If you don't have something positive to say, keep it to yourself it makes you look so much smarter.
    Life Resolution--NEVER let my shop get cluttered again....EVER!!!!!
  5. #5
    Aluminum twowheelinjim's Avatar
    Join Date
    Aug 2012
    City
    Greensboro
    State
    North Carolina
    Country
    United States
    Posts
    57
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    That's a good little find. Every time I look for a used bandsaw, I can't find one or the ones I find are priced higher than the new ones. I know I'll probably just buy a new one from HF but prefer an older one. Good luck with your saw; you may not have to worry about hacksaw elbow for quite a long time.
  6. #6
    Bronze Pacer's Avatar
    Join Date
    Apr 2011
    City
    Greenwood
    State
    NW La
    Country
    United States
    Posts
    442
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    First - that buy just about rates a gloat - good score, youre gonna love that thing...
    Probably more than one factor involved here with the binding -
    The blades origin/condition is an unknown to you, plan on replacing it soon with a bi-metal in something like a 10-14tpi (thats a pretty good general purpose tpi for the home shop)
    Aluminum can be problematic - it can want to 'clog' the blade teeth and cause binding (back to condition of blade??)
    The saw does probably need a check for alignment -- do get over to the yahoo group and check in - along with alignment tips there are lots of mods that are well worth doing.
    I did a quick check of my pics and found this one of a simple method of helping align the blade to the bed of the saw (critical for a straight cut) The two 3 bearing guides will have a little bit of slack/looseness in them to allow aligning of the blade with a square - the little piece of metal clamped to the blade gives more area for the square to align with and allowing easier adjusting.
    You can also see a couple of my mods in this pic - I extended the rear vise jaw to get it closer to the blade allowing smaller pieces to be clamped closer to the blade. Also added a 'permanent' small table that I can leave on all the time, and the piece of box aluminum for table extension...
    Great shop tool - that little saw (For the sharp eyed, thats is one of the 'swivel' saws, but much of it is like the 4x6)
  7. #7
    Plastic
    Join Date
    Apr 2011
    Posts
    22
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Thank you all. Late response as I had not needed to use it again until today. I cut a piece of 4" round 6061, and it cut pretty good. The max difference is 1/8", and even that is being pessimistic. The previous owner used wax to lubricate the blade and it clogged up the guides REAL bad. Cleaned them, new blade and it seems much better.
    Only complaint is when you get the guides as close to the workpiece as possible, they prevent the blade from dropping all they way so it will not cut all the way through without stopping and adjusting the guides back.
    Now I am waiting for the 4" four jaw chuck for the mini-lathe to come in the mail and see how hard it is to turn this 4" down to 3.5 for an adapter for my encoder on my servos.
  8. #8
    Cast Iron
    Join Date
    Jun 2011
    City
    Brookshire
    State
    Texas
    Country
    United States
    Posts
    595
    Tickets
    0
    Post Thanks / Like
    Chats
    6
    With a few tweaks, that little saw will soon be some of the best money you can spend on tools! As mentioned before, please check out Yahoo's 4 x 6 Band Saw Group files as there is a wealth of data on there. Also, in case you have not already checked, pull the cover on the gear box and check the oil. Many have found unsuitable gunk in their saws gear boxes straight from the factory and it is very easy to drain, wash/clean, and refill with a high quality gear oil. Also check the main blade wheels for roundness and make sure you have proper tension on a quality blade before you adjust the guide wheels!
    Good Luck!
    Ray
  9. #9
    Brass
    Join Date
    Oct 2012
    City
    casa grande
    State
    Arizona
    Country
    United States
    Posts
    159
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    I picked one up a few weeks ago and don't know how I have been getting along without it. I used it all the time. The only problem I have had so far is the blade coming off. I did some adjustments and slowed the feed rate and hopefully this will not continue. Enjoy, and join the Yahoo group.
  10. #10
    Plastic
    Join Date
    Oct 2012
    City
    Somewhere
    State
    Manitoba
    Country
    Canada
    Posts
    33
    Tickets
    0
    Post Thanks / Like
    Chats
    20
    The belt on the pulleys is set to go the fastest speed. try slowing down the blade speed.
    John
  11. #11
    Plastic
    Join Date
    Feb 2013
    City
    Dartmouth
    State
    Nova Scotia
    Country
    Canada
    Posts
    28
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Recommend that you check the condition of the oil in the gear box. My second hand saw had very little oil in it due to no maintenance by the p.o. I cleaned out the old oil and filled it with new. Fortunately the gears were in good shape. Follow that manual provided above. I used the steel box cover as a pattern to cut out a new one from plexiglas so now I can easily see the oil level. Views are before running and during a cut.
  12. #12
    Tungsten Carbide ScrapMetal's Avatar
    Join Date
    Apr 2011
    City
    Elkhorn
    State
    Nebraska
    Country
    United States
    Posts
    1,735
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Quote Originally Posted by prmindartmouth View Post
    I like that idea! I'll be "borrowing" that to do on my little ChiCom saw.
    Thanks much,
    -Ron
    South Bend 11" Lathe
    Wells-Index 860 Mill
    Queen City Shaper
  13. #13
    Global Moderator darkzero's Avatar
    Join Date
    Nov 2012
    City
    Los Angeles
    State
    California
    Country
    United States
    Posts
    844
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    OzzModz Classifieds
    1
    Is that actually oil or is it grease?
    -Will-
  14. #14
    Plastic
    Join Date
    Feb 2013
    City
    Dartmouth
    State
    Nova Scotia
    Country
    Canada
    Posts
    28
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    It is 140 wt lube, been in the saw for a few years.
Similar Threads
  1. Threading problems? Lathe problems?
    By Charley Davidson in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 03-28-14, 08:18 AM
  2. New Brideport 2J I picked up
    By The_Crusher in forum BRIDGEPORT & B'PORT CLONES
    Last Post: 12-22-13, 01:13 PM
  3. I just picked this up Sunday.
    By pipehack in forum ATLAS & CRAFTSMAN MACHINES
    Last Post: 09-12-13, 11:39 AM
  4. picked up one of the today off CL
    By rafe in forum SHELDON, LOGAN & ROCKWELL MACHINES
    Last Post: 08-01-13, 02:10 AM
  5. 9x 16 horizontial bandsaw problems
    By jester69 in forum ANTIQUE, VINTAGE, & OTHER TYPES OF MACHINERY
    Last Post: 10-11-12, 12:29 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
