Results 1 to 16 of 16
Thread: Adapting a dial thread gauge Metric Vs imperial
  1. #1
    Plastic piscov's Avatar
    Join Date
    Dec 2012
    City
    Odivelas
    State
    Outside US / Canada
    Country
    Portugal
    Posts
    38
    Tickets
    0
    Post Thanks / Like
    Chats
    6
    Hello all,
    I have a Optimum 180X300 lathe with metric set up but that can also do some thread sizes in Inches .
    My problem is that this a a very basic lathe and does not have the dial thread gauge to help me threading. I am doing the threads by "eye" and some times I make mistakes.
    My question are:
    1) Can I adapt a dial thread gauge on my lathe? I think that yes,I can, and this lead me to the next question:
    2) Will it work when I am doing an Imperial thread for instance 36TPI, or its going to work only when I am doing metric threads?? ( I am assuming i can only install a metric dial gauge as my lead screw is metric.
    3) is this easy to install?
    Best regards
    Vasco
  2. #2
    Steel 12bolts's Avatar
    Join Date
    Apr 2011
    City
    Hinchinbrook
    State
    Queensland
    Country
    Australia
    Posts
    1,052
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Re: Adapting a dial thread gauge Metric Vs imperial
    Vasco
    A thread dial allows you to pick up the leadscrew in the same place each time you engage the half nuts. Depending on the thread pitch you can engage it at different segments of the dial indicator.
    If you are making/adapting a thread dial for your lathe then the number of teeth on the dial gear will affect how/where you can engage it on your lathe. However if you only re-engage the half nuts on the same mark on the dial each time then you should be good to go. It may be a little slower waiting for the mark to come around, but it will be faster than reversing back to the start each time.
    Cheers Phil
    Users should consult the PDS before considering whether the advice contained is suitable for their personal situation.
  3. #3
    Brass JT.'s Avatar
    Join Date
    Jul 2012
    City
    boortmeerbeek
    State
    vl-brabant
    Country
    Belgium
    Posts
    102
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    from what i now you can not use the metric thread dial for imperial threads
    ore visa versa the problem is not the dail but the leadscrew it never returns to the exact place
    so the treads will change every cut
    so you need to keep the halfnut ingaged al the time and reverse the motor to go back
    if you got no ververse direction on the lathe you need to do it by hand ore change the feed direction
    please correct me if I am rong
  4. #4
    Administrator Tony Wells's Avatar
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,538
    Tickets
    0
    Post Thanks / Like
    Chats
    53
    That is how you must do it to cut Metric on most Imperial lathes, so it seems reasonable that it would work the same the other way around.
    Late to bed, early to rise puts big dark circles under your eyes! Author - Me!
  5. #5
    Join Date
    Apr 2011
    City
    Hinchinbrook
    State
    Queensland
    Country
    Australia
    Posts
    1,052
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    As I understand it, if you try to use the segments on the dial you wont pick up the same spot on the leadscrew but if you only use the one same mark on the dial each time then it should be ok to use.
    But I stand to be corrected
    I will have to try this on my lathe and see what happens
    Cheers Phil
  6. #6
    Tool Steel GK1918's Avatar
    Join Date
    Nov 2010
    City
    No. Dighton
    State
    Massachusetts
    Country
    United States
    Posts
    1,261
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Phils right, although I am not into metrics but I think the lathe doesnt care what threads are being cut.
    Its just a matter of timimg. The feed screw, the half nuts do not change, rather its the when and where
    to engauge half nuts. Dials are like a vehicle speedometer a driver (feed screw) driven the dial. One
    of my SBends never had one (dial) way over priced so I put an Atlas dial (dime a dozen ebay). Problem
    is Atlas dial gear is a lot smaller and less teeth than the correct one, so what happens is lines and
    number will not work. But it does work only on ONE mark. What I do is turn chuck by hand and when
    the half nut slides in, I will engauge the mesh on the dial on say No.2. And No 2 will be the number
    through out the operation. I write this if you wish to make your own. I use to run a speedometer
    cable off the leed screw to a cardboard dial with a pointer it did work, didnt look good, then the old
    timers use to paint gear teeth at engaugement points. Also I was never a beleiver in reversing the
    machine that only puts more wear Now, on both sides of the half nuts. samuel
  7. #7
    Join Date
    Dec 2012
    City
    Odivelas
    State
    Outside US / Canada
    Country
    Portugal
    Posts
    38
    Tickets
    0
    Post Thanks / Like
    Chats
    6
    Quote Originally Posted by 12bolts View Post
    Cheers Phil
    Hi Phill,
    If you could try it would be great. Please let me know.
    I will only buy the dial thread if I'm certain it will do the trick. The threads I need to do have 3-5 mm long and no more than 1 mm deep. Maybe I will be ok doing JT says. I will not even use the motor, I will rotate by hand. This threads are made on plastics.
    Cheers
    Vasco
  8. #8
    Brass JT.'s Avatar
    Join Date
    Jul 2012
    City
    boortmeerbeek
    State
    vl-brabant
    Country
    Belgium
    Posts
    102
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    i wonder how mutch wear will occure on the half nut after backing up the cutter en reversing the machine
    i tought it was that way most modern machines are used to cut threads
    another thing he will not need the dail
  9. #9
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,538
    Tickets
    0
    Post Thanks / Like
    Chats
    53
    Normally, the half nut is disengaged at the end of the thread, and the carriage is run back to take another pass, with the thread chasing dial used to synch the half nut to the previous pass.
    For such a shallow cut in plastic, I'd be tempted to do it all in one pass, once I have proven what the DoC should be. Not necessary to hand feed it, unless you are very close to a shoulder and don't feel comfortable under power. If done in a single pass, no thread chasing dial needed at all.
  10. #10
    Plastic
    Join Date
    Jun 2012
    City
    Abbotsford
    State
    British Columbia
    Country
    Canada
    Posts
    28
    Tickets
    0
    Post Thanks / Like
    Chats
    0
    Something that helps clarify the concept of a thread dial is to set a ruler on the ways and with the power off and thread dial engaged move the carriage noting the inches of travel and what numbers are indicated on the thread dial. Conventionally one number on the dial represents one inch of travel..... but not always if the lead screw has an unusual pitch. When operating that dial is simply an imaginary ruler travelling down your threaded piece.
    Logically if you are cutting threads per inch you can pickup on every inch. You cannot pickup on a half inch mark on the thread dial if you are cutting 11 threads per inch because you would be five and a half threads along your work. Having a imperial thread pitch on your lead screw prevents you from picking up on a metric thread. If you had a 3 mm pitch lead screw you could easily pickup on threads that were a multiple of 3mm such as 6mm but you would have difficulty picking up on a thread pitch of say 2 mm.
  11. #11
    Join Date
    Dec 2012
    City
    Odivelas
    State
    Outside US / Canada
    Country
    Portugal
    Posts
    38
    Tickets
    0
    Post Thanks / Like
    Chats
    6
    Thank you all! You have been very helpful.
  12. #12
    Join Date
    Apr 2011
    City
    Hinchinbrook
    State
    Queensland
    Country
    Australia
    Posts
    1,052
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Hi ya Vasco,
    Sorry I was a bit slow getting to this.
    Quote Originally Posted by piscov View Post
    Hi Phill, If you could try it would be great. Please let me know.
    The thread chasing dial will work on any thread, provided you only use the one same mark on each engagement of the 1/2 nuts. The leadscrew/carriage relationship does not care whether you are machining a 3TPI acme, 14TPI whitworth, or 1.0 mm, (which in effect is just a 25.4TPI) anyway.
    --->JT The point of the exercise is to avoid having to wait for the carriage to travel back to the starting point to recommence the next pass, not to reduce nut wear. Also something that is a pain to do if you dont have reverse on your lathe. Cranking the drive pulley backwards gets real old real fast.
    Cheers Phil
  13. #13
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,538
    Tickets
    0
    Post Thanks / Like
    Chats
    53
    Phil, just out of curiosity, did you do this experiment on your lathe? If so, please remind me of what kind of lathe you ran it on. I've not done the Imperial on a Metric lathe thing before, but on an Imperial setup Mazak, even using the same number on the chasing dial, it never tracked the Metric thread the same way twice.
  14. #14
    Join Date
    Apr 2011
    City
    Hinchinbrook
    State
    Queensland
    Country
    Australia
    Posts
    1,052
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Tony,
    I have a change gear Hercus 9". It is an imperial lathe, and has had some mods done to it over the years, (some by me, others not by me). My chasing dial is not original (I dont think). Yes I did run it on my lathe. Although I only scored the thread on some ally rod, disengaged, wound back, re-engaged, and followed the previous score exactly. No compound movement. I didnt complete the full thread. Now you got me thinking maybe I was just lucky
    Cheers Phil
  15. #15
    Join Date
    Jan 2011
    City
    Tyler
    State
    Texas
    Posts
    5,538
    Tickets
    0
    Post Thanks / Like
    Chats
    53
    No Phil, I doubt it. I was just working over in my mind how the Mazak could have been geared differently. Of course, Yamazaki lathes are Japanese built, so I would presume they are natively Metric, and those sent to Imperial-land are geared to cut Imperial threads. But then, it's been quite a while since I scrapped....I mean re-worked those parts for Bell Helicopter. I took 2 or 3 passes before I saw it was not re-tracing the thread. Ended up doing the forward and reserve thing to cut the parts.
    There was probably more to making that lathe properly cut Metric than I knew at the time.
  16. #16
    Join Date
    Apr 2011
    City
    Hinchinbrook
    State
    Queensland
    Country
    Australia
    Posts
    1,052
    Tickets
    0
    Post Thanks / Like
    Chats
    2
    Quote Originally Posted by Tony Wells View Post
    No Phil, I doubt it. .....There was probably more to making that lathe properly cut Metric than I knew at the time.
    Nontheless Tony I think I will go back and redo that test, but actually cut a full thread......Dont want to be putting wrong info out there....
    cheers Phil
Similar Threads
  1. Imperial thread sizes on Myford lathes?
    By Ockert in forum BOXFORD, MYFORD, DENFORD VICEROY, EMCO & UNIMAT MACHINES
    Last Post: 03-23-14, 09:40 PM
  2. Modifying thread cutting dial to do metric?
    By Nels in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 02-10-14, 09:26 AM
  3. Building a thread chaser dial for a metric lathe
    By rljones in forum MACHINE ACCESSORIES - QUESTIONS & ANSWERS
    Last Post: 02-08-14, 06:32 PM
  4. Adapting 9/10K Thread Dial For Heavy 10?
    By Splat in forum THE SOUTH BEND MACHINERY FORUM
    Last Post: 06-24-12, 03:42 PM
  5. Boxford Model A Imperial/Metric screwcutting workbook
    By MosfetMeltdown in forum GENERAL MACHINING -- QUESTIONS & ANSWERS -- GET HELP FAST HERE!
    Last Post: 08-24-11, 08:51 AM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
