+10 for McMaster-Carr
I've been slowly replacing my worn out drill bits from McMaster-Carr since I don't have a sharpener. I've been buying the TiN-Coated Split-Point HSS ones. They are awesome. They cut beautifully. The website doesn't state a brand, but they've all been Chicago-Latrobe brand.
I've been other items from them such as metal stock and bolts and screws. I needed some fully-threaded bolts and they were hard to find. MC had them.
I get my orders in a day since they have a warehouse in south Jersey.
I have just had a wonderful experience with McMaster-Carr.
I’m just a small-time garage hobbiest. All thumbs and no talent. But I enjoy it. I spend, max, total, all-in, maybe a $500 a year on the hobby.
I had a need to make a few cuts through a 6x6x8” block of silicon. (Not silicone). I read that a diamond blade could do it. None of the machine shops in the area (I called 27) had such a blade, could cut silicon, or could give me a reference to who could. A high-end water-jet shop said they also could not. Yeah, I’ve heard of EDM or such, but I ran out of energy trying to find a shop in my area able, and willing to do for a hobbiest.
So, I bit the bullet and decided I’d try it myself. After some internet clicking I found three sources of diamond blades for my 4x6 HF bandsaw. $120, $130, and $140. And, I had no way to evaluate them further. Well, I had had a couple of generally positive experiences with McMaster-Carr (I normally am more of a Harbor Freight and EBay Chinesium sort of fellow) so, spent the extra $20 and ordered the $140 McMaster-Carr blade.
I think they must send the order out to some shop—I don’t really know who makes it for them. But, two weeks later (as they said), the blade shows up.
Much to my amazement, it cuts the silicon very nicely. (No, not the 6x6x8 block—that was too big for the 4x6 no matter how I worked to properly support it. I put a diamond blade on a 12” sliding miter saw and made the initial cuts with that. (No cooling/lubricant) Large chip-out (like up to 1/2” chips) no matter how slowly I entered or how light the pressure. The 14amp motor and blade I bought cut at a square inch every two minutes. Slow. Took a while to get a 6x6 slice. But, it did work to get down to 4x6 band saw size.). The $140 diamond blade, on the $200 HF saw, cut silicon quite nicely. Almost no chip-out. Slow, but, I’ve got time.
So, I am cutting up some silicon pieces. Generally cutting 2” wide pieces and 6” deep. 12 square inches a cut. (About 2 minutes per square inch. I have not explored more pressure—am using as much as I normally use and know that my blades all stay straight) Got in 4 nice cuts. And, midway through the 5th cut, the blade broke. The $140 blade, broke. Nothing special about that cut. No twisting. No funny sounds.
OK, not like I lost my life savings or anything. But still, for my budget, this was a significant disappointment. (I was still just getting pieces down to proper project size—so, still needed to do another dozen cuts)
Well, I emailed McMaster-Carr. (Yes, this project report is about them) and asked if they could repair (it was a clean break, seems like someone with a blade welder could fix it right up) or if there was some sort of warranty on it. (I have never heard of a warranty on a consumable, like a saw blade, but heck, it is worth asking.)
Much much to my surprise McMaster-Carr agreed that a properly used blade should not have broken at 50 square inches of cutting, and said they would send me a (free) replacement!
I was gobsmacked. And, today (10 days later), the new replacement blade showed up. Not only zero charge, even for shipping, but zero paper work needed on my part. Wonderfully amazing.
This is simply exceptional customer relationship management. I am so glad I bought from them and, for my non-Chinesium purchases, purchases that are investments, and not disposable, I am certainly going to keep buying from them.
Yeah, McMaster-Carr is a big company. I have no doubt others have experienced them in a negative way at some point. But in this instance, they gave absolutely A+ service.
Oh, and when I finish my little silicon project, yes, I will post.
-Bill
I've had similar responses from McMaster. And, their technical people are very responsive and helpful when I call them.:)
agreed - but those &#%@^-ers still won't sent me a catalog!
If you spend the minimum of $50,000.00 per year they'll be more than happy to send you a catalog. Personally I don't understand the fascination with McMaster catalogs. I used them for years and much prefer the online system. Prices and inventory change regularly and there's no way for the catalog to reflect them.
I hated making an order then getting a call a couple hours later telling me my PO wasn't enough to cover the order, or the item was "temporarily out of stock". Then I'd either have to make an addendum to the PO, or write a whole new one. With the online system the prices and inventory are far more accurate.
The catalog is more of a Trophy than anything else. I gave up a parking space for mine. Fool doesn't know what he gave up in prestige points. I don't mind, I needed the extra steps each day.
I guess it was last year when I placed an order and of course received it the next day. I just have McMaster bill my credit card. Well I hadn't realized that the card on file had expired. They sent me an email to update it. They could have held my order until I updated the new card info but instead just shipped it out. How awesome is that.
Because I once had a business (sole proprietor engineering consulting, but I had a tax ID), I have an open account with them... they send me stuff, they send me a bill afterwards, my wife pays it. :love:
I order from Mcmaster often... usually I just add stuff to my cart until I have a large enough order to justify driving over and picking it up. I live @ 30 miles or so from the Douglasville, Ga warehouse.
Their warehouse is massive! I don't know how many square feet it is, but its a lot!
-Bear
Tell me Bill, what are you doing with the pieces of silicon once you have them cut to size?
We all have our own fetishes...
I am an element collector. In particular 1”x2”x6” bars. I’ve posted on this before. I work to scrounge affordable (and safe) elements. (Of course, you can just go buy whatever you want, for a price. I work to do it on the cheap.). I have 15 done and on the mantel. Another half dozen are in some stage of process. One of which is silicon. Each of the elements has characteristics surprisingly unique. They all (excepting copper) are basically just grey. But start handling them, or better yet, melting or machining them, and wow, each its own personality that makes you smile with wonder. Yes, Tin “creaks” when in a vise, but so does Bismuth (not quite as loud). Antimony, when machined, sprays out the most deadly, sharp sharp jagged microscopic dust—nasty stuff. Cadmium shrinks a tremendous amount when it freezes—you can watch the shrinking in real time. Fascinating. And on and on. I’ll write more about observations on each another time. Well, I happened to get a good deal on a 6x6x8” piece of silicon. (Go go Ebay) Now I need to cut it down to 1x2x6. This has been a wonderful adventure. A bit more spendy than I was planning, but I sure have learned a lot. Basically, with my silly hobby equipment (and a $140 diamond blade) I can cut silicon now. So, I am making a bar. To go with a score of others. I’ll post an updated picture after this next batch is done (Sulfur (yes, amazing, but you can make a bar of sulfur), silicon, selenium (sort of like obsidian, but melts at just 450F (and I’ll talk about the smell and the reaction with aluminum I discovered accidentally)), manganese (I think my kiln can melt it to shape—we’ll see after the extra insulation arrives), zirconium (supposedly coming from the middle of China somewhere—I’m not sure, maybe I am getting ripped off?). So, more posting, with more photos, in a few months after this current batch is puzzled out as best I can.
I am retired—worked 2500 hours a year for 48 years. Finally am having a chance to let loose and be silly. Am loving it.
-Bill
Next time contact Alex. He has a shop out Hwy 74 in Indian Trail. He has an EDM machine.
Thank you so much for thinking of me and giving me the pointer. Really appreciated.
I reached out to them. They responded they do not have an EDM machine. Oh well. I’ll keep on truck’n with what I got.
Thanks again.
-Bill
[QUOTE="682bear, post: 795834, member: 44088"
[/QUOTE]
Indeed. On my first trip to will-call at the Aurora Ohio McMaster I'm heading down the driveway thinking "wow that's a big warehouse". Then the driveway takes me around the corner and I realize that I was originally driving towards the end of the building. The side of the building was at least twice as big! Over 60 loading docks just on that one side.
