well its been a while, but other things got in the way, and some tidying needed doing to be able to progress to the next stage, anyway, this morning the tidying was completed and I had a space for the legs, after wrestling the bed next to the legs it was then a case of wrangling an engine hoist through the house and setting it up in a space no bigger than the spread of its legs, after this it was a matter of minutes to lift the bed onto the legs, aligning the bolt holes was fun, but eventually it was all completed, the headstock and tailstock were lifted up and placed on the bed,
after this it was time to look at the bed and do some clean up work, there was a spot on the carriage ways where there was a section a foot long that was badly pitted with rist, I have worked this with a smooth file to break through the rust, then gradually finer stones have been used to smooth out the surface, the pits wont overly affect the carriage movement, but it needs to be smooth, I will work on this until I am happy with the carriage movement.
this last picture shows the state it was in before, this is right at the end of the ways, past the tailstock, so is not as crucial, but it will still be cleaned and smoothed.
next will be the headstock and tailstock ways, these have some bad damage near the chuck, but this area isnt needed as much, as neither the headstock or tailstock run in this area, it might be an issue for the steady rest though.
