NICE!It is just a 40 years old 4 gear 66 CC Zundapp engine (stock 50 cc). The carb is a Mikuni VM20 (20 mm to the cylinder flange).
It is a quick renovation of an ugly duckling a bought a few weeks ago since it was running at least. I came out quite nice though, and the value has increased by a factor of 4, to about $4 k. I'll keep it for my small collection.
Just wondering what you did to prep the surface?Thank you guys.
The end of the rear frame looked quite bad so I sanded it and sprayed it with a 2-component paint. The result is almost astonishing. I didn't know before that this type of paint is so good compared to conventional 1-component base and 1 component clear coating. The 2-k paint is super glossy as is and need no layer of clear coat. It is also resistance to fuel and can be used on fuel tanks.
The last surfacing was done with a 1000 grit paper.
Before
After
