Do you guys know the size of the taper on the drill chuck arbor that comes with the PM932M?
I was using a large hole saw, the chuck loosened up during operation, saw bit, and threw the chuck off a bit on the arbor. They're still mated right now, but the runout is huge.
I was looking to pick up some removal wedges and I'm trying to ensure I purchase the correct size wedges. I'll pop the chuck off, clean up the tapers, then re-set the chuck. Hopefully it's not boogered up too bad.
