I now have upwards of four hours ( yep that new) of actual lathe time on my 1948 mw 2136. I am just starting to figure out what I don't know. These questions probably should be in beginners forum but you folks know Logans so I am back.
I know this all depends on many factors, so I don't expect specifics on this but what kind of typical depth of cut are you using with my size lathe. I'm thinking of rough cut, 12l14 steel and only 1/2 hp original motor. I am using hss tool bits in a lantern style holder? Any rules of thumb?
Obviously I am saving for qctp and inserts but lots of other expenses right now so learning with what I have.
Second, after doing only two gear changes I realize the value of a quick change gear box, I have regular change gears. Old manuals show gearbox and lead screw option sold as a package. I know they are hard to find but when I search the internet only see gear box without lead screw. Am I missing something or can you convert the original screw?
Does anyone know what part numbers or model numbers I should be looking for regarding qcgb and lead screw?
Thanks for the continued help.
