A Shop-Made Compact Rotary Broach
randyc
Active Member
#1
I’ve been looking at some shop-made rotary broaching tools for about a year, thinking that one could be very handy when a small internal feature is (occasionally) required. Finally I decided to make one and the result is shown below with the tool installed in a vertical mill.
Most shop-made rotary broaches that I’ve seen use a pair of radial ball bearings and a ball thrust bearing. Most of these tools are also pretty darned large and would look ridiculous on my 8 x 30 vertical (definitely overkill for my needs).
I made the compact design shown above by using a single hardened ball for alignment and thrust. The ball thrust bearing runs in wheel bearing grease. The body of the tool is made from drill rod, torch-hardened moderately. (I would have used pre-hardened 4140 if I’d thought of it.)
The broaching tool was also made from drill rod but is harder than the tool holder. This is the second one made; the first was ruined while torch-hardening the finish machined part. The second one was turned to the finish diameters but only rough milled to the cutting shape.
After hardening and tempering, I used a solid carbide end mill to carefully bring the broach cutting surfaces to finish dimension (I have no surface grinder). Before using the tool and after removing cutter marks from the sides, I put it in the mill and gently lowered the rotating tool against a hard Arkansas oil stone to polish the face.
I didn’t make a radiused face like most of the other shop-made broaches found on the internet. This was intentional due to comments written by a guy (manufacturing engineer, foreman, production machinist ?) who worked for Volkswagen for a number of years and was closely associated with their rotary broaching operations.
He wrote that, not only was the “dished” cutting face unnecessary but that it diminished the time between sharpenings because the sharper edges broke down and the breakage, although not visible, was easily seen under magnification as cratering and erosion of the cutting edge.
This is important because the cutting tool is tapered ! Any sharpening of the face reduces the dimensions of the finished work. I decided to give his opinion a try. I figured I can always carefully “dish” the face later if it didn’t work properly, right ? This is the result of the first test drive.
The hole is octagonal, .340 inches across the flats, .500 deep, .750 square CRS material. I made the pilot hole .005 oversize then countersunk generously to provide a good start for the broach. The broach was run at 1000 RPM (just because) using black pipe threading oil.
It is visible in the photo that the feed was erratic. I might try using the boring crank rather than the quill lever next time as well as experimenting with spindle speed. Total broaching time was on the order of ten seconds.
The shape and dimensions of the prototype broach were arbitrary, determined by whim. More practical applications include producing “D” holes, hex holes, square holes and splined holes.
It seems like this tool will be handy. I can quickly make up custom broaches from 0.500 or 0.750 drill rod as the need arises. (I don’t envision producing an internal feature larger than 0.375.) For my purposes, heat treatment is not at all critical so a torch and some motor oil will suffice. I doubt that any broach that I make will be required to produce more than 10-20 parts.
(An example anecdote: I made a tracer attachment for my smaller lathe about ten years ago. It worked well although was sort of a PITA to set up. To date I have made a total of five parts with the system.)
Here is the complete tool; the house key gives an indication of tool size …
Works in the lathe too, of course:
And here’s a sketch:
The shank of the tool is offset, as can be seen. The offset and the length from the ball to the cutting edge of the broach is intended to produce a cutting angle of 1.5 to 2 degrees. The angular clearance on the sides of the broach must be just slightly greater than that. Too much clearance and the broach won’t “track”, producing a spiral cavity.
Edited to add: the sockets for the .500 ball are made with a .500 ball end mill secured in the tail stock drill chuck of the lathe. The lathe should be slowed way down and the feed from the tailstock moderate else the socket will NOT be spherical.
Ulma Doctor
Infinitely Curious
Active Member
#2
excellent design!!!!
i have wanted a rotary broach for years but i haven't made one yet.
your design looks like it's right up my alley!
thanks for the info and drawing!!!
:thumbsup2:
mike:))
randyc
Active Member
#3
Cheers, you have probably noted this already but the four set screws do not touch any surfaces during normal operation. They exist only to prevent the broach holder and the ball from separating from the shank when the tool is not in use. Three screws would be fine ...
It's a fun project, inexpensive and doesn't take much time.
rwm
H-M Supporter-Premium
#5
Very nice.
Why do the sockets for the ball need to be spherical? Wouldn't a simple countersink center the ball just as well? Is it a force issue?
R
randyc
Active Member
#6
Very nice.
R
You're absolutely correct, rwm !
A center drill or countersink could locate the ball just fine and - for my modest needs - would last as long as me, ha-ha. But the very much increased spherical contact area won't wear as much as the center drilled hole . (The two parts that bear against the ball are not hardened very much -)
Greedpetey
Swarf
Registered Member
#7
love the simplicity of the design, I think I'll try my hand at one. What is the ID of the shank? I didn't see that called out on the drawing.
-Gideon
talvare
Ted A
#9
Randy,
Thanks for posting your design. I just finished making my rotary broach copying your design. I up-sized some of the components a little although it probably wasn't necessary. I initially turned the offset for the drive shank at .092" which would provide the 2 deg. cutting angle. For some reason, this just didn't work for my tool. I ended up re-doing the offset to .180" and it now seems to work well.
Thanks again for sharing.
Ted
Silverbullet
Active Member
Active Member
#10
Thanks this is one that's going up to the front of the list. I see square holes in my future , tools are us. Thanks really all kidding aside it's a great easy tool to build and use. I've looked at brooches and there costs just make me winch in pain. Great job lots more will be thanking you too.
