  • Untitled 1
    As promised, a formal announcement has been made regarding recent changes in the administrative staff here at H-M.
    Please take a few moments to go to our home page and review that announcement.
[4]
Am I discarding my cutting discs too quickly?
[10] Like what you see?
ericc
Active Member
Dec 24, 2013
257
Likes
59
#3
The guru of anvilfire says that most beginners cheap out on grinding disks by buying the long lasting ones instead of the quick cutting (friable) ones. I saw this happen myself when I was helping another blacksmith radius an anvil made out of a piece of AR armor plate. He was buzzing away for 40 minutes without much progress, and declared the job impossible. I went to the welding store and picked up a premium Walter soft wheel and did the job in 5 minutes. It was better than a factor of 10, because I did more work than he did. I spent $5 for the wheel, but it was money well spent. I gave him the remainder of the wheel, but he said it was a little rich for his blood still. Running a wheel down that much is pretty hilarious, but I suspect that slow grinding at that lower surface speed could waste quite a bit of time.
Ken from ontario
Active Member
Active Member
Dec 26, 2016
539
Likes
396
#5
:grin::grin:,I think you are pretty close to the "throw it away" size, I also like Walter brand and zipcut disks are the ones I use the most but when they reach to that size ,it is time to put in a new one.
But you already knew that.
magicniner
Active Member
Active Member
Oct 21, 2017
73
Likes
50
#6
I put worn discs like that to one side for when I have a job to grind in a tight space ;-)
savarin
H-M Supporter-Premium Member
Aug 22, 2012
1,608
Likes
2,094
#7
I dont think you are using them enough to throw out.
If cutting a narrow strip from some material theres at least another half inch of use there
menace
H-M Supporter - Premium Member
Jan 31, 2014
18
Likes
9
#8
Looks like you got your money's worth out of that one, time for a new one.
While I'm at it does anyone know if Razorwheel discs are still available ? Best I've ever used no BS ! Can't find a supplier for them around here! Thanks.
[6]
[5] [7]
