- Oct 18, 2016
- 2,872
Greetings,
I recently acquired a Logan 200 to replace the 6" Atlas that I've been using for the last few years and
wanted to start a thread on the "rebuild" I plan on doing before I get it up and running.
Despite it's age, it seems
to be in pretty good condition, though of course it has a few issues. My plan is to clean and lubricate everything, make repairs and get it running. I may also add a VFD.
From the S/N, it seems
that this lathe was built during WWII, so I'm assuming it was sold to the Army. This is one of the early
200's, with the separate post that supports the countershaft assembly. It's painted a sort of OD green,
which was sprayed over the original gray.
I started the project by picking up a cast countershaft support off eBay: for some reason one didn't come
with the lathe. Then I decided to fabricate a welded machinery base for the lathe. I did this for several reasons.
Unlike the later 200's, the support post doesn't "attach" to the lathe itself: it has to be bolted down in the
correct position so that the aft part of the c'shaft assembly rests on it. I think the intent was that these lathes
would be bolted down to a floor. Logan changed the design later: I assume because there's no way to leave
the lathe free standing with the unsupported post. So, the machinery base will allow everything to be bolted
down in their correct locations. The base weighs about 75-80 lbs, which will add some rigidity and mass,
and will sit on 5 leveling mounts. The other advantage is that it raises the lathe up to a more
comfortable working height, which will help with my less than perfect back.
I've already purchased a few small parts from Logan, and got the parts list and manual while I was at it and
begun taking apart sub assemblies and cleaning things up. Which leads, inevitably, to the first problem that needs to be solved. Last night I started taking apart the headstock: the bearings seem pretty
smooth but sound dry to me so I want to take a closer look and get things cleaned up. After removing
the take up nut, spindle gear, key and spacer, removing the set screws and the bearing cap screws, I tried
to tap the spindle out with a rubber mallet. It's moving, but it's stubborn, and it seems that the aft (smaller) bearing is frozen to the spindle, so that it's moving with it. This has resulted in the bull gear
pushing up agains the headstock casting. I stopped at that point, and have the inner race soaking in Kroil.
Has anyone experienced this, or does anyone have a suggestion on how I might resolve this. It seems as
though the inner retaining collar is also "stuck" to the spindle. Thanks!
