  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
Any Info On Speedway Drill Mill Dtmach34/03989
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by Dragonheart, Jul 28, 2015.
  1. Dragonheart
    Dragonheart United States Iron Registered Member
    9
    3
    City:
    Katy
    State:
    Texas
    I recently acquired an old SPEEDWAY DRILL MILL - model #dtmach34/03989 that I understand was originally sold by Homier ion early 2000's. Would anyone have one of these or any information on this old machine like what kind of spindle does it use. It has a 5/8" chuck I would like to increase to 3/4".
    Thanks
  2. Ripthorn
    Ripthorn United States Active User H-M Supporter-Premium
    210
    43
    City:
    Austin
    State:
    Texas
    I have not used one, but knew someone who had one that I saw several times. His was was outfitted with ER40 collets, if I recall correctly. I don't know if that was aftermarket or not, though.
  3. Dragonheart
    9
    3
    City:
    Katy
    State:
    Texas
    Thanks for the information, at least it's a starting point.
  4. Dragonheart
    9
    3
    City:
    Katy
    State:
    Texas
    So far the information or mis-information on the internet list the 03989 spindle as being a MT2, which the person I purchased the Speedway from said it was not. Some say it is a MT3, so when I have the time I will dig into it and see if I can figure it out. I had hoped there was someone on this site that had one and knew for sure.
  5. hardwarz
    hardwarz United States Iron Registered Member
    5
    3
    City:
    Akron
    State:
    Ohio
    Here's the information I dug up when I unearthed my mill from my parents house, where it sat unused for over a decade.
    Drill/Mill Machine
    Speedway Series (Homier)
    DTMACH34-03989
    Motor:
    3/4 HP, 56 frame, 10.6 A
    Lever handles:
    M12 x 1.75 mm
    Revolving Handles:
    M10 x 1.5 mm
    Taper:
    MT2 taper
    Included Stock Arbor:
    MT2 to B18 with M10 drawbar thread
    Included Stock Drawbar:
    M10 x 1.50 mm x 275 mm
    Replacement Imperial Drawbar:
    3/8"-16 x 10-3/4"
    Speed:
    390-480-600-780-960-1080-1620-1750-2150-2280-3259-3950
    Max. Drilling Capacity:
    5/8" (16 mm)
    Max. Diameter of Vertical Milling:
    1/2" (12 mm)
    Max. Width of Face Milling:
    1-1/2" (40 mm)
    Table slots:
    7/16"
    Table movement:
    9-3/4" x 4-3/8"
  6. hardwarz
    5
    3
    City:
    Akron
    State:
    Ohio
    I'm using an MT2 ER20 collet chuck with an M10 thread for the drawbar to hold my end mills. I only purchased a 3/8" ER20 collet and 3/8" shaft end mills, so I don't have a lot in tooling right now. I'm wondering if I should have went to ER32 collets....
  7. Dragonheart
    9
    3
    City:
    Katy
    State:
    Texas
    Thank you very much for the information. One of my plastic revolving handles was broken, but I was able to find an all metal replacement on Ebay. They have a slightly larger but better ergonomic grip, so I replaced them all. I think you made the best decision going with the ER20 size, as I have found this really is a better drill press than a mill. Maybe one day soon I will have a shop where I can put a real mill, but so far this old drill/mill is giving me good service in my garage. I don't suppose you would have a manual for the 03989? I have been unable to find one online.
  8. hardwarz
    5
    3
    City:
    Akron
    State:
    Ohio
    Manual? No I don't. I contacted Homier, they don't have a copy.
    I was tramming my drill/mill and I noticed that there's a lot of deflection throwing off the accuracy. Eventually, I'll replace my mill with something better. I'll probably end up keeping this as a really accurate drill. I still want to put a DRO on it.
  9. Dragonheart
    9
    3
    City:
    Katy
    State:
    Texas
    I have been using mine mainly as a drill, love the table. I understand several owners filled the column with concrete. They posted it really helped. I can see the added stiffness would be a plus.
  10. djcnoteeastli
    djcnoteeastli United States Iron Registered Member
    4
    3
    City:
    Miller Place
    State:
    New York
    hardwarz likes this.
  11. hardwarz
    5
    3
    City:
    Akron
    State:
    Ohio
    Here is my current setup.
  12. djcnoteeastli
    4
    3
    City:
    Miller Place
    State:
    New York
    That's great. How do you like that vise? I was looking at the same one. Is that the 4"?
  13. hardwarz
    5
    3
    City:
    Akron
    State:
    Ohio
    I purchased it from eBay. It's the: SHARS 4 x 4-1/8" Precision Mill Vise Anti-Jaw Lifting W/ Swivel Base CNC New
    It's been a great vise. Way better than when I was trying to use a drill vise with the milling machine.
    I plan on making a way cover and also adding a vertical feed stop with a DRO.
    X/Y DROs will be added at a later date.
Share This Page
