Best Place To Buy Electric Motors
ex_isp
H-M Supporter - Premium Content
H-M Supporter-Premium
#3
Surplus centers are good! Harbor Freight is OK but you want to get their "farm motors". They have better bearings, the windings are completely dipped making them last MUCH longer and
they have great startup torque. If I went new, this is what I'd get. If used, surplus or from a friend.
JimDawson
Global Moderator
Staff member
Director
#4
I bought mine from Surplus Center. Watch what you are buying, they have some ''5hp special'' compressor motors that are closer to 3 hp. Look at the amps, a 5 hp motor draws about 23 amps on 240V. I bought another NOS 5HP, 3 phase for my other compressor off of Craigslist for $125.
The largest motor that Harbor Freight lists now is 3HP, and I have not been happy with the HF electric motors.
Ulma Doctor
Infinitely Curious
Active Member
#5
about 15 yrs ago i ran across a bunch of 240v single phase 56YZ frame air compressors that were "special 5Hp" manufactured by GE
so special that they were soon replaced by 5hp ,3 phase, 184t retrofits
ebay may be a source of reasonable motors
ex_isp
#6
Jim, was the standard or the farm motor you had problems with?
JimDawson
Global Moderator
Staff member
Director
#7
I think it was a farm duty. We tried two of them on Alloy's lathe and took both of them back. 3 HP, 1725 RPM as I recall. Both motors were very noisy, and overheated when running unloaded.
They don't seem to sell them any longer. In fact their motor selection is much smaller than it used to be.
ex_isp
#8
Thanks for that info Jim! I'd had good luck with their farm duty versions in the past. If they've gone downhill, I'll avoid them in the future!
Keith Foor
Active Member
Active Member
#12
Used motors I would look on Craiglist. You can see them and typically hear them run turn the shaft and feel for clunkyness that would indicate bad bearings. It saves you on shipping as well. If you want new, TSC has motors that are pretty good. From there if your pockets are deep go to MSC or Grainger. They will have anything that is possibly available or can have it in a days time. Those of course are new and that comes at a cost. But there is no question of quality with MSC or Grainger. It will be top quality stuff.
markba633csi
Active Member
Active Member
#13
Steelyards sometimes have a pile of motors that with luck you can pick a good one out of, and often they will let you test it- bring a cord with alligator clips and a meter.
Mark S.
Also they sometimes turn up in the oddest places, like Goodwill and Salvation Army.
