Building a house ...
Building a design that relies solely on PLC seems like a poor idea. PLC can radiate a lot of junk too. Do they have any alternative communications schemes available? Hard wired, like ethernet or RS-485, etc.?
That said, my well pump is constant pressure and uses PLC to close the loop between the 0-10,000 RPM pump and pressure at the controller... But I don't think I have anything else doing that, and the well wire is separated from everything else.
Agreed, and no. Definitely an architectural weakness imho. I believe above I mistakenly indicated that the battery is PLC but it is a wired protocol, they don't say what it is but I suspect something like RS-485 as it is differential multidrop. I can see why the inverters are PLC given the microinverter architecture with the inverters on each solar panel. Multi-drop wiring underground/outdoors gets ugly. PLC to those inverters is somewhat tolerable when the inverters were just reporting usage info and maybe an occasional software update. But now they are going toward inverter-based current limiting when there is a grid-imposed maximum output. That gets dicey as reliable PLC becomes time critical for compliance. Like your well it is primarily outdoor/underground but the through wiring on the solar controller does not make for a simple filter install.
They also dropped Ethernet to the controller, so the controller is wifi dependent. That was new, not clear when I bought the system. Previous generations of equipment offered both. Definitely unhappy with that, although it hasn't been a problem.
Hopefully some ferrite on the mini-split solves the current issue, but the house is still primarily unoccupied. I suspect the addition of the spectrum noise analysis is a result of earlier generation suspected problems, and with this newer equipment they're confirming it. If the ferrite doesn't do the trick I'm facing a 80 amp, 240V capable line filter.
Frustrated with the battery and linux reload on the laptop, as the SDR would be a quick and very easy way to track this down. Or the inventoried Rodhe & Schwarz portable spectrum analyzer that I couldn't take with me, but nobody else was going to use when I retired. Guaranteed that the drywall will finish at the same time the replacement bits and pieces arrive.
Drywall is done. Overall I’m very pleased with the quality of work. Just a tedious process, and although it’s expected, it is messy. We’ll need to get a dumpster to haul away the scrap, but that’s over due given general construction waste.
It was also refreshing to deal with a contractor that didn’t have a contract, down payment, or other legal process. Paid them in full yesterday when they picked up their scaffolding.
Pictures of the pre-drywall framing did save my hind end already. Two outlets got covered over. Was able to pinpoint their location and cut them out without damaging any surface. I suppose I could whine to them about that but perfection isn’t cheap. Also, although it took quite a bit of flipping between pictures to trace wiring out of a subpanel, I was able to resolve an electrical wiring confusion. Had pulled most of the outlets and switches prior to drywall, and in putting them back something wasn’t right. Turned out to be two breakers that were mislabeled (swapped). That cost much of Sunday afternoon.
Much of the ceilings are already painted, and thanks to a high school friend from Duluth, Mn visiting, about half the outlets are replaced. Need more friends like that! We did take some time to play on the heavy equipment, dug out a flood water retention pond in one of the two gullies off the property hillside, and dropped a good sized dead tree in the woods.
Ferrite beads arrived so those will get tested later this morning, more painting, mopping /vacuuming up drywall dust, and reinstalling light fixtures for the next few days.
Token painted drywall picture. Ceiling will get some sort of wood panel/lath finish.
It's coming along nicely.
Curious about something. Here we're required to have drywall on ceilings for a fire stop. Assuming that's not required where you're at?
Correct, not required. I am thinking I'll put a good coat of code rated intumescent paint on the ceiling before we do the intended wood paneling.
Looks like a pair of ferrite beads on the mini-split disconnect reduced the background noise by about 7dB, which is enough to keep the solar PLC happy. I used the 30A rated beads from Enphase. Although their installation instructions say to put them on the panel side of the solar controller, I figured putting them closer to the noise source was better. And of course the solar controller is on a 100A connection to the main panel, so bigger (pricier) ferrites would have been required. Thought about digging through ferrite design criteria (essentially an LRC filter) and seeing if I could come up with cheaper ones from digikey, but ended up just buying from Enphase at the substantial price of ten for $130.
Several weeks of painting all the drywall. Have gone through about 20 gallons of paint for all the walls. And another 5 gallons of the fireblock paint on the ceiling, which needs another coat and I'll have to open the 2nd 5 gallon container. Stuff ain't cheap, either. I'd post pictures ... but of what, solid painted walls? Or walls that need a second coat? Not exactly picture worthy material.
Started putting concrete backer board down for tile. Kitchen and pantry cabinets arrived yesterday, but need to finish up the flooring in those rooms before we can install those.
About the same time you posted this, I gave away three gallons of primer.
At least painting isn't the worst work in the world. Once set up to do it, I don't mind painting on new construction.
Repainting something isn't a favorite activity... LOL.
The time consuming thing about initial painting is finding those little imperfections that need touch-up in the drywall work. We're using an 'eggshell' sheen for the paint, which shows things a bit more than the very flat drywall/mud surface. And of course you're going over every square inch when painting, much more so than a finished drywall inspection.
For variation I've also been putting outlet/switch cover plates on. Does give things a finished look even without trim and flooring.
Did spend a few minutes on the lathe yesterday turning a UHMW lid. Shop has suffered from a year of disuse. Entropy is setting in. Looking forward to more shop time but probably another year of serious house work before things slow down enough for that.
Had a dumpster onsite Monday/Tuesday. Loaded up 20 yards of debris quicker than I thought, used the 6 ton trash compactor to get everything to fit. Had intended to keep the dumpster longer and do some misc cleaning of old junk, but it was compacted and full by the time it left. 4860 lb load, most of the weight probably drywall scrap. Also quite a bit of HDPE and PE pipe which would have been worth melting into stock but there are only a finite number of hours in the year.
Have you lived in a house with eggshell finish paint before? I know this is all personal preference, but two houses ago (which we had built) all the walls were done with paint with the eggshell finish. We loved them for about three months. It is impossible to touch up an area - we would have to repaint a wall from corner to corner. Ended up repainting everything with a satin finish. Used satin finish for the house we are currently in.
