Building a house ...
I used a flitered unit because if you just use a register the grease builds up in the duct over time. It's a permanent filter made of stainless steel mesh. I clean it every 5 years or so by soaking it in solvent.
Mine is aluminum mesh, and I clean it more often than that; it fits in a dishwasher.
I have 9 foot ceilings and to get to the filter I have to put a 2 x 10 and blocking across the stoves. Kind of labor intensive. Five years seems about right as it's still filtering well but starting to look greasy.
The time had finally come to move a beverage cooler into the new house. Lots of work to do yet, but this will facilitate the thinking and planning portion at the end of the day. Had to pull the doors off frig to get it through the door. It's a 36" wide by 31" deep model with the doors and door hinges removed. Plenty of room for a complete beverage selection.
If I tried to do anything on a 5 year schedule it might as well be never. Anything longer than yearly would elude my memory and organizational skills. Yearly chores sometimes slip (the above tractor is overdue for annual maintenance), but at least they stick in my memory. Or at least I can write dates and hours on prominently on those filters, less attractive to do that on a range vent.
Continuing to play with the thermostat project I mentioned on this thread back in early July. Cranked out a smaller sensor-only version (no solid state relay outputs), waiting for that to come back from fab.
Molex pin connectors will actually be screw terminals. Just too lazy to find a proper 3D model just for a picture/image render. Lots of AI facilitated coding used, mixed feelings about that. Would not have otherwise had the time to do detailed coding for all the features implemented. But the code isn't as carefully reviewed. Reminds me of transitioning from embedded coding with assembly to using C/C++ a couple decades ago.
This is meant to be a battery operated version (3 x AA's), WIFI + RS-422 + USB interfaces, but primarily to log to a syslog server to record temperatures on the radiant floor heating pipes. Using a Pico 2W gumstick, which is familiar but not the best choice for this project as it isn't the best at low current standby mode (i.e., long battery life).
I hear you. Let's call it 5 years-ish.
A little bit of machining related content to homebuilding -
Kitchen cabinets are installed and I've been putting in the handles in the odd moments between other bigger projects. Started by using one of these cheap amazon jigs:
I found that if I drilled one side, stick a screw through, and drill the other side, it mostly works, but
the guides use a 4mm hole (about .155) and it comes with a 4mm drill. The hardware screws are also 4mm, and wood doesn'talways drill to size. So I often ended up using the battery driver to screw the 4mm machine screws through the wood as I couldn't quite press them through easily by hand, or risked blowing out the wood on the face if I did that. Well, that means there isn't much give in the screw holes so it is easy to end up with a couple of holes that are off by maybe 0.030 and won't line up. Well, I snapped I screw off in one handle by trying to force alignment and it cross threaded.
Workable for drawers, but a disaster for cabinet doors. The problem is you're trying to hold the jig from sliding down the door, while holding the door open, and holding the drill in the other hand. I'll just have to admit I'm not that skilled. But this only needs to happen once ...
Yes, I can and will fix that by slotting the holes for both handles maybe 1/16".
But I decide to make this -
Fixed jig referencing both edges of the door. It's double sided so I can flip it. It's aluminum, 2"x1.5"x10", the holes are 1/2", I'll make some steel bushings/buttons that are drilled as a guide for a 3/16th bit. Plan is to press fit (or locktite) them in, do all the left hand doors, pop them out, flip everything, and do the right hand doors. Yeah, I could get fancy and tap them I suppose, and heat treat some tool steel for the bushings, but it's a quick fix for my lack of manual skill with a battery operated drill, not a machining show piece.
Also, apparently my mill doesn't like sitting idle and is rebelling. Yesterday's project surfaced two problems, the variable speed input is binary, max or min with noisy jumps between them if I try to get something else, and the X axis power feed failed. Likely the variable speed is a bad multi-turn pot that might just be fixed with some contact cleaner although replacing the pot is probably as cheap as buying contact cleaner. The X axis power feed has acted up before, it's a plastic gear that needs loctite on the retaining screw iirc.
