  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
Can We Talk About Gibs?
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by Hukshawn, Jan 7, 2017.
  1. Hukshawn
    Hukshawn Canada H-M Supporter - Premium Content H-M Supporter-Premium
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    when I made that back plate for the 4 jaw chuck, I had enough movement in the compound to annoy me. I had to put the compound at o degrees and move it closer to one side (far enough off centre) to get close enough to work on the plate. Because of the interrupted cut for the first while I had to really tighten the gib to stop the .010"~ play. Which eliminated the use of the compound side as it was too tight... I loosened it off since to use it but its still somewhat stiff. I haven't tried again to dial it in again yet. there is still some lack of rigity there. There's still movement. We're not talking about tons of movement but enough to annoy me. Especially if I'm cutting an internal thread (which I've been doing a lot lately. Made 3 spindle threaded pieces for various projects so far)
    The last time I tried to fine adjust it I was unsatisfied. There's a very very fine line between rigity and smooth movement, and I haven't quite acquired it.
    What can I try aside from the back and forth of adjusting the screws?
    I should note. The gib is about 1/8" - 3/16" thick and there are 4 adjustment screws. There is no damage in the dovetail or gib
  2. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    I took some pictures to show the setup, it wasn't until I turned everything around I realized the gib is NOT seated well at all... never noticed that before... don't like that at all, I'm sure that has created huge amounts of unwanted wear on that dovetail.
    How can I seat that better??
    Edit... I figured out how to embed my photos instead of just attaching them. That should make it easier to view them without having to open the image.
  3. mikey
    mikey Active User H-M Supporter-Premium
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    Shawn, it might be the camera angle but are those screws hitting the gibs above the gib centerline? If so, then they will cock the gib like they seem to be.
    First, remove the gib and clean it really well. Make sure there is no damage to the gib.
    Is there something between the gib screws and the gib? If so, what is it? If not, then I would suggest you use make some very short rods with an angle on the gib end to match the dovetail angle on one end and a flat on the other end to contact the screw. Make three and use a ball bearing for the screw you use for a gib lock. This gives much broader contact for the adjusting screws without chewing up the gib itself. The ball bearing allows point contact when locking the gib.
    Once you have those inserts in place, adjust them. I would suggest you adjust from the inside, out. Loosen all screws, then bring a center screw into contact plus, say, 1/8 turn. Do the other center screw and do the same thing, working out to the ends. Then try it and see. Adjust until the compound moves smoothly but without play.
  4. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    I get the idea behind the angled plug. I have some brass I could use. But maybe I read this wrong, I'm not visualizing where the ball bearing goes...
  5. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    It replaces one of the angled plugs.
  6. stupoty
    stupoty Active User Active Member
    195
    63
    City:
    London
    The bigger screw for locking the slide should probably be in one of the middle two holes, their may be a bigger recess in the gib strip that shows which hole it went in originally.
    Stuart
  7. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    I think the big screw is because someone broke s set screw or stripped the hole
  8. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    Mike, is the bearing thing kind of either use the brass plugs or bearings, one or the other? Or is there a purpose to use plugs and bearings here or there?
  9. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    Put the bearing in one of the center holes. It is just a way to lock the gib.
  10. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,186
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    I agree with mikey on the screw holes being too high preventing the gib to bear correctly on the dovetail. The gib really needs to be thicker to fill up most of the gap in the slide assembly. Last, if I had to guess, the compound needs to be rescraped and fitted to get the bearing surfaces of the dovetails bearing properly, along with making a new gib. This would help on keeping the slide from creeping on you too.
  11. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    Sorry, I gotta run through this to properly understand...
    So, one of the middle two holes, put a bearing into the hole, then the set screw. Then the other 3 holes, the brass plugs with angled tips then the set screws?
    I am understanding the need to get that gib angled better, but it's just the order of operations that is iluding me.
  12. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    Oh my god.....
    Okay guys, here's my moment of shame....
    the gib was backwards. The set screw pockets were on the other side. For Christ sakes...
    Either way. It's still kind of stiff even with the gib backed way off. My dials are aluminum and they bind slightly and are stiff too, I may need to look into a bearing seated dial fiasco.
    Might be worth doing a bit of an overhaul on the compound.
  13. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    Yes, you have it
  14. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    You aren't thefirst guy to do that so don't be too hard on yourself.
  15. 4gsr
    1,186
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    It might be worth while to take apart your compound slide and do a good cleaning and visual inspection of the slides. May need to do a little deburring/ smoothing out slide surfaces with a oilstone. Fix any galling of shafts, bearings, etc. This little bit TLC and some fresh oil on everything could work wonders!
    fixit and mikey like this.
  16. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    I agree. I did that when I brought the lathe home no more than a few months ago. But I will do it again. I want to look into setting bearings into the shaft in the dials to be able to tighten the nut but remain smooth. Stefan gotteswinter has a couple good videos of that on his YouTube channel
    4gsr likes this.
  17. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    Shawn, I just re-read this thread and noted that your gib has pockets on the back side? Can you show a pic? If there are actual pockets then a angled insert will not work if you plan to use that stock gib. The inserts have to match the gib's features. If you make a new gib then an angled face will work well. If it has a coned hole then make the inserts with a matching cone.
    4gsr likes this.
  18. stupoty
    195
    63
    City:
    London
    Ahh fair enough makes sense, some lathes have a cap head gib screw to lock down with :)
    Stuart
  19. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    The pockets are angled.
    I don't have the ability to make a new gib. No milling machines. So ya, likely reusing this one. If I can get the time, I'm going to do a tear down again. See if I can make it better.
  20. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    Well, I tore it all apart. No room in the collar to put bearings and I'm not interested in making new ones cause I'd have to make a new longer shaft. However, I cleaned everything out, honed some surfaces, (the ways still have scraping marks, so that's nice), made some minor modifications to allow the collar and graduated ring fit a bit better and I think I'm somewhat satisfied with the result. Minimal movement, much more rigity, and relatively smooth operation. Yay..
  21. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    Glad you got it sorted. Is there room between the surfaces of the collar to fit a really thin Delrin washer? They can make a huge difference in smoothness.
  22. Hukshawn
    124
    43
    City:
    Bowmanville
    State:
    Ontario
    It's possible. I could cut a relief to fit a small washer, that would probably solve some minor binding issues I get. But I noticed while cleaning and honing the collar, it's hardened. Or, very hard tool steel. Did not file well, had to rub it along my hone to clean and smooth the facing surfaces.
  23. mikey
    795
    113
    City:
    Honolulu
    State:
    Hawaii
    The washer simply needs to go between any two sliding surfaces. I would think a 0.015" thick washer would do the trick.
  24. Joncooey
    Joncooey Canada Steel Registered Member
    25
    13
    City:
    Colborne
    State:
    Ontario
    Excellent conversation fellas. My '42 Atlas will benefit from this sort of attention. Glad to be a fly on the wall; I'm learning a lot.
    Hukshawn likes this.
Share This Page
