Yes sir cheap,quality in the same sentence.Guys over the yrs I have rebuilt several machines which I posted pics of them here,asking lots of questions.Guys alot of time when I go to apply the first coat of primer on cast iron parts I will thin the paint just alittle and use a 1" paint brush for first coat.Now if its small sheet metal parts I will also use the 1" paint brush.I'm not expecting a smooth as glass finish cause I will sand after couple coats of primer and then sand and spray couple coats of the finish color.So you see that I use paint brushes then toss them just because they are cheap.
Guys since Harbor Freight came to town I would go down and buy a box of 1" paint brushes which I think is about 8.00 for a box and they were perfect.But I guess over time HF has decided to cut corners and go with a cheaper brush.The bristles are all different lengths and they just fall out even when you run the brush across your hand.(I know what do you expect for 8.00 box) Well at one time they were good.So guys what I was wondering if someone knows of a source on the web for 1" paint brushes that is just a step above HF quality that can be toss after use? I did google cheap paint brushes but its hard to tell looking at pictures so maybe first hand info would be better than rolling the dice.Thanks guys,being cheap---kroll
Guys I just look over on the auction site and there is a lot of brushes,but all the pics makes the brushes look good.Do you have a favorite seller that you purchase from?
