First post here, but looking for guidance on what direction to go before I start spending the $$$.
I have a number of tools that lack collet assortments, my mill is a Gorton Taper - and I have a full set of their proprietary, but would like to make a Gorton to ER or similar adapter or simply mount a 1/2" straight shank ER into the collet when in use.
But I also have a few Lathes that I would like to begin using collets on. One is an Atlas/Craftman 109 - MT spindle with threaded nose. Also have a SB Model A which is ~the same thread on the hose and the same taper.
I'm debating making ER threaded adapter for the nose, also because I could get the same ER collet set to work with the shank on the mill, make an adapter concentric on both lathes.
Negative of this - is of course the reverse direction on the lathe can loosen the chuck. The positive is that there's some through capacity with no drawbar.
I could also buy MT 2 or MT 3 collets w/ a drawbar for the lathe. I could do an MT - ER collet with a drawbar.
I could buy and obtain 5C collet chuck.
Little machine shop the 3C nose adapter and collets (drawbar).
So I guess my main question to the masses here - knowing the size and capacity of these machines - which direction would you go? Also ER sizes - I think it would be nice to go larger on the Lathes to have capacity above the spindle bore for parts, but that may be somewhat obnoxious on the mill.
The 3C is lathe specific and probably more $$$ than it should be, 5C of course makes sense if I buy a larger/newer lathe.
So before I go nuts - what would you guys do?
